Question about Samsung NV3 Digital Camera
I have a new NV3 digital camera and cannot get it to recognize the SD memory card I bought for it. The camera says "Memory Full" when the card is inserted. The card is a PNY 4 GB SDHC. I was wondering if it was too large for the camera. Please advise.
    Brigadier General:
  • 11,967 Answers
According to the specs for your camera, it can use an SD card up to 2GB but not an SDHC card.
Posted on Oct 11, 2010
Testimonial: "Thanks most helpful !!!"
  • sean665 Mar 08, 2011
    Your a bloomin star, i am mike tysons personal professional photographer and shoot with a Nikon D3, and a canon 7d, the nv3 is the stick in my pocket and walk about cam. So the sd card ....... bah iam waffeling. Just brilliant straight forward advice. Thank you so much.
    sean
    p4p photos
    www.p4pphotos.ifp3.com
I just got a samsung sensory pleasure nv3 i put a 4 gb memory card in it and it says memory full but the card is empty
Hi
Try formatting the SD card before using it.Also,check the storage destination of the pictures,could be they're storing on your camera and not in the memory card.Make the SD card the default storage device.
Hope it helps.
Feb 20, 2012 | Samsung NV3 Digital Camera
My camera is saying memory full with a new sd card in. why?
The Samsung NV3 can only use standard SD memory cards up to 2GB. I'm guessing that your new card is a 4GB SDHC card, which the camera is not capable of recognizing. Fortunately, 2GB SD cards are relatively inexpensive these days, and are widely available on Amazon (see this link) if your local store no longer carries them.
Oct 08, 2011 | Samsung NV3 Digital Camera
New 4GB SDHC mamory card will not work in my Samsung NV3 camera - I get a memory full message. I have formatted the card and erased internal memory with the card out of the camera and still no joy - any...
Sorry, but your older camera can only use 2GB or less standard SD cards. Fortunately, these are relatively inexpensive these days, and may be found on Amazon, if your local store no longer carries them.
Aug 15, 2011 | Samsung NV3 Digital Camera
My camera always shoing memory full , i format the internal memory and format new sd card , same problem , still shoing the same , how can i fix it
Make sure that the camera is set to record to the memory card... often the internal memory will only handle a couple of pictures...
If it still shows memory full then a ribbon cable has come loose inside the camers and it is not recognizing the memory or cards...
heatman101
Apr 23, 2011 | Samsung NV3 Digital Camera
Nv3 it says memory full even if the sd card is empty. it wont take photos
try using the camera to reformat the SD card.
Or maybe if that camera has internal memory, it is set to use the internal memory. Go to the options and set the camera to use the SD card
Mar 03, 2011 | Samsung NV3 Digital Camera
Full Memory with new cards
Go into the camera setup menu and make sure you have it set to save images on the card, instead of internal storage.
Dec 19, 2009 | Samsung NV3 Digital Camera
Memory card full but its new!!!!
Format the card in the camera to initialize it.
Oct 14, 2009 | Samsung NV3 Digital Camera
SD cards
Do the 4GB Cards say SDHC on them? They should. SDHC is simply "Secure Digital High Capacity". They're high capacity SD cards that hold more than regular cards. In this case, 4GB. The problem with these is that they need to be supported by the device. I've never put an SDHC card into a device that doesn't support them, but it looks like that's what your situation is. The highest memory capacity a non-SDHC compliant device is capable of 2GB. I recommend that you return the 4GB cards and buy 2GB cards instead.
Jun 16, 2008 | Samsung NV3 Digital Camera
MEMORY FULL
How many photos or videos do you have on the camera already? It probably won't store more than about 4 shots.
May 04, 2008 | Samsung NV3 Digital Camera
SD Card Wont Work
Check if the SD card is iserted properly into the camera, eventually pull it out and push it back inside the camera. Also remove camera batteries , repeat the operation, and put back batteries.
If the card still does not work test the card into a different device, it is not unfrequent that an SD card comes defective from factory. In this case take the card back to the retailer and a have it changed.
If the card works on a different device, then it may be that the NV3 does not support 4 GB , there is no mention about max SD format supported in camera specs, or in the manual. In this case I suggest testing a 1 or 2 Gb card at the shop, and then buying right one.
Regards
Apr 02, 2008 | Samsung NV3 Digital Camera
Samsung NV3 Digital Camera Logo
252 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
