Question about Hotpoint BWM12 Front Load Washer
Door locked and handle broke
My machine is locked i cant open the door. I am assuming there is a spring mechanism behind the handle when you pull it to open it but that seems to have broken - i have spoken to a local repair shop and they need me to bring in the door to fix it but i need to get the door open and then take it off - Any suggestions?
Same thing happened to me,
if the leaver is clean broken off,. get some thin wire,. i used Bell wire, loop it around the Hook, in order to pull it,. use a flat screwdriver to pull the sping back then pull on the bell wire,
it is pretty tricky to loop the bell wire around the Hook,. be it can be done, u will need a pair of long nose pliers,. to grip the bell wire and pull it thru in order to complete the loop,
the leaver can be bought from Hotpoint, the door frame is 10£ odd,. either way u can fix it ur self for under 15£ max,.
Posted on Aug 02, 2008
Interior driver side door handle does not open the door and doesnt lock.
remove interior door card and inspect door handle rod to lock mechanism make sure it is connected both ends
Oct 06, 2015 | Cars & Trucks
Front right door locked cant open to take panel of to see what the problem is. Got central locking which still works on all the other doors but the door at drivers side is locked and wont open.
can you still put the window down ? if you can ( or sometimes if you cant ) you still might be able to straighten a metal coat hanger and put a hook on the end . lift the rubber at bottom of the window and you should see the connecting wire from the door handle has come off or broke. use the coat hanger to pull the mechanism yourself. dont look at the inside of the handle,look where it leads to ( should be to the side of the door where it closes ....hope this helps
Apr 24, 2015 | Cars & Trucks
What part do I need? It opens from the inside. The handle is not snapped.
Are you saying the inside door handle isnt snapped,but the door wont open by pulling on the inside door handle or is it the outside door handle thats not working??Both the inside and outside door handle has a spring and other components on the backside of the handle which cant really be seen unless you remove the whole door handle assembly.One of these components are most likely broken or the rod that attaches between each handle and the locking mechanism(part that locks into the door striker to keep the door closed and releases it too)might have come loose from the back of the handle.The outside handle is usually mounted to the door by pop rivets or bolts/nuts.The inside handle is usually mounted with screws,but it really depends on what kind of car youre driving.Youll probably have to remove the handle to inspect it for damage.Open the door and watch the locking mechanism for movement while youre pulling on the door handle.If it doesnt move when you pull on the handle,the handle is definitely broke or the rod has come loose from the back of the handle.
Mar 09, 2015 | Cars & Trucks
The handle broke off the door completely, therefore I cannot open the door of my Hotpoint counter saver plus microwaive oven. What to do please?
Take it to a repair shop you will have to take teh back off the oven and gain access to the door lock mechanism from behind.
Sep 14, 2014 | Washing Machines
The driver side door lock wont go all the way up.
The outside door handle spring is broke ,or the latch spring is broke. The only way to tell is remove the door panel and inspect the rod from the handle to latch. Look for broken spring on handle. I have installed an external spring from the handle rod to latch to keep the rod in the full up position.
Nov 18, 2009 | 1999 Ford Ranger SuperCab
Door handles don't open....
i have the same problem on my 1995 grand prix gtp 2 door coupe...the only differnce is that i had door poppers installed and took off the lock rod, turnes out the solenionds cant pull the latch open, so i need stronger solenoids. but my door wont open either...if anyone has any fixes to this problem let me knows ASAP!! i cant crawl thru the passenger side in the middle of a S. Dak. winter...
Oct 09, 2009 | 1995 Pontiac Grand Prix
Cant open the door on my washing machine
if you can get a small thin metal object in there and jiggle it around, you may get it open. if not, sheet metal panels will have to be removed to get to there. do not smash the glass!
Jul 19, 2009 | Washing Machines
Can't open the kick plate of my samsung j845 washing machine
Happened to me too today. As I was pulling the handle, a piece inside snapped. The handle felt loose, as though it wasn't pulling the catch. To get the door open, I used a screwdriver. I pulled the handle as far out as I could, so that I could get the screwdriver in. The dark black metal part has to be levered away from the washing machine - in the direction the door would open. That will release the catch and then the door will open.
After the door is open, the challenge is to remove the handle. You'll need to undo all 10 (or so - from memory) of the little screws, so that the inner part of the door comes off. Be careful as you get to the last one - things will fall away. The handle and the small broken tab just fell out for me. Once the handle is out, you can put the door back together again. I use a small hex key to help open (and close) the door. With no handle, the catch springs a bit too far over for the door to close, so you'll need something (e.g. 1/8" hex key) to hold it over a little. So now, I can use the washing machine while I try to find a new part.
Apr 11, 2009 | Washing Machines
Both front doors on my "93" Corsica won't open.
You have to open the Window all the way And I Assume your looking Down Threw the Glass opening to View the Linkage,
their is a Spring for the Return of the latch, While looking at the Latching system, Look for the Spring that When you "Try" to open the Door it's Suppose to Compress, Most likely the Spring is Not Fully Releasing,
You may try WD40, And work the handles for a few mins and Then Try to Unlock the door for it to open, OR you can Try a LONG Screw drive to Slide the Spring to fully Non compressed state and then Make sure the Door Lock is in the Open State before you try the handles..
Feb 03, 2009 | 1995 Chevrolet Corsica
Indesit W 125 X Washer Handle Broke Off and Door Will Not Open
use something lopng and thing, a thin screwdriver operhaps. Pull the metal bar ( part of the spring) to the left. When this is fully to the left push the white plastic part in and jiggle about util the door comes off. Might be easier with sumone to help you pull the dor out as you uch in
Oct 22, 2007 | Indesit WA 125 Front Load Washer
Hotpoint BWM12 Front Load Washer Logo
93 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
