Question about Miele Touchtronic W1113 Washing Machine
Miele w1113 Dreum made squeking noise. Tech said to replace door gasket and shocks with spring. Replaced parts and it started to smoke after a first spin cycle. Tech says it is either a belt or the bearings need rplacement. If it is the belt - ok, its cheep. They want $925 to change bearings. what is your opinion.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It seems to be the belt that has gone bad and to resolve this it should be replaced. From what you have dont think the bearings and belt both can go bad, you can unplug the washer completely and then try to turn the drum with your hand, if it spins like this then the belt is fine and you need to get the bearings replaced. However, if it wont turn then it is the belt that is bad, $925 is too high for bearings. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 11, 2010
Door on my miele built in dishwasher is broken
First thing you need to do is SEARCH for "spares"
for your Miele G685sc
We don't seem to have "parts" for your G685sc here
in the USA...
but a casual look over BOSCH hinge and spring costs
show the hinge at $20 USD
AND
SPRING at $10 to $19 US Dollars...
Lower door gasket $20 to $30 USD
AT those prices I would attempt to avoid a "new"
dishwasher... When you are done trying to get a HEATER,
silence and stainless interior...
You are looking at BIG MONEY.
Check the FIT of the door... and health of the gasket(s)....
I'm just saying... I would
(it is the ULTIMATE in recycling).
http://www.appliancepartspros.com/bosch-dishwasher-gasket-seal.html
Apr 11, 2017 | Dishwashers
Miele w4840 door rubber seal relacement
i just replaced rubber gasket on miele w4840 it took lots of patience! there is a retaining wire on spring on front part this is easily removed. next there is a light and water line about 11 o'clock take this apart and unhook water line in order to remove these from gasket. next there is a locking wire on right side at 9 o'clock. i was able to get a flat head screwdriver and loosen the screw you can open about 1 -1.5 inch at this point the rubber seal can be removed. you have to carefully (painstakingly) put the new seal on. make sure everything is lined up right before replacing the wires took me about an hour as the gasket is difficult to put on back part on drum
Apr 16, 2012 | Miele W4840 Front Load Washer
G660 door falls open
Hi.
The problem is either because the spring supporting the door half way up is broken or because the spring must be adjusted.
First perform a door spring adjustment procedure as explained at page 28 in chapter 10 of the Installation Manual.
Here Miele installation manual for the G660. The file is in PDF format.
If the regulation procedure does not do the job, then the spring must be replaced.
This video shows how to replace the spring (model and manufacturer are different-operations are similar):
The spring is usually sold as part of the hinge assembly.
To get parts or to book a qualified technician call the Miele support number listed on the owners manual or use the Contact page on your local Miele website. Here UK website: Miele - Contact Us.
Regards.
Ginko
Nov 05, 2011 | Miele 24 in. G638 Plus Free-standing...
Miele w1113. Washer drum won't spin during wash cycle
I assume you are saying the machine is working except the drums not turning? - you need to see if the belt has come off because thats what i would check first if you hear the motor start/stop after it fills up with water.
May 30, 2011 | Miele Touchtronic W1113 Washing Machine
Why dose the water leak out from the Miele Touchtronic W1113 Large Capacity Washing Machine w/ Stainless Steel Honeycomb Washing Drum?
Hi dear.Please check the door gasket for any wear & tear.(Also open the door,ajar inside the door gasket, check inside of it for any fine tear or cut.)Please check for pump filter.Is it attached correctly.I hope that helps.Thanks.
Jun 19, 2010 | Miele Touchtronic W1113 Washing Machine
Help ! I own a Miele Touchtronic W1113. I put to0 much Zero liquid soap , using cold water . Now the machine flashes " Fault " for intake and drain . I opened the trap door and let the water drain over...
Sounds like you may have flooded the base of the unit and activated the float switch. Tip the unit forward slightly with a towel at the base and all the water will pour out. You should be right to run the unit after that and any other water inside will dry up. it won't rust as it is stainless steel inside.
Feb 15, 2010 | Miele Touchtronic W1113 Washing Machine
Smoke in drum on spin cycle
I did it by going to an agent, I do not trust you,,,how do I know that your services are for real? Please do not be offended.
Dec 10, 2008 | Miele Touchtronic W1113 Washing Machine
Back wheel coil spring sqeuking
there should be a shock running in the middle od the spring this is what is squeking not your spring
Dec 05, 2008 | 1989 Mercedes-Benz 190
Miele w1113 alarm buzzer
do you have 3 dashes across the dispaly?? you need to get into service mode to access the fault
Aug 17, 2008 | Miele Touchtronic W1113 Washing Machine
Drsining washer manually
open the little door at the bottom fron and twist open the lint filter clean out
Jul 12, 2008 | Miele Touchtronic W1113 Washing Machine
Miele Touchtronic W1113 Washing Machine Logo
225 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
