Question about Intel D845GVSR Motherboard
Not booting Was given an intel d845gvsr motherboard with its original emachines base unit -motherboard had failed. Now on my 2nd replacement from eBay & same problem. Green light comes on but no response when power switch pressed. Have checked other components in a working P4 system - cpu, memory, psu, cpu fan, on/off switch, power cable & all o.k. Tried mobo with and without securing screws, in and out of case. Have also tried clearing cmos, starting with only the essentials (cpu,memory,fan) but still nothing. Am quite experienced & have done several successful mobo replacements in the past, know how to safeguard againt esd etc. Any suggestions? Does this board have some kind of safety cut-out & if so, how do you reset it? thanks, Mike.
  • Senor Speedy Jun 01, 2008
    thanks for your reply. Yes, tried it with a different psu;also checked the emachines psu with a different m'board and works o.k.
  • Marty marty May 11, 2010
    have you verified a good PSU and mobo together? emachines are notorious for bad psu's.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 262 Answers
I think it could be one of two things either on off switch is bad or
useing to light of a power source try a 450watt power conductor.
24/4 connector and try replaceing power switch .lala linda
Posted on Jun 02, 2008
E-machine T2984 Motherboard replacement
The eMachines T2984 uses an Intel D845GVSR motherboard,
http://www.ebay.com/itm/Intel-D845GVSR-Socket-478-Motherboard-Warranty-/261132348848?pt=Motherboards&hash=item3cccb36db0
Just one example from a quick search.
http://www.intel.com/support/motherboards/desktop/d845gvsr/sb/cs-008823.htm
The above is the motherboard manual -
Intel Desktop Board D845GVSR Product Guide (PDF)
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 24, 2012 | Computers & Internet
I want vga&sound drivers for 3260
The eMachines 3260 is a UK model. I don't see driver download support at the UK site.
However the eMachines 3260 uses an Intel D845GVSR motherboard. Let's go to Intel Support, and see if the graphics, and audio drivers are available;
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22Intel+Desktop+Board+D845GVSR%22
On this page select the Operating System you are using. I am going to use Windows XP, as an example. (Home Edition or Pro Edition, doesn't matter)
Shows 7 drivers.
Among them are;
1) Intel Extreme Graphics Driver for 845 Chipset-Based Intel Desktop Boards
2) Audio: Realtek* AC97 Audio Driver
Download AND install these two drivers.
Post back in a Comment.
Regards,
joecoolvette
Jan 21, 2012 | E-Machines eMachines Desktop PC
Fan Speed 100% on Intel D845GVSR motherboard
see if you plug them in the right spot cpu gose by the cpu case fan will say case on board some take two wire fans some 4 wire some 3 wire jim
Feb 20, 2010 | Intel D845GVSR Motherboard
D845GVSR motherboard replaced but PC won't boot
please check your RAM if it is compatible in your new motherboard.. go check the manual of the board you buy.. or visit the website of your new motherboard.. cheer. ^^
Feb 16, 2009 | Intel D845GVSR Motherboard
BIOS problem with D845GVSR
you don't want the cd to be master,You want to change boot order and make cd,first boot.
Jan 20, 2009 | Intel D845GVSR Motherboard
Motherboard won't boot
u can go to ur mb bios nd check ur processor setting.may be 845gvsr not support intel crl processor.u can give load bios default from ur bios press F6 or F7,
Sep 19, 2008 | Intel D845GVSR Motherboard
Emachines D845GVSR motherboard repair
your i/o controller ic {SMSC} fail or rtc circuit fail there is two most possibility
Apr 01, 2008 | E-Machines eMachines Desktop PC
Intel D845EPI/D845GVSR MB problem
if you can get past the POST properly and see the drive size, nothing is wrong with the drive hardware. I think XP is seeing a previous boot sector install so try first to fdisk, format and system boot the drive. This should remove any boot sector "shadows".
Dec 26, 2007 | Intel D845EPI (INTELKD845EPILPAK10)...
Intel D845GVSR Motherboard Logo
121 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
