Question about Solar ES1224 Truck PAC 3200 Peak Amp, 12/24 Volt Jump Starter
Looking for a wiring schematic for a solar es1224 truck pac put new batteries in and the selector switch is reversed from before pretty sure its the way it was any help would be great!
2 Suggested Answers
mkh5094
  • 145 Answers
SOURCE: outdoor umbrella with solar leds with switch, doesn't turn on
If you connect to solar panel for the lights to go on do the lights go out at night? If so, and the they do not light when hooked to the batteries then the batteries may have no charge and may also not be holding a charge. Put in new batteries to test.
Posted on Apr 26, 2010
I have a 96 six pac truck camper need a wire digram
Have you tried search engines for the brand name to see if the manufacturer is still around?
Jul 03, 2017 | RVs
Dc charging cord needs replaced. what are the specs?
How much current (amps) is the cable taking, if it is on the output side, a cable that can take at least 100 amps.
May 23, 2014 | Solar ES1224 Truck PAC 3200 Peak Amp,...
Charging cord missing
The charger manufacturer is Clore Automotive. The part number is ESA26 (http://www.cloreautomotive.com/sku.php?id=274).
If you know anything about electronics, you can determine the input voltage and current requirements for the charger and purchase a generic power pack. The cord connection to the charger can be matched and purchased from an electronic store like FRYs.
Oct 24, 2012 | Solar ES1224 Truck PAC 3200 Peak Amp,...
Still running rough after plugs and wires.
if the other coils are functioning, then voltage to the coil pack is ok. removing the spark plug wire from the suspected bad coil with no change in engine performance is a reliable procedure to check for a bad coil.
May 11, 2010 | 1991 Buick Park Avenue
Outdoor umbrella with solar leds with switch, doesn't turn on
Apr 26, 2010 | Solar 2-wire Pull Chain Light Switch For...
WHAT TEST CRITERIA CAN I USE FOR THIS PACK
This thing is a beast! What criteria you ask? What do you want to jump? The answer.... any damn thing you want!
3200 peak amps is huge.
1600 peak amps is huge! You have got it covered here friend.
  • 3200 peak 12 Volt amps.
  • 1600 peak 24 Volt amps.
  • Integrated voltage selection switch.
  • LED battery status indicator.
  • Automatic recharging.
  • 60" Heavy-duty cables.
  • DC outlet to power a variety of 12 Volt accessories.
Sep 26, 2009 | Solar ES1224 Truck PAC 3200 Peak Amp,...
Fuse blows upon insertion on 2006 Harley Sportster 883 Custom
When you're putting the new fuse in, is the switch in the on or off position? You need schematic of the wiring for the bike. If you wish to trouble shoot this problem, purchase a service manual. Make sure you're putting the correct fuse in to begin with. I'm pretty sure that the "hot" wire from the battery goes directly to the switch. There may be a short between the battery and the switch. Also, the wire that comes from the voltage regulator to the positive post of the battery may have been damaged. Look for melted insulation on the wire near your exhaust pipes and mufflers.
Sep 22, 2009 | 2006 Harley Davidson XL 883 Sportster
Solar ES1224 Truck PAC 3200 Peak Amp, 12/24 Volt Jump Starter Logo
132 people viewed this question
Top Solar Electrical Supplies Experts
Steve
loft404
loft404
Level 1 Expert
Craig Butler
Craig Butler
Are you a Solar Electrical Supply Expert? Answer questions, earn points and help others
