Question about Hayden Industries SuperVac 6000 Central System Vacuum
I have a hayden 202 super pack deluxe head. The motor is turning fine and the brush is rotating but is vibrating badly. How do I take apart cover to look at belt. It sounds like motor is loose. thanks
3 Suggested Answers
ThinkVacuums
  • 144 Answers
SOURCE: I need the manuel for the hoover steamvac deluxe 5
http://www.vacshopusa.com/pdf/hf5837900.pdf
Here is the schematics
Posted on Aug 14, 2009
  • 147 Answers
SOURCE: the brush on my hayden
First you will want to remove the light cover. this can be done by pusing as you look at the front of the powerbrush on both the left and right side of the head.
There you will find the lightbulb and 2 screws to remove. Remove both of the screws and turn over to pry with a screwdriver at both the sides of the powerbrush to remove the top cover.
Once you have the lens cover off you will also see in the plastic the belt change instructions.
When you want to put the top cover back on, it will act much like a hinge, hook it on to the front of the head where the brush is, and snap it back into place at the back.
Posted on Nov 04, 2010
The turbo tool for pet hair on my Hoover power vac doesn't rotate. I removed the brush and cleaned but still doesn't work. Suction is fine without the tool attached.
Have you checked the drive belt on the pet head? Mine comes apart and a thin belt is driven by the propellers which in turn drive the brush head via the drive belt. To check turn propeller and see if brush head rotates if not belt missing broken / jammed
Oct 21, 2017 | Hoover Vacuums
How to get into Hayden super pack delux vac unit
Are you speaking about the Power Nozzle? If so, you need to remove the head light cap. It has clips on each side. Using a small flat head screwdriver gently pry the light cover off from the sides.
Now you will see two screws. Remove those screws. Now you need to pull out on the sides of the cover while hinging it from back to front.
That is it. There is the motor, belt and electronics.
To reassemble, just revers the steps.
May 23, 2014 | Hayden Industries Vacuums
Hayden supervac
There are end caps and you can replace them. You will need to expose the brush bar/ beater; and remove it. Dig out the end caps and replace with exactly the same type. If you inspect the so called bearings, you may find matted up material that caused the stoppage. Clean and retry the system before getting a set of end caps.
Apr 03, 2014 | Vacuums
Need to replace belt and cannot figure how to take it apart to get at the belt --- Took Screws off on the bottom but could not get to the belt
You have already removed the screws so lift the brush cover off. Then grasp rotating floor brush at both ends and lift. Clean strings,hair and other debris from rotating brush, paying close attention to the brush ends. Clean the debris from motor pulley and drive belt areas.Grasp old drive belt and remove from motor pulley. Place new drive belt over motor pulley and stretch other end over rotating floor brush in the space between the bristles. Place the ends of the rotating floor brush down into slots on the sides. Turn the rotating floor brush by hand several times in the direction of motor pulley. If installed properly, drive belt will center itself on rotating brush. Reposition brush cover and screw back into place. I hope that this helps you!
May 26, 2011 | Bissell 3591 CleanView Bagless Upright...
Now that I just fixed my Lux Legacy canister vacuum, I need help on my other Electrolux Regency Series upright! The vacuum works fine but the rotating brush does not work and the brush motor does not turn...
There are a couple rectangular holes on the bottom of the power nozzle, beside the wheels. These have tabs in them that need released with a standard screwdriver.
rogerpotts_10.jpg Once they release, turn the vacuum over and lift cover of power nozzle at the back. This pulls the front of the cover out of the lip on the "bumper".
Once this is done, you'll need to unscrew the screw at each end of the brush. Lift the brush out and thoroughly clean it, including the ends.
Check the wiring to make sure they're connected to the terminals of the motor. Also, check the belt for wear and tear. These belts can last for five years or more, but if it looks bad a good time to replace it is while you have the power head apart.
When reassembling the vacuum, ensure the belt is fitted properly around the motor shaft and brush.
Insert the front of the cover first, ensuring the edge fits neatly beneath the lip on the bumper all the way around. It takes a little manipulating to press the back into place. Make sure both tabs click into the locked position. Turn the vacuum over and reinstall screws. Try to rotate brush by hand a few times.
At this point, plug the vacuum in and turn it on. If the power head doesn't run, press the reset button. If the power head motor still doesn't run, it could be due to loose or disconnected wires that lead to the reset switch, a bad reset switch, or even a bad motor. The vacuum needs to be taken to the nearest Aerus Electrolux store for further diagnosis and repair.
http://www.aerushome.com/storelocator/
Jan 09, 2011 | Vacuums
The brush on my hayden 6000 supervac is not rotating when power is on and i can't figure out how to open the vac to get to the belt. help please
Nov 04, 2010 | Hayden Industries SuperVac 6000 Central...
I have a built in vacuum with a Hayden Deluxe Superpack carpet nozzle. The vacuum works but the Superpack power nozzle does not turn on. Reset does not work. Are there steps for troubleshooting, or...
Find a local vacuum repair center. Could be a short in the hose. The PN could need a new motor or circuit breaker. It will be cheaper to repair than replace, but check the hose for current at the handle end.
Jul 02, 2010 | Hayden Industries SuperVac 6000 Central...
The head on my canister vac vibrates, smells and makes a bad sound. When I took it apart the inside of the "end brush tufted" piece had bits of the plastic broken off. Should I replace the Agitator Unit...
If you are talking about the end cap is broken off the agitator, I would replace the agitator. you can check the motor by turning on the vac without the roller installed.
Oct 24, 2009 | Vacuums
Odd noise coming from central vacumn cleaner
The rattling noise, will likely increase when the head is flipped upside down. Generally means you have a stone caught in the belt or a blown or stripped tooth on the belt.
If you gently squeeze the outside edges of the light housing it will pop off to reveal two screws to remove the lid. Check for other screws at the neck of the power head. Once removed your belt and brush will be visible. Remove the brush roll with end caps and flip the belt inside out rolling it between your finger , look for cracks or a floppy or missing tooth. Replace if any sign of wear.
Inspect the dust caps on your brush. There is a washer under each, likely buried in lint. Do not lose as these are a spacers for each end of the brush. Clean shaft and lube with WD40. Spray caps with the same. vacuum loose grit and dust bunnies away from motor and reinstall, your red button must align with the lid when replacing
Jul 19, 2009 | Hayden Industries SuperVac 2400 Central...
Bissell upright vac, brush on bottom does not rotate
The front brush motor will not engage until the power is turned on and the handle is in the down position. In the upright position the brush motor wont engage. Typical faults will be the belt is broken and needs replacing or the fornt brush motor needs replacing.
May 21, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Hayden Industries SuperVac 6000 Central System Vacuum Logo
151 people viewed this question
Top Hayden Industries Vacuums Experts
Are you a Hayden Industries Vacuum Expert? Answer questions, earn points and help others
