Question about Western Digital Caviar (wd800lb) 80 GB Hard Drive
Hard Drive Issue
I have a Western Digital 80 gig hard drive. When I turn on my computer it shows up in the bios, and I hear it kick on but I just get a black screen with a cursor. I cant even click F10 for system restore or whatever it shows when it first starts loading. I have windows xp home edition. I have a copy of windows xp professional but was told I have to get my dvd burner to pick up first in the bio settings in order to get it to load. How do I do that. Also when i put in the xp disc and click repair, hw do u no what to repair there are so many options. I just want my hard drive back. Im stuck with a 40 and its a 80
  • 119 Answers
You can access the bios settings at the first boot screen here you have to go to you boot priority and make the dvd Rom drive you number 1 in the list, save and exit bios insert the xp professional disc and re-install window. during this process do not reair you copy of xp home just install the xp professional it will automatically detect and delete the old xp home files without deleting any of your data. But DO NOT formatt otherwise you will lose your data. lease the file system as is. the only catch with this method is that due to the xp home registries being deleted along with it. most of the software which was installed on xp home will be there but not work you will have to re install it.
Posted on Oct 17, 2008
I dont know how to summarize the problem.
It sounds like the hard drive is bad. You might be able to run chkdsk (or whatevers its called; check disk) to scan/fix errors if possible.
A different issue but:
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 16, 2010 | Western Digital Passport WDXML800UE...
Western Digital (wd5000co32) Not recognize by windows xp
is it ur western digital external or internal and you use a converter to connect it as external
Jun 09, 2009 | Computers & Internet
320 GIG Hard Drive now thinks it is an 80 GIG hard drive
Enter your BIOS setup and check what the BIOS sees for hard-drive. It may not be assessing the drive size correctly so you may have to force it by manually entering the data it needs to see the drive.
May 23, 2009 | Western Digital (WD3200JS) 320 GB Hard...
I just purchased a 320 gig hard drive and when i set a partition it only shows 132 gig
Use the WD data life guard disc to partition the drive. Put the disc in, reboot the computer, and run data life guard. A screen comes up and asks if your system can recognize a partition greater than 137 gb. If your system can read larger than 137, then use the option to format one large partition.
Some OS cannot read larger than 137gb. Also some Bios have the same problem.
May 01, 2009 | Western Digital 320GB Internal Serial ATA...
Syntax SV266A Motherboard Hard Drive update
i,d suggest an 80-120 gig hard drive should be sufficent.
if you require larger drive storage. you can add an external hard-drive via USB upto 500 gig usually without restriction.
You can also purchase An PCI Card, with sata connectors. should you wish to take that option. all the above is dependant on how modern your computer system/systems bios Is.
Mike @ Compurepair.
Mar 25, 2009 | Computers & Internet
Western digital passport essential harddrive 250 gig
It assumes that the drive C is the drive you booted from or the "root" drive. You must make it something other than "C". Try putting in a camera card, hooking up an external drive or other device that the computer makes drive "C" THEN hook up your passport. It will be "D" or "G" or something other than "C" and it will work.
Oct 24, 2008 | Western Digital Passport WDXML800UE...
120 gig Western Digital black no longer mounts on LEOPARD osx 10.5 grrrr
i have the same problem.
macbook doesn't see anymore my hdd western digital 2,5'' white 250 GB.
tried disk warrior, disk utility but nothing.
it's just seem disappeared, even if i hear it works inside (and the led light is on)
what can i do?
May 10, 2008 | Western Digital Passport WDXML800UE...
WD Portable Hard Drive Not Coming On
open it it up take out the hard drive, purchase a USB hard drive enclosure and install the drive. hopefully the drive is still good and spin up
hope this helps
Jan 07, 2008 | Western Digital External USB 2.0 80 GB...
Problem maxtor hard drive
What type of Computer are you installing this 80g drive on? How old is it? I need to know some specifics, because in older machines the BIOS are not setup to recognize large capacity HD, in addition you may have recieved a bad Drive. Please advise! I may have an answer for you!
Nov 26, 2007 | Maxtor Hard Drive
Western Digital Caviar (wd800lb) 80 GB Hard Drive Logo
142 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
