Question about Uniden Lands Phones
Phone rings once and hangs up on the caller
It is all pretty much in the subject line but the additional information is that we just tried to change the number of rings from 4 to 6 before the answering machine picks up.
  • mark119 May 10, 2009
    I have exactly the same problem. The incoming call rings once then hangs up.
    We got a bit of static or line interference the day before. Intermittant problem.
5 Suggested Answers
SOURCE: New GE Model 28821 Answering System HANGS UP after greeting announcement! HELP?! ;P
Posted on Dec 18, 2008
  • 11 Answers
SOURCE: Caller display not showing
you have to go on phone settings or call settings and it has an option for caller id on or off
Posted on Mar 20, 2009
  • 95 Answers
SOURCE: uniden cordless phone 900 MHz
A phone uses a voltage drop to determine when it is answered or hung up. What is happening in your case is the phone or base unit, or worse yet the house wiring has a short to ground somewhere. This also cause the static you hear. You can get a regular phone and plug it into the same cord and see if it works normal. If so it is not the house wiring but the phone or base unit. If so you can only hope to find the short yourself which is very time consuming and difficult on modern digital units. Sorry to say it's cheaper to get a new unit than pay for repair. The only other thing that cause those symptoms is the batteries are going dead. I assumed you checked this first. If not you can try changing the battery pack on the phone.
Posted on Mar 28, 2009
SOURCE: phone won't ring with incoming calls
I just bought a new Uniden DECT 6.0 phone and had a similar problem. It wouldn't ring when plugged into my Linksys voip router, but my old 5.8 GHz did ring. It would get a dialtone and make calls, but when called via an outside line, it would appear as if it was ringing. If I picked up during this "silent ring," it would answer and take the call. It wasn't a ringer volume issue. I called tech support, they said on the main headset, unplug the battery, then unplug power from the base, then unplug the phone cord from the base. Wait 15-30s. Plug the phone cord, then power, then reinstall the battery. Press the End button on the phone. Put the phone on the base for 15-30s. Pick up the phone. Press and hold the Find button on the base. Do this Find thing 3 times. Put the phone back on the base. Wait 10-15 minutes. Then try calling it to see if it rings. Worked for me, finally got it to ring before I decided to return it.
Posted on Jan 13, 2010
Change number of rings on uniden phone model exi 8560
The EXI8560 isn't an answering machine. It will continue to ring until someone or some answering machine picks up or the caller hangs up.
To change the ring count on your answering machine, consult the documentation for that answering machine. If you require further assistance, please add a comment to this question and specify the make and model of your answering machine.
Jan 14, 2014 | Uniden EXI8560 5.8 GHz 1-Line Cordless...
Caller id not working on only 1 phone
It's a good bet that that telephone doesn't ring therefore the system won't pass on the caller id information.
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
May 26, 2010 | Avaya 700340193 Corded Phone
After I answer the phone and I hang up the phone will ring again
hi, it could be that whenever service comes(network) thats when it does like that..because i use to have a phone like rings once to indicate service(network) is it to a place that the service is FULL..
May 18, 2010 | NorStar Meridian M7310 Phone
Lucent Partner 18D - Caller ID not working
The caller id information is sent from your local telco provider after the first ring and might not be able to be extended to the individual sets, try backing off the ring to answer on your voice mail from 2 to 3 rings to see if the information is then passed on. The Voice Messaging System message is being sent from the system showing who transfered the call to you. You should also notice that the ring pattern when that message is displayed is a standard ring followed by a beep meaning a transfer is taking place.
Nov 20, 2009 | Lucent PARTNER18 Corded Phone
Auto-answer issue: fax beeps on line when voicecall received
Try changing the receive mode from automatic to FAX ONLY and set the number of fax rings higher. You should be able to receive phone calls and if you are not answering your phone it will automatically receive a fax.
Mar 27, 2008 | Office Equipment & Supplies
Not sure it this is a solution for ALL your problems, but...
I had a similar issue: Phone rings, caller ID info displays then seems to hesitate, then displays only "INCOMING CALL."
The issue seemed to be caused by interference with other devices on the same line (in my case, an alarm system).
Tech support had me change a setting on my TRU9466 base unit (this is one of the PowerMax 5.8ghz models). This is how we did it step-by-step on the base unit:
select LINE 1
switch to TYPE B
This seems to have solved the Caller ID "interference" issue -- my Caller ID now displays as it should. The Tech Support person suggested trying that TYPE A/TYPE B setting on "OFF" if TYPE B didn't solve the problem, but thankfully, it did.
Now Cheryl, it sounds like your issue is more involved than this -- I didn't have any connection problems -- but perhaps they're related -- you might try my solution.
Mar 07, 2008 | Uniden 5.8GHz Cordless Phone
KX-TG6071M 5.8 GHz talking caller id not working
Hi trinigirl, You should not have to do anything to make the caller id information come through. There is no programming to perform for the regular caller id identification on your display after the second ring (it takes at least one ring cycle for the digital information to pass through). Your model also has the talking caller id function, which will announce in English the callers name or a custom name you can prepare in the phone book of handset number 1. With all that said, you are not getting caller id showing after the second ring, then your phone is bad (which is pretty rare for this symptom), or your phone line still does not have caller id activated. To troubleshoot your problem you need another phone line with working caller id and/or a different phone that is known good to pass caller id. That way you can interchange the phones/lines to see if it is your line or your phone. My guess it is your line somehow, though I have fixed phones that won't pass caller id, but rarely. If it is your phone, try rebooting it, thats about all you can do short of sending it in for repair. Let me know how it goes. CG
Feb 19, 2008 | Panasonic KX-TG6071M Cordless Phone
Caller Id
Try changing the cord between the base unit and the phone jack. Some phones are pretty fussy about this, and when they are, it's usually the caller ID information that gets clobbered. Alternatively, try attaching the base unit to a different phone jack - preferably the jack with the shortest wiring run to where the phone service comes into your home.
Jan 29, 2008 | GE 28112EE2 Cordless Phone
Message Bank
You may have activated a "Caller tune" or "Ring back tone" service. Check with your service provider to deactivate the tune.
Apr 05, 2007 | Motorola Mobility RAZR V3
Lands Phones Logo
646 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
