Question about HP LaserJet 3600n Printer
Error code 10.92.00 cartridges not engaged - HP LaserJet 3600n Printer
I need the cd player code
Common problem.. I re-engage the cd or cd cartridge and the error message goes away and cd starts to play. try it, it make take 2-3 times but it works for me.
Apr 22, 2015 | 2008 Ford Taurus
Cartridges not engaged error 10 92 03 hp 3800n
Sounds like one or more of the cartridge lock levers or slide levers may be broken. If this printer is very old, you may want to consider replacing it. See...
http://printertechsforum.com/forum/showthread.php?3861-HP-LaserJet-3800n-10-92-03-cartridges-not-engaged-error
May 19, 2014 | Canon Computers & Internet
It displays either code 59.51 or10.92.02 not engadged
It's likely either a bad Cyan cartridge or ribbon cable pinched. This is what I found on DepotTechSupport (so the solution isn't mine, just the searching) :-)
59.51, 59.61 ERROR
http://depottechsupport.com/index.php?/Troubleshooter/Step/View/8
59.51 ERROR 59.61 ERROR An error occurred with the cyan printcartridge drive motor during startup or rotation. 1. Check that connectors J5004 on the cyan print-cartridge drive motor and J207 on the driver PCA are seated correctly. 2. Replace the cyan print-cartridge drive motor. 3. Replace the driver PCA
10.92.YY CARTRIDGES NOT ENGAGED
10.92.YY CARTRIDGES NOT ENGAGED The print cartridges are not engaged correctly. YY Description: 00 Black 01 Cyan 02 Magenta 03 Yellow 1. Open and then close the front door. 2. Make sure all the print cartridges are seated correctly. 3. Turn the printer off and then on. 4. Inspect each cartridge lock-lever (on the right side). Open the front door and remove all cartridges and the ETB. Then use the ETB holder on the right side to move the lock-levers up and down. Replace the cartridge lock if it is broken. 5. Inspect the right side cam. This piece controls the movement of the cartridge engagement arm, the cartridge shutters, and the OPC drive. You can inspect this piece without taking off the covers by wiggling the white rod arm on the right side of the ETB. If it moves easily, the part is broken and should be replaced. 6. Inspect the ribbon cables. Folded or damaged ribbon cables can cause a short that generates an error. 7. Inspect the cartridge guide rails to see if any are damaged. 8. Upgrade the DC controller firmware. 9. Clean the contacts on the memorycontroller PCA. 10. Verify that contact is being made with the E-label PCA on the print cartridge. Replace the print cartridge if the Elabel PCA is missing. 11. On the DC controller, make sure that connectors J1022 and J1023 are seated correctly. On the driver PCA, make sure that connectors J201 and J401 are seated correctly. 12. Check the gears on the print-cartridge drive motors. Replace defective motors.
Sep 09, 2013 | HP COLOR LASERJET CP 3505 N PRINTER
Why does my sony wega kf-50we610 blink 8 times? I just changed the lamp.
It is an error code (they are usually listed in the owner manual).
If you did not have this before changing the lamp---unplug set and plug it back to see if same error code.
A common issue if the error is really 3 blinks I can answer instantly--if it was not 8 before lamp replaced remove lamp and make sure it went in correctly and the two pins on the cartridge engaged properly
Mar 27, 2012 | Sony Televison & Video
Error 10.92.00 cartiridges not engaged
The printer keeps track of the number of pages that the cartridge has printed, by reading the memory chip on the cartridge. Reinstall the cartridge. Are you using an HP cartridge? Try a different cartridge. Problem could also be with the DC Controller.
Aug 16, 2010 | Office Equipment & Supplies
Error Code 1102 on Lexmark P6350 Printer
Hi, it seems that it's a cartridge problem. That's the most probable reason why you're getting that error code. Try this out.
1. Remove cartridges.
2. Unplug printer from power outlet.
3. Then, plug printer back in power outlet after 10-15 seconds.
4. Reinsert cartridges.
If error still appears, redo steps 1, 2 and 3. Then, insert black cartridge first. If error appears, replace black cartridge. If not, insert color cartridge, if error appears, replace color cartridge. Hope this helps.
Mar 08, 2010 | Lexmark P6350 All-In-One InkJet Printer
HP printer error 10.92.02 and 10.92.01 - cartridges not engaged . . just changed the cyan cartridge and this error appeared - help
I don't know what printer you are using because a P3005N is a monochrome printer and doesn't use a cyan cartridge.
For a lot of colorlaserjets you can try the following steps. Remove all the cartridges, close all doors and power on the printer and then power it off. Insert the cartridges one by one and power the machine on and down each time you inserted a cartridge.
Feb 18, 2010 | HP LaserJet P3005n Printer
I have a hp color lasorjet 3800N printer and am getting the following error message 10.92.03 cartridges not engaged. OPening and closing the door does not correct the problem. How do I fix?
Any of the 10 series errors are saying the cartridges are not correct or not installed properly. The first place to start is remove each cartridge wipe the contacts and make sure all are installed fully. After that, if you still have the error you might have gotten a defective cartridge if one was replaced recently.
Oct 02, 2009 | Office Equipment & Supplies
Hp color laserjet 3550 - error message "cartridges not engaged"
here are the codes for the error you are getting
10.92.00 Black toner
10.92.01 Cyan
10.92.02 Magenta
10.92.03 Yellow
The fix is either the toner lock is broken. Contacts on the left side of printer are damaged.
There is a complete proceedure for replacing the the toner locks which comes in a kit you can order from precisionroller.com. this takes about an hour.
If the contacts are damaged you will have to replace the whole plastic part on the left side behind all of the electronics. It takes about an hour
Jun 14, 2009 | HP Color LaserJet 3500 Printer
I just put in a yellow cartridge. Previously the printer was working just fine. Now it is showing an error code: 10.92.00 So I put the old yellow cartridge back in. The same error code now appears? He
Hi ron0911170:
This is your problem.
10.92.YY CARTRIDGES
NOT ENGAGED
alternates with
Open and close
front door.
The cartridges are not engaged,
poor primary transfer bias contacts,
defective high-voltage supply, or
control signal errors.
YY Description:
00 - Black print cartridge
01 - Cyan print cartridge
02 - Magenta print cartridge
03 - Yellow print cartridge
1. Open and close the front door to fully
engage the cartridges.
2. Reseat the print cartridges.
3. Check the printer primary transfer bias
contacts to the transfer unit. Clean if
dirty. If the contracts cannot be
cleaned or they are damaged, replace
the transfer unit.
4. Replace the high-voltage power supply
PCB.
5. Replace the DC controller PCB.
Hope this helps
May 24, 2009 | HP LaserJet 3600n Printer
HP LaserJet 3600n Printer Logo
532 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
