Got a high temp/error warning light - Computers & Internet
  • 2,567 Answers
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced
Posted on Oct 11, 2010
While driving down the road in my 2003 pontiac montana. The change oil light comes on and high temp warning light comes on. When the high temp light comes on the van losses all power.
Check the coolant first. Add as needed. Once full. heat it up in the driveway and check for leaks. 3.4 montana, I would guess the water pump. Change the T stat also.
Aug 09, 2015 | Pontiac Cars & Trucks
My utility heater by Pelonis model hb301 serial no. 3011137160 will not heat up anymore .
the over temp safety switch has failed. It is replaceable but is a pain to change as they are usually attached with special high heat crimp terminals. there should have been a a warning light on the front that is supposed to warn you when the high temp switch has been activated.
Feb 15, 2015 | Pelonis Heating & Cooling
Hotpoint ffs70 high temp warning light is on
First check the compressor and make sure it comes on and cycles. Then check the evaporator fan and make sure that is working. Then check for an ice building up on the evaporator coils (an indication of defrost heater malfunction)
Feb 02, 2012 | Hotpoint FFS70 Bottom Freezer Refrigerator
Display is reading "system error
it means there is a high temperature warning or issue
E001 is a high temp. error. My first advice would be to attempt to clear it in service mode:
  1. Press ADDITIONAL FUNCTIONS, #
  2. Go to #7 Printer and press OK
  3. Go to #4 Printer Reset and press OK
  4. Yes = ( * )
  5. Power cycle unit.
If that fails you will need to theck the thermistors and or replace the fuser
Apr 18, 2011 | Office Equipment & Supplies
Red warning light marked A/T Temp has come on.Meaning?
This light warns you if the transmission temperature goes to high
Jun 29, 2009 | Mitsubishi Raider Cars & Trucks
Check gages light is on what does it mean?
could be low fuel , low coolant temp , high coolant temp , low oil pressure , low voltage , high voltage , have a mechanic put a scanner on it make sure all is normal , might have false warning
Feb 17, 2009 | 2003 Pontiac Bonneville
High temp warning
2 BLINKS: Temperature
Apr 05, 2008 | Sony KDS-R50XBR1 50" HDTV
Fridge freezer temp warning light
I expect the thermostat is failing. You may be able to replace it yourself - depends on availability, and your skills, or else I guess it's a service call out.
Jan 15, 2008 | Refrigerators
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
