Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
I have a whirlpool side by side with ice dispenser and holder in the door. The model number looks like GS6NHAXVO (or possibly Q on the last digit as the number is printed overlapping the upc code and hard to read). I have had a small amount of water leaking out the front of the door where the water/ice dispenser is located. There is water dripping out of the ice dispenser chute and there is a little flapper door inside the dispenser chute that doesn't seal the chute closed. The flapper door just dangles loosely, I suspect a spring is misaligned? Is there a way to fix this flapper door so that the ice doesn't drip out the front of the refrigerator?.
SOURCE: Ice dispenser
I fixed it by replacing the solenoid that operates the flapper door and the flapper door. They came as a kit and both were broken.
I still have a problem which is a bad circuit board. I can't switch from ice to water. I am stuck on ice, so I have not bothered to fix.
Posted on May 12, 2008
  • 24 Answers
SOURCE: Front of in door Icemaker door spring fell out!
Any chance of some photoes may be able to figure out if have some pics.
Posted on Oct 08, 2008
  • 1122 Answers
SOURCE: ice dispenser chute
most flaps have a solinard that opens and closes the flap,if you can replace or get in there to lube it you should me ok,let me know more-mike
Posted on Oct 12, 2008
  • 4 Answers
SOURCE: Ice dispenser little flap not closing after dispensing ice, build up of ice on inside
you have apossibale air leak mixing with cold air from refer
Posted on Oct 17, 2008
peyton32034
  • 410 Answers
SOURCE: how to repair the ice dispenser door on a whirlpool refrigerator
If you will look on the bottom of the dispenser cover you will see 2 notches on the left and right side. carefully pry the cover off using a flat tip screw driver. then you will see a white switch plate that is either held on with latches or 2 srews depending on model. once this is removed you will gain access to the dispenser door.
once you gain access I think you will find the hinges for the dispenser door are broken off. if so you will need a dispenser door repair kit form whirlpool part # 8201756 this kit includes new door and hinge repair kit. this is something you can do yourself if you are pateint and pay lose attention to detail. otherwise I would recomend a god servie company. thanks for using FixYa Peyton
Posted on Feb 18, 2009
ICE MAKER WORKING BUT NO WATER COMING
The water dispenser and ice maker solenoid comes as a set it is very possible the dispenser side for the water valve is defective. Get the model number of your refrigerator and click here=> sea_breeze_35.jpg and then enter model number for your 25.4 cu. Ft. SxS find part number in photos and replace the part number for your whirlpools dispenser solenoid. Easy to do and much less expensive. If you need help let me know because its a lot cheaper than calling a technician.Let me know, I will be glad to help you, Sea Breeze help you, Sea Breezesea_breeze_36.jpg
Dec 24, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Whirlpool side by side with ice maker dispenser not working
Hello, we are sorry to hear that you are experiencing this problem. We would suggest checking the ice chute to make sure that there is no ice lodged in the way of the flap. If the issue persist we would suggest having a certified technician out to look at the Refrigerator. If you would like further assistance you can send your name, phone number, address, model/serial of the appliance and the date on which you purchased the Refrigerator to Whirlpool_Reviews@Whirlpool.com. Thank you.
Apr 17, 2017 | Whirlpool Refrigerators
Whirlpool indoor ice maker not making ice
Could not locate your model number. However, Check fill tube for icemaker inside the freezer. Iced solid? replace water valve. No ice in fill tube? Get correct model number and resubmit your request.
Sep 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Need someone to explain in detail how to change the water filter ....i have a replacement just don't know how to do it
At the bottom on the kickplate ( by the picture on this thread , you didn't give a model number ) twist the slot under freezer door , to the left and slide out filter . The filter slides off the holder . Slide new filter on and reinstall into the hole , twisting the holder clockwise so it seats .
Sep 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Dispenser flap is dangling
You need a ice door kit. It's either part # 8201756 or 8201758. I'm not sure which part number it is but you can go to ddapplianceparts.com and go to the left hand side of the screen and type in the 1st part number and if it says it's a ice door kit, then that's the part you need. We replace a lot of these.
Aug 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
ICE MAkER HANDLE PROBLEM
If your model is the Whirlpool Gold I can possibly help you.
Whirlpool Gold GD5NVAXSY need model number to got to service manual. Sorry, but manual people don't realize how many versions of refrigerators. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Jun 02, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Inside light on fridge/freezer not working.
OK, the digital logic being out reminds me of the possibility the mother board or circuit board has gone out. If you can get the complete model number on inside of fresh food compartment door frame, near bottom of door, I will be able to help you better. While I wait I will try to look up similar models and get better answers for you. Thanks, Sea Breeze
Mar 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
How to repair the ice dispenser door on a whirlpool refrigerator
Feb 18, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
Dec 30, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice dispenser in door will not dispense ice
this could be the:
door switch (usually 2 switches, 1 for the light and 1 for the dispenser) auger motor itself the dispenser switch or the plug near the hinge that connects the door the the refrigerator has a bad connection. this connection is hidden under a plastic hinge cap usually.
Jun 28, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
