Question about Baby Gear
Headrest removal how do you remove the headrest on a chevy 2007 impala ls
  • 50 Answers
There might be a cir clip in the back of the seat you have to put your arm up the inside to push the clip in may be scized
andy
Posted on Jun 02, 2008
How do you remove rear headrests?
Tracy, Some just pull straight up and out, there may be a pin hole, lever or button just under head rest which will release and allow head rest to be pulled up or pushed down, it does take some force as they do like to get stuck.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Headrest Removal Pinhole Release Car Seat Cover Installation
Removing Rear Headrest Center Volkswagen VW Passat 2012 2015
How to remove the headrest in 2011 150 Supercrew
2007 Chevy Uplander Head Rest Removal
Mar 23, 2016 | Cars & Trucks
Keys locked in 2007 chevy impala
stick a straightened metal coat hanger in between the door and the vehicle and fish for the unlock button. this is made easier by prying the upper part of the door open slightly with something that wont scratch the paint like wood or plastic.
May 21, 2014 | 2007 Chevrolet Impala LS Sedan New Cars
Recently purchased a 2007 Chevy Impala LS. All aux lighter plugs do not work. One plug has actually been removed and wires are taped off. I have not checked the fuses yet but was wondering if the...
Check the fuse first and then check the wiring coming from the taped off one to see if it has power. Then check the harness to see if they are connected to the same power source, which may be the missing one.
Sep 25, 2013 | 2007 Chevrolet Chevrolet Impala LS
How can i remove the headrest on my 2007 impala LS ?
Stick a heavy duty straightened out paper clip or ice pick in the hole in the posts holder and push the adjuster on the other side of the post. Pull the headrest up and out. clay58_28.png
Feb 13, 2011 | 2007 Chevrolet Impala LS Sedan New Cars
Where is the thermostat on my 2007 chevy impala ls? is it by the radiatior cap?
engine size? follow the upper radiator hose to the engine, its in the housing at the end of that hose.
Dec 20, 2010 | 2007 Chevrolet Impala LS Sedan New Cars
How do I remove the headrests on a 2010 Chevy Impala?
Check the base of the headrest at the plastic ring. There should be a small button that is pushed in from the side of the ring.
Oct 08, 2010 | 2009 Chevrolet Impala
How to replace a turn signal light on a chevy impala 2007 ss
Open hood. on top of headlight assembly you will find 2 small bolts. I believe a 10mm. socket should fit. Take the 2 bolts, out and remove complete assembly.
Feb 01, 2010 | 2007 Chevrolet Impala LS Sedan New Cars
Remove rear seat impala2007
To remove the rear seat, pull up on the front of the seat bottom, it should be hooked in place by spring type clips. After you get the front edge up, pull out the seat. This should expose the bolts/screws that hold the seat back in. Look below and there should be a couple of screws holding the seatback to the car body. Remove these and then you can pull the seat back out of the car.
K
Aug 29, 2009 | 2007 Chevrolet Impala LS Sedan New Cars
2007 Chevy Impala LT stock stereo
pop out the center trim piece with a flat head screwdriver. Center dash piece may be brushed aluminum or wood grain depending on trim level. It should pop out easily working all the way around it. Then radio is held in with 7mm screws.
Jun 21, 2008 | 2007 Chevrolet Impala LS Sedan New Cars
Baby Gear Logo
267 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
