Question about Apple iTunes
Cant't run itunes. keep getting err#2096 quicktime was not found when qhicktime is downloaded
    President:
  • 2,291 Answers
ITunes.exe has been set to run in compatibility mode for an older version of Windows. For best result, turn off compatibility mode of iTunes before you open it.
> 1. Make sure iTunes isn't running. 2. Click Start, type regedit, then press Enter. 3. Navigate to this Registry location:HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers 4; Its better you clean/repair Windows registry with Reg In Out. 4. Look in the main pane for a key that refers to iTunes. If you find one, delete it, then exit the Registry. 5. Start iTunes. The offending message should be gone!
Posted on Oct 12, 2010
PC power up - error mssge AppleSyncNotifier.exe will not execute because CoreFoundation.dll not found. Have reloaded itunes and Quicktime but problem still appears. Solution?
First Uninstall itune completely from you PC.
Go to www.apple.com/itune
Download newer (Latest) version of itune & install it on you PC.
Then run Apple Software Updater Install all apple software updates.
This may fix your problem.
If given information fix your problem please vote me up.
Thanks.
Jul 31, 2010 | Apple iTunes
Help MEE. I cant get QuickTime off my computer
go to douctuments and seaedh quicktime the right click and click uninstall
Jan 02, 2010 | Apple QuickTime
When trying to open itunes from desktop the following error message is recvd: "Quick Time failed to initialize (error-2096) Quick Time is required to run iTunes. Please uninstall then re-install iTunes"...
Go to...
My Computer
C:\
Program Files
Quicktime
On Quicktime.exe
right click and select propities
Un- select read-only.
Click OK
Go back into Program Files
Go to iTunes Folder
Go to iTunes.exe
Select properties
Go on the compatability tab and de-select all.
Dec 31, 2009 | Dell Inspiron 1720 Notebook
Error 7 keeps coming up when oppening itunes
A number of users have experienced problems updating to the newlyreleased iTunes 8.1.1. Generally, when this issue occurs, installationappears to proceed normally but then delivers the error message “Theinstaller encounted errors before iTunes could be configured. Yoursystem has not been modified. To retry these operations at a later timeplease return to the installer again. Click Finish to exit installer.”Fix
This problem can often be fixed by reinstalling the latest version of QuickTime via the following steps:
  1. Download the latest edition of QuickTime for Windows (make sure to pick the option without iTunes)
  2. Choose to save the file to your disk, then double-click the .exe file and install QuickTime
  3. After QuickTime is successfully installed, download iTunes again, choosing to save the file. Double-click the iTunes installer .exe and proceed with installation.
Other potential fixes for this issue include:
Run a disk check Disk errors, particularly in Windows XP, can prevent proper iTunes installation. See this Microsoft Knowledge Base article for instructions on performing a disk check/repair.
Use Windows Installer Cleanup Use the Windows Installer Cleanup toolto remove any references to Apple-related installation files(QuickTime, iTunes, etc.), then re-try using the aforementionedtwo-step method to reinstall QuickTime and iTunes
Oct 22, 2009 | Apple iTunes
Hi - sound keeps on cutting out when playing itunes.
Try the following, it shuld fix the issue;
Open up Quicktime (if you cant find a .mov or .mpeg video file go to Program Files, Quicktime, QuickTimePlayer) go to Edit, Preferences>Quicktime Preferences and go to the audio tab, be sure to set everything as follows:
Rate: 192kHz
Channels:Set to be equal to the speaker setup you have Apply and then OK and close Quicktime and iTunes and then start up iTunes.
Regards,
Anirban Mazumdar
http://www.ikarmatech.com
Sep 09, 2009 | Tascam US-122 USB Audio/MIDI Interface...
My itunes does not start whwn i clicked on icon.
Here's some info that may help - picked up from other boards where similar problems reported.
First check to see if Quicktime works normally, iTunes will not work without it.
If Quicktime is OK, then use these troubleshooting articles: XP version http://support.apple.com/kb/TS1421 Vista version http://support.apple.com/kb/TS1717
Have you installed any of the following: ACE & K-Lite mega codecs package, QT alternative, Storm codec, WinAVI video converter, Mpcstar, (possibly starcodec pack, 3ivx)
If so uninstall them, they are know to cause problems with Quickitme. Then download the version of Quickime without iTunes: http://www.apple.com/quicktime/download/win.html Now Remove Quicktime using the method for Quicktime in this article (just Quicktime): XP http://support.apple.com/kb/HT1925 Vista http://support.apple.com/kb/HT1923 When you come to your C:\Windows\system32\ folder you can delete any file or folder with Quicktime in the name. Restart you computer Install the stand alone Quicktime and check if it starts. If it does you are in a position to find out if iTunes is OK.
If Quicktime is OK, do you get any error message when you try to start iTunes? If not, open your task manager after trying to start iTunes. Do you see iTunes.exe running on the processes tab. If there is no error and you see iTunes.exe running then iTunes is hanging and we need to look at a slightly different route.
Sometimes it is just a problem with the itunes database file when it won't open after an upgrade. Press and hold the shift key while trying to start itunes. Does it give you an option to choose or create a new library? http://docs.info.apple.com/article.html?path=iTunesWin/8.0/en/15502.html
Bonjour is a common cause of iTunes hanging at start up. i.e. silent launch failure with iTunes.exe running on the processes tab. You can uninstall bonjour if you don't need it. However it is required for sharing libraries and other things
You could also try uninstalling it, then downloading bonjour from Apple and installing it directly. http://support.apple.com/downloads/Bonjour_for_Windows
Jun 15, 2009 | Apple iTunes
Try to open itunes but no quicktime
u can download quick time player in the following website..
www.filehippo.com...
thank u!!!
Apr 10, 2009 | Apple iTunes
Problem with QuickTime
Uninstall Quicktime I've tried following the steps here, but I can't seem to uninstall my version of Quicktime. I have a quicktime folder in my program files, but it doesn't appear in my "add/delete programs" screen accessed through the control panel. I also can't simply delete the entire quicktime file as one of the files gives me the "access denied" error and won't let me delete it.
So how do I get rid of this Quicktime program so I can try reinstalling itunes?
OR TRY THIS
You can download the stand alone Quicktime Player installer at:
http://www.apple.com/quicktime/download/standalone.html
Oct 13, 2008 | Apple iTunes
Itunes
Hey 0836,
If the error message you are seeing reads as "QuickTime failed to initialize. Error # - 2096" you may wish to turn off Compatibility Mode for QuickTime, as doing so may resolve this problem.
You should be able to disable Compatibility Mode by doing the following:
1) Right-click on the QuickTime Player program and choose the "Properties" option from the menu that appears. Normally the application is kept in the C:\Program Files\QuickTime directory, but may differ if you chose to have the program installed onto another hard drive or in another directory.
2) Once in the "Properties" menu, click on the "Compatibility" tab.
3) Uncheck the box that says "Run this program in compatibility mode" if it is currently selected.
4) Click on the "Apply" button.
If QuickTime was not initially in Compatibility Mode, and you still receive an error message prompting you that iTunes requires Windows 2000 or later (or prompts you to make sure that compatibility mode is disabled in iTunes.exe), you may wish to try the following instead:
1) Shut down iTunes.
2) Click on the "Start" menu, then on "My Computer." You can generally also double-click on the "My Computer" icon on your desktop as an alternative.
3) Once in "My Computer," open the drive where Windows XP is installed. Typically this is the C:\ drive, but please remember that your configuration may slightly differ if you have multiple hard drives.
4) Open the "Program Files" folder.
5) Open the "iTunes" program folder.
6) Next, right-click on the iTunes program - this may be listed as either iTunes or iTunes.exe. Once you have done so, choose "Properties" from the menu that appears.
7) Click on the "Compatibility" tab, and uncheck the option to run in Compatibility Mode if it is selected.
8) Click "OK" to accept the new settings.
One of these two solutions should hopefully resolve the problem, but I would strongly suggest visting Apple's support homepage for more information if you are unsure of how to proceed.
http://www.apple.com/support/
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Apr 13, 2008 | Audio Players & Recorders
Apple iTunes Logo
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
