Question about Cameras
When connect to pc with usb no function - Cameras
    Brigadier General:
  • 11,967 Answers
Try using a separate card reader instead of the camera.
Posted on Oct 11, 2010
I cant install printer usb port is damage
Which USB port Damage because there are two USB port available.
One is Printer USB port or Sec is PC USB port.
If you are say PC USB port not working first you check it USB driver installed or not, or USB connect to motherboard or not. PC there are two side USB available one is front side and sec is back side. You connect only back side, because this USB connect to main board. So you connect only back side. If not working removed driver or installed driver.
Or if you are say printer USB then change cable or port or not solved only change option.
Read More Help.. If you have USB or Network Printer and are having trouble printing and HP Tech Support
Jun 27, 2014 | HP PSC 1315 All-In-One InkJet Printer
Mp4 player not working
Check your MP4 player's system requirements.
Some MP4 players are only capable of working with certain operating systems and hardware, so refer to your player's documentation to ensure it is capable of functioning with your PC.
Change the USB port your MP4 player is connected to if you have confirmed your PC can function with your MP4 player.
Disconnect other USB devices, and try connecting your player to another USB port if you are still having problems.
Try restarting your PC if it is capable of working with your MP4 player.
Restarting your PC resets non-functioning USB ports, which may be your problem.
Make sure your USB cable is connected properly.
If your player requires you to install drivers, make sure you install them.
Try connecting your player to another PC to see if the new PC recognizes it.
If it does, chances are your computer does not support the hardware necessary to run your player.
Reset your MP4 player if your PC is still unable to recognize it.
Resetting your player varies depending on the manufacturer and model, so refer to your player's documentation.
Contact your player's manufacturer if you are still unable to get it to work with your PC.
http://applestore.altervista.org/mp3mp4.pdf
Aug 25, 2013 | Intel Computers & Internet
I cannot download pictures from my LG Neon gt365 to my computer. What do I need to do? Do I need a USB? Do I need a micro SD? If so, what kind do I need? any help would be great!
You should be able to connect it using a usb cable that will need to be bought separately and a micro SD card installed in the phone. You should be able to buy any micro SD card up to 4GB. Also, if you buy a card with an SD adapter that will allow you to connect the SD card (with a memory card reader) to your computer without the additional usb cable. The manual link is attached: http://www.tmoatt.com/uploads/53/LG_Neon_GT365_UG_English.pdf
Per the manual:
Transferring Music from the Digital Music Service 1. Using your computer, open your preferred PC music management client. 2. Download the selected song to your library. 3. Make sure the microSD™ card is inserted properly into the handset. 4. Use the USB adapter cable to connect the handset to the PC. When you try to connect handset on your PC, the handset displays "Call and Message functions will not be available while connected to USB". 5. Once the USB connection has been established, the handset displays "To avoid data corruption always carry out safe removal hardware on PC after use." and the computer screen then shows the LG NEON device. If the detection does not occur, skip to Changing USB Connection Settings section on page 63. 6. Follow the instruction in the program to transfer music to your handset. n Note If you have a USB hub, connect the handset directly to your computer rather than through the hub. Transferring Music using Windows Media Player 1. Open Windows Media® Player on your computer (version 10.0 or higher). 2. Use the USB adapter cable to connect the handset to the PC. When you try to connect handset on your PC, the handset displays "Call and Message functions will not be available while connected to USB". 3. Once the USB connection has been established, the handset displays "To avoid data corruption always carry out safe removal hardware on PC after use." and the computer screen then shows the LG NEON device.
Jul 23, 2011 | Cell Phones
Can't connect front USB ports. I need the blueprint of the mother board
The story of compaq presario desktop computers. Apple computers invented compaq presario as hrybrid computer displaying the fuctionalities of microsoft windows desktop computers. Presario has the circuitry of apple only similarity is windows display format in programs. The presario desktop has every feature like USB connectivity only requires an APPLE update softwares before compertibilty functions are achievable. Acquire the software patches from www.apple.com to complete USB function connectivity.
Dec 20, 2010 | Compaq Presario 7000 (470004-759) PC...
How to connect usb cable to pc htc mobile
you need to download and install a software call ActiveSync XP 4.5
Aug 07, 2009 | HTC Touch P3450 Smartphone
Cant connect wireless
If the stick is the solution, why are you avoiding the solution?
From what you have said, the internal wifi in the Evo doesn't work, while
an external usb stick does.
Assuming that your internal wifi is properly configured and functional, it is
incapable of picking up your home wifi signal, though it might be functional in other situations ... Buying an external usb stick gives you a better antenna position and takes nothing away from your system, while adding functionality and sheilding the innards of your system from viral
attack as a first line of attack that is detachable.
Buy the USB stick.
Bue
Apr 14, 2009 | Compaq Evo N600c Notebook
Usb not working
Check that all the USB ports are turned on in the BIOS setup.
Apr 02, 2009 | PC Chips (M925G) Motherboard
T-mobile dash problem
ActiveSync 4.x utilizes a network type of connection with Windows Mobile
powered devices, since this allows faster data transfer than a serial USB
connection. When the PC is connected to the Internet or a local network,
in some cases, the PC may disconnect the ActiveSync connection with
your phone in favor of the Internet or network connection. If this happens,
select Start > Settings > Connections > USB to PC and clear the Enable
advanced network functionality
check box. This makes ActiveSync utilize a
serial USB connection with your phone.
Jan 13, 2008 | T-Mobile Dash Smartphone
Problem with my usb connection
Start-Setting-Connections tab-USB to PC then clear the Enable advanced network functionality check box. This makes your PC utilize a serial USB connection with your device. The USB to PC icon appears on the Today Screen when serial USB connection is used.
Hoping this will help your problem
Nov 24, 2007 | T-Mobile Wing™ Smartphone
Cameras Logo
22 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
