Question about RCA P52926 52" Rear Projection Television
Top third of picture is distorted, kind of wavy or out of proportion while the bottom two thirds appears to be fine. Also when you first turn the set on the picture is only about one third of its height in the middle of the screen. As it is on the picture gets taller but when it gets to full height you see a horisontal line above is wavy below is fine. What is the cause?
  • 4,889 Answers
Sounds like a problem with the horizontal/vertical deflection circuit. Can you please upload an image to an imagehosting site like imageshack.us and get me the direct link?
Sai.
Posted on Oct 11, 2010
  • eagle338
    eagle338 Oct 11, 2010
    Take a picture with your camera while the tv is on and upload the image to imageshack.us. You can then get me the direct link.
    Sai.
  • eagle338
    eagle338 Oct 12, 2010
    It is definitely a problem with the HOT and/or deflection circuit. It is recommended that you replace both the deflection IC and HOT . Then look for anything that may have caused the overload that blew the ICs in the first place ex: Faulty resistors, blown caps. This is gonna require considerable amount of electronics and soldering skills and I would recommend that you seek the assistance of a qualified tech if you do not have these.
    Sai.
Distorted picture with wavy lines..
SOUNDS LIKE A CAPACITOR GOING DOWN ON BOARD OPEN BK LOOK FOR BULGING HEADS
Sep 28, 2017 | Sony Grand WEGA KF60WE610 60" Rear...
There is a blue wavy line from the left top to the middle of the top of the screen. The area above the line is yellowish. Below the line the images are clear until the bottom third where everything has a...
Convergence ICs have failed. The Sony type 1 convergence repair kit available from www.tvrepairworld.com is the correct kit for your model. The kit contains the parts and the CD with instructions.
Jul 16, 2010 | Sony KP-46WT500 46" Rear Projection...
Wavy picture on top and bottom
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 29, 2010 | Sony KP-53HS30 53" Rear Projection...
I dont know how to turn camera on
Q: Camera Usage Instructions
A:
For use with systems including an Acer Orbicam, CrystalEye, or other factory installed camera.
Taking still pictures
  1. Double click the Orbicam Icon to start the program, which will open the main application screen.
  2. Set the configuration choices by clicking on the "gears" icon, which should open an additional window that slides out. Clickthe tabs and select the options for the desired settings. By default, still pictures will be sent to the "Pictures" folder.
  3. Set the resolution for still pictures by pressing the arrow under the main display. A drop down menu should appear with the available resolutions. Larger resolutions will result in larger file sizes.
  4. To take a picture, align the subject in front of the camera so that the display appears in the window as desired. Click Take Photo.
  5. The pictures should appear along the bottom of the application window if the Gallery view is enabled.
Recording video
  1. It is suggested to find a third party application to use this functionality.
Using the camera as a webcam
We cannot support third party application configuration or use.
Feb 18, 2010 | Acer Aspire 5315 15.4-inch Notebook PC
Wavy picture with blue and purple color.
Projection TV sets have two very common problems listed below.
*Screen Looks 3-D
*Colors wont align
Jan 09, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Why did my picture become big so I can not see the sideline information
Press the RATIO button repeatedly to select the desired picture format. You can also adjust Aspect Ratio in the OPTION menu.
  1. Set By Program. Selects the proper picture proportion to match the source’s image. (4:3 → 4:3, 16:9 → 16:9)
  2. 4:3. Choose 4:3 when you want to view a picture with an original 4:3 aspect ratio, with gray bars appearing at both the left and right sides.
  3. 16:9. Choose 16:9 when you want to adjust the picture horizontally, in a linear proportion to fill the entire screen.
  4. Horizon. Choose Horizon when you want to adjust the picture in a non-linear proportion, that is, more enlarged at both sides, to create a panorama view.
  5. Zoom 1. Choose Zoom 1 when you want to view the picture without any alteration. However, the top and bottom portions of the picture will be cropped.
  6. Zoom 2. Choose Zoom 2 when you want the picture to be altered, both horizontally extended and vertically cropped. The picture taking a halfway trade off between alteration and screen coverage.
  7. Cinema Zoom. Choose Cinema Zoom when you want to enlarge the picture in correct proportion. Note: When enlarging or reducing the picture, the image may become distorted. You can adjust the enlarge proportion of Cinema Zoom using D / E button. The adjustment range is 1~16.
Oct 18, 2009 | LG 42LC2D 42 in. LCD HDTV
Wavy lines appear across the screen
*Screen Looks 3-D
*Colors wont align
May 01, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Bad color and picture
*Screen Looks 3-D
*Colors wont align
Jan 02, 2009 | Hitachi 50UX57B 50" Rear Projection...
Partial tv picutre
By distortion do you mean that the top part is stretched? If so, you have bad caps in the vertical circuit. If you are comfortable working inside hte set and can solder, you can fix this yourself. Please post the model number and I can give you the details.
Dan
May 28, 2008 | Televison & Video
MODEL NO SP42W4HB PICTURE DISTORTED TOP AND RIGHT SIDE COLOURED SHADOWS COLOURED WAVY LINES TOP THIRD SCREEN PINK AND GREEN
This is most likely a convergence problem. You should see 2 large black ICs in side attached to a heatsink. They will be marked STK392-010. Try resoldering the pins on these ICs first. If that does not resolve the problem, replace them. These parts will be about $20 each.
Keep us posted.
Dan
May 28, 2008 | Samsung Televison & Video
RCA P52926 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
