Question about Black & Decker BDP2600 Gas Powered Pressure Washer
Leaking profusely from handle part of gun. Loss of water cuts washing pressure considerably. Tightened screws, to no avail. Part has been discontinued per B&D website.
We used to replace the gun periodically, but we used commercial grade equipment from paint store and not the B&D from box store
Pressure washer Guns
http://www.ultimatewasher.com/pressure-washer-trigger-guns.htm
Pressure washer fittings that you can put on end of your hose
http://www.ultimatewasher.com/fittings-connectors.htm
Look at the connection where gun fits to hose >>> can this unscrew?
Look where the hose connects to power washer >>> can the hose unscrew?
When buying a new gun, the key is the connections >> it has to connect to the hose.
If you can unscrew the hose or unscrew the connectors connected to gun, then you can buy a new-hose-and-gun or buy a new-connector that fits your existing hose, then buy a new-gun that fits the connector
Posted on Oct 11, 2010
  • John White
    John White Apr 06, 2015
    A video discusses this problem and points to a blog that contains a solution:https://youtu.be/_amfg3qV4rs
Motor starts and cuts out when using gun now wont start
About 622,000 results (0.78 seconds) Search Results
    Troubleshooting Your Pressure Washer - Jacks Small Engines
    www.jackssmallengines.com/diy/troubleshooting-your-pressure-washer/
    Mar 18, 2015 - Or, you are in position to start washing, you pull the spray-gun ...Inspect hose for any twist, cuts, bends or dents. ... Your Engine Won't Start or is Lacking Power ... carb got motor running now hoses leaking and little water coming outof a ... I have a troybilt with a Briggs & Stratton engine 3000 max pressure.
    How to Fix Washer That Won't Start ' Washing Machine Repair
    www.partselect.com/Repair/Washer/Will-Not-Start/
    Find out how to repair a washer that won't start by troubleshooting and testing common parts like the ... Read on to learn how easy it is to fix the washing machine yourself. ...ApplianceHelp.com is now PartSelect.com .... If the motor starts, then the problem iswith the transmission or the pump and can be further diagnosed by ...Missing: gun
    Washing Machine Won't Start ' ThriftyFun
    www.thriftyfun.com/Washing-Machine-Wont-Start-1.html
    This is a guide about washing machine won't start. You have ... Is the motor burnedout? My wife was ... My Maytag Neptune was running; then the power went out andnow it won't restart. By Larry L. ... Question: Washing Machine Starts to Fill and Then Stops. When I try to ... It has something to do with the door lid. I usually ...Missing: gun
Jan 28, 2016 | Washing Machines
Just had the spider gasket replaced and now water is "gushing" out the handle
Hi Shari,
I see two possibilities. 1. The diverter shaft o-rings are not sized correctly (or missing). 2. When valve handle was reinstalled it was not oriented properly with the diverter position in valve body.
Hope this helps you.
Jun 14, 2014 | Hayward SAND FILTER, PRO SERIES
Where can I find a replacement for the trigger handle for task force 2000
There are quite a few replacement guns and hoses. If you do a search; " replacement power washer guns" you will have many sites wit numerous guns that will work.
  • Sorry, this item is not available in
  • Image not available
  • Amazon com Powerwasher 80012 Universal Electric Pressure Washer...
    Jun 03, 2014 | Task Force 2000 PSI Electric Pressure...
    How to fix 12POE-150 power washer leaking gun wand
    There are no parts available for the inside of the guns. All you can do is replace the gun.
    see parts in link.
    http://www.ppe-pressure-washer-parts.com/12POE-150-power-washer-parts
    May 01, 2014 | FAIP 1500 PSI Electric Power Washer
    I have a Karcher 110 pressure washer and when switched on to jet wash the water is coming out of the handle and just trickling out of the jet nozzle please can you help. Thankyou Brian Hills
    Which part of the handle is water leaking from? It could be that the hose connection into the gun is not fitted properly. Otherwise it could be that you just need to replace the handle.
    Feb 28, 2011 | Garden
    Leaking around the top, tightened the handle, leaking down the sides to the base from top ring
    hi . there should be an o-ring or a piece of dirt under the top . cut water off and take handle off clean and put back together it should be fine. have a good day.
    Feb 09, 2011 | Kohler FortĀ© Single Lever Handle Kitchen...
    I have a Moen shower faucet that is six years old(copper sweated plumbing). My wife noticed water dripping profusely from the downstairs ceiling during my shower. The screws holding the face plate were...
    Try removing the handle, then the face plate. With a flashlight handy, check inside the wall around the valve to see if you see any leaks. Then, try the valve by pulling the stem (may need a plier to grab this). Keep checking inside the wall. Next, try the shower, and again watch in the hole you have. You may find that the connection(s) to the valve is/are leaking, particularly at the top of the valve where the shower pipe heads up the wall. Or, it may be that the shower head's arm is leaking somewhere above. If you only see water dripping down from above, try the flashlight with a small make-up mirror to see if you can see where it's coming from. Sometimes the pressure in the shower head builds up from the flow restrictor, or the head's spray holes may need cleaning out (try soaking the head in a solution of CLR [stands for Calcium, Lime, Rust] available at most home improvement/ hardware stores). Sometimes the shower arm (the bent 1/2" diameter pipe that the shower head mounts to) isn't fastened in tightly enough. A good trick to help here is to wrap the threads with teflon tape, then apply teflon paste also. Wrap the tape clockwise around the threads so that it doesn't unwrap when you screw the pipe back into the fitting in the wall. Also, make sure the threads in the fitting in the wall are cleaned out, and don't let any debris contaminate the new teflon paste as you slip it back through the hole in the wall. If you find that the pipe out of the top of the valve is leaking, I recommend you call the plumber. He/she can likely fix it without taking the wall apart.
    Aug 27, 2010 | Moen & One Handle Tub & Shower Faucet
    Leaking water
    The o-ring and the plastic insert is broken. They may not have a part replacement, may have to get a new gun. Take the gun apart and you'll see the problem.
    Jun 18, 2009 | Karcher K2.26 Electric Power Washer
    Water leaks out at water pump and i just replaced the o-ring
    you may have cut o ring when you replaced. coat with vaseline next time before assembly.
    Apr 10, 2009 | Karcher 2500 PSI Pressure Washer
    Black & Decker BDP2600 Gas Powered Pressure Washer Logo
    788 people viewed this question
    Top Black & Decker Garden Experts
    Jim Parker
    Jim Parker
    Nick Olsen
    Simon Elder
    Level 1 Expert
    Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
