Question about Grilling
Jenn-Air grill half burner issue
I have had my Jenn-Air grill about 3 years. I go to turn on the grill for the first time this spring and the left half of all 3 burners light but the right side stays unlit. What could be going on?
  • 1 more comment
  • Anonymous Jun 10, 2008
    i have a four burner jenn air lp gas grill.If I turn on more than two burners all burners go out. Anybody have the same problem.
  • Anonymous Jun 29, 2008
    I'm also looking for any solution that will fix this.
  • hacksaw582 Apr 27, 2009
    I have a five burner Jenn Air grill. Only left side of each burner lights now. Grill is about 3 years old.
Re: only one side lighting, it is a problem with the cross over **** that carries the flame from one side of the burner to the other. It is located at the rear bottom of the burner and is probably clogged. Wire brush them to clean; failing that, replace with new ones and keep the new ones cleaned with a wire brush regularly.
Posted on Jun 12, 2009
Clean your venturi.
Posted on Jun 30, 2008
Hi There, I have a Jenn Air Gas Grill that I purchased at Lowes with a lifetime warranty. My Model# is 721-0336. We need 3 new burners and two small spacers that go between the burners.
Hi, you have to contact Clagrill on 501-821-4050 to request for your parts. I think they have a free shipping policy within the US.....
Aug 29, 2010 | Jenn-Air Grilling
Flare behind temperature knobs on jenn-air gas grill
This seems to be a problem for most Jenn-Air users. The burners are defective, rusted or clogged and allowing the flame to "back up." You most likely have a melted electronic ignitor as well as gas valve damage. The new burners that I received this week for my model 720-0061-LP are 1/2 inch shorter than previous versions. Time will tell if this fixed the problem. I would call Nexgrill and get all new burners and inspect the gas valve area for damage. Since 2004, I am on my 5th set of burners, glad they were free since I have a lifetime warranty on my model.
Apr 17, 2010 | Grilling
Jenn Air grill burners only lite on one side
It could be a bad regulator but,highly unlikely . Check your air shutters at the end of the burner tubes and adust them properly.And if you have a OPD propane tank you maybe turning it on to quick causing the check valve inside the gas valve to open half way. Try opening the valve slowly.
Oct 31, 2009 | Grilling
How do I adjust the flame to burn hotter or more.
There are adjustment screw at the end of the burner tubes that allow more or less air to enter the burners. try opening or closing these screws
Jun 01, 2009 | Jenn-Air JLG7130A
Grill jenn-air will not heat past 100 degrees
You need to pull the burners out and scrub open the side feedholes on the burner. These ususally clog up over time reducing the heat available for cooking. Also, sometimes the Gas regulator goes bad over time when left outside for a year or two. A bad regulator will put out less gas as it fails closed.
May 04, 2009 | Nexgrill 720-0234 (LP)
Jenn Air Grill - Gas flow from one valve
I have the same problem. The middle and the right burners will work, but if I light the left side (3rd burner) all 3 go out. pressure is reduced to zero.
Aug 30, 2008 | Grilling
Exhaust fan comes on when burner turned on
The left side is set for your grill. There is apparently a switch under the left side top / front of the cooktop. The aeration tray has a prong on one end that fits into a hole in the front end of the burner basin and activates the switch which stops the fan from coming on when using the burners and allows the fan to run when using the grill. Try switching sides with the aeration trays as one might make better contact than the other.
Dec 01, 2007 | Jenn-Air 30 in. CVG4280 Gas Cooktop
Grilling Logo
604 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
