Question about Crosley CR248 Turntable
During a recent move all the wires to the needle got pulled off and need to be sodered back on but I do not know which wire goes where. there are 4 wires
  • Crosley Master
  • 5,391 Answers
With the amp on touch each wire with your finger one at a time. One will buzz on the right and the other on the left, these are the channels. The others are the earths. Put one of the channels on one side and the other on the other, then connect the earths. Try it it out. If the sound doesn't sound right reverse the earth and channel connectors. You will also need a record where you know a voice or instrument is on the left or right to make certain you have the channels the right way round.
Posted on Oct 12, 2010
The automatic threader wont pick up and thread needle. Can do manually but thats not easy?
to make manual threading of a needle easy buy a needle threader
it is a instrument that has a very fine piece of wire in a loop that you push through the eye of the needle , put the thread in that loop and pull the loop back out of the eye and the needle is threaded
available from most any shop that sells material , cotton , thread or sewing machine shops
cost --pack of 2 for $1.00 or there abouts
Oct 05, 2016 | Sewing Machines
Is there a diagram for my kelvinator chest freezer? i need to repair a wire that fell off during our recent move
If the wire is green it's a ground wire and can be attached to any metal screw that is near that area
Jun 11, 2012 | Freezers
Sanyo 24 in flat screen model DS24425 Screen slowly goes fussy and slowly goes black , a slight tap on the rear left side brings the picture back to good screen,for a few minutes or a couple of hours no...
Hello
Your flat panel TVs picture tube base board has soldering loose contact with it. Just unplug your TV from AC mains socket, and open it. Pull out the picture tube base card from the picture tube neck. Pull it out straight, no shake must be there, as it will damage its connecting pins.
Normally, loose sodering are very difficult to loacate, as they will be quite micrscopic in size. Just resolder all the suspected loose sodering point on that board, by applying a little more solder. This will solve your TVs problem. OK.
May 26, 2011 | Toshiba 55ZV650U 55 in. LCD HDTV
Bosch Dryer front loading: I just recently moved and had to change my 3 prong to 4 prong cord and hooked up to new location. Dryer will not turn on or light up. Checked breaker box 4 prong terminal and new...
sounds like you wired it wrong really. Do you have 120 volts from either outside wire to the center wire on the unit, and 220 to both outside wires if not its wired wrong
Jul 08, 2010 | Dryers
How do i get it out to put new one in
find the offending carb or carbs by pulling float bowl over flow hoses to the side and starting motor, 1 or move hose will be pouring fuel, follow hose to offending carb, unmount all 4 carbs from motor,(unmount tank,1 bolt 2 hoses,2 wires) then (unscew hose clamps from front and back of carbs) next(reomove scew from very top font of air box,near metal cross bar behind fuel tank) then wiggle carbs to separate from rubber intakes,unhook trhottle cables pull carbs out one side(either side of bike) once off turn upside down,take 4 bowl screws out ,remove cover,take out small pin holding floats ,needle will come with it,use the right wrench and uscrew brass seat needle came out of(make sure any rubber o ring come with) reinstall seat &any orings take old needle off float install new one,put needle in hole of seat,pin float put cover back on bottom of carb,re assemble bike.I hope you've maked where everything goes,a little oilon rubber helps with reassembly .
Jul 17, 2010 | 1981 Suzuki GS 750 L
No sound from the speaker output for the standard speakers for a Dell W3201C. Only works from the RCA connections to hook up an amplifier. Is this an easy fix or is it costly
it is an easy fix if you know how to soder all you need is to open the side to get to the broken speaker the wire that goes connected to the speaker fell of just soder it back to the speaker and it will work
Oct 29, 2009 | Dell W3201C 32 in. LCD Television
Pontiac 2003 Sunfire Gas Guage doesn't work
Your needle moving from empty to full and then back to empty indicates that it is trying to set itself (most cars do this each time they are started). So, yes, there seems to be a problem with the sending unit that feeds information to your gas guage. Prior to cracking open your fuel tank, you might try tracking the wires from the back of your guage as far as you can towards the tank. Then track the wires from your tank as far as you can toward the guage. Watch for damaged wires and/or loose connections as you go.
Jan 29, 2009 | 2003 Pontiac Sunfire
Phillips 60" Changing STK392-120 Removing board Model#60PP936H/17
Typicaly you can remove the SSB board on the left without having to remove the flyback wires. If however you are trying to remove the entire deck all at once you will need to remove the flyback wires as indicated.
You do not need to use needle nose pliers. Goto the site www.TvRepairKits.com and click on the "Tips" menu. Under that section you will see instuctions on how to remove the HVG/flyback wires.
Hope this helps,
Dec 13, 2008 | Philips 60PP9352 60" Rear Projection...
Env issue
Sorry, i have been out and you may not need my help any more but here goes.
When you take apart the envy, the speaker will come out and should go back in no problem. If something comes lose like a wire and needs soldering, its tough on those small parts. you will need a small soder gun, a computer tech store might have one small enough. Also get small soder. There alot of heat involved and soder smoke can be toxic if enhaled alot. try in a wel vented garage or outside. Take the phone apart and do it carefully. Make sure not to melt anything else while sodering.
You get better with experience and i would practice soldering a couple of small wires together for practice first so you get the feel for how soder moves when it turns liquid.
I havent had to soder on a cell phone bwefore. If it has some kind of ribbon instead of a wire, then it may not be possible and you may cause more damage trying.
Its cheaper to have the tech insurance,it has a $50 deductable, just copy all your numbers and files onto the Micro SD, then drop in water, take to verizon and bingo, new one for $50 bucks
Good luck
Oct 23, 2008 | LG enV VX9900 Cellular Phone
I can't hear through my internal or external cb speaker
Can you hear static when the squelch is at minimum ?. If you can hear static then tere is nothing wrong with the audio system. If you are sure about the squelch, connect goosd speaker directly to the 2 wires coming from the main board bypassing the speker jack. if there is still no sound then the audio amp chip is defective. The audio amp can only be damaged if the output is shorted for a long period of time.
Mar 02, 2007 | Uniden PC78ELITE 40-Channels Base CB Radio
Crosley CR248 Turntable Logo
301 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Sam Palermo
Sam Palermo
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
