Question about Haier HSB02 1.8 Cu. Ft. Compact Refrigerator / Freezer (Black Finish)
Frige and freezer not turning on (not getting cold).. You can hear compressor on, thermostat is set @6, No signs of damage and or leaking free-on.
SOURCE: ge refrigerator model gss22wgph bb
Carben,
I have the same problem and I am able to resolve it by defrosting the element which is behind the inside rear panel of the freezer. I use a hair dryer to melt the ice build up. It happbed a couple of times so I know that there is a cause for this which may be the defrost heater but I am not sure how to confirm this. Let me know if you have any ideas.
Posted on Sep 16, 2008
Krames
  • 18 Answers
SOURCE: Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Posted on Nov 15, 2008
aasc
  • 1606 Answers
SOURCE: blowing cold air but not cold enough to keep frige cold
IF there is frost on the back wall inside the the freezer section about 12 inches from the bottom , you have a defrost problem . If there is no frost on the rear wall , then you probably have a bad overload/relay (part # 2188840 ) . This piece is the part which is plugged onto the compressor , with 2 or 3 wires going to it . Unplug it from the compressor and shake it . If it rattles , replace it .
Posted on Aug 02, 2009
milten1
  • 1304 Answers
SOURCE: freezer is 0 degrees frige side only 40 degrees
that would be a valid check
but with this model i would look more twords you thermister in the refer, if its maintiaing a constant temp, but just outta temp, its more than likely you thermistor is going bad
Posted on Oct 14, 2009
Testimonial: "it seems that even if I set the control to the coldest is dosen't affect the temps range"
  • 2468 Answers
SOURCE: MY ROPER FRIGE IS LEAKING WATER FROM THE FREEZER
the drain tube from the freezer to the lower compressor area is plugged with ice or debris,and when it defrosts the water in the drip pan behind the evaporator back cover inside the freezer thaws and cant drain down and overflows down thru the damper vent door to the refrigerator,remove the rear panel inside the freezer shut off unit and let thaw,then take a wire and work it down this drain hole till water comes out at the bottom of this drain tube located in the rear
Posted on Mar 19, 2011
Testimonial: "Thanks for the info. with a blow dryer , and turkey baster and a hour worth of fun, we finally got it to drain."
I have a samsung fridge/freezer. Production date 2007. Model#RS20NRSV5/XSA both the fridge an freezer not getting cold The lights are on but no cold air.An cant hear anything working at the back.
Your compressor is not working that's why its not cooling and you cant hear anything.
Possible cause:
  1. thermostat is set to off or defective
  2. defective capacitor that's why your compressor failed to run.
  3. defective compressor motor
  4. Freon leak or no freon at all.
Solution:
  1. check thermostat switch or relay
  2. check capacitor and wiring.
  3. check compressor motor.
  4. Check Freon pressures.
May 11, 2016 | Samsung Refrigerators
Tip
Refrigerator not gettin cold but freezer is good
ok if you have a refrigerator that leaks from the freezer into the frige all you have to do is put all the food in an ice chest turn it off or better yet unplug it for no less than three hours then clean up the mess you just made on the floor and dont forget the standing water under the veggie drawers plug it back in and turn the thermostat setting to 3 and dont forget get your food back out the ice chest and put it back in frige grab a beer and relax cuz your done ha
on Feb 24, 2010 | Refrigerators
I have an amana bottom freeze abb2227dew the freezer is working fine but the frige isn't cold?
check the regulator or thermostat for the fridge and set it well.
if it is well set then your compressor is losing compression.
May 11, 2011 | Amana ABB2227DE Bottom Freezer...
Freezer has quit freezing only a little over a year old. manufactor date 6/2009 compressor is running will only cool down to 50 degrees thermostat set on coldest.
Is the compressor continually running? If so then there could be a leak in the system or the compressor is damaged. If it's running then stopping, the cold control (thermostat) could be damaged.
Mar 06, 2011 | Kenmore 15 cu. ft. Chest Freezer 16542
Freezer and Refrigerator wont get cold
Good day,
Looks as if you covered most bases.
You didn't say if the fan motor in the freezer compartment is running. Open the freezer door. You should be able to see and hear it. if not, remove the rear panel in the freezer and inspect and replace if needed. If no luck here......
Based on everything you said, it sounds as if you have a serious problem with the sealed system which includes the compressor.
You do not recharge a refrigerator. You fix the leaks, and then recharge. But it could be a restriction in the internal system, or possibly bad valves in the compressor.
In either case, you'll need a qualified tech to sort it out.
Thank you for using FixYa.
Jan 20, 2010 | Kenmore 63093 Top Freezer Refrigerator
Blowing cold air but not cold enough to keep frige cold
if one of the panels in the fridge has frost on it, the evaporator coils may be iced up. this restricts the cold air flow. to defrost: empty the fridge and freezer, turn it off, remove the panel in the freezer that has the frost, use a hairdryer and defrost the ice buildup, sop up excess water, dry it up, replace the panel, turn it on (while it's empty), set the temp halfway, and close the doors. when the compressor turns off, fill the fridge. if the panels are frostless and the coils are warm, you may be out of refrigerant from a freon leak somewhere. it might be cheaper to replace the fridge.
Jul 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My frige in not getting cold it just started today the lights are on but its not getting cold i
Do you hear the compressor running? This is a problem with lots of possibles. Things that keep the comp from running, thermostat, defrost timer stuck in defrost, failed electrical components on comp.
If it is running the condenser fan might not be, the coils could be dirty, the light is not turning off when the door is closed (which usually results in a warm frig only, freezer is ok). Eric
Jun 11, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Light on no fan
it sounds as though the thermostat is faulty not bringing the compressor on and the defrost timer is turning the fan off and on as it should do
May 02, 2009 | GALAXY Microsystems 63702 Top Freezer...
Freezer is freezing but fridge is not cold as it was
Sounds like defrost timer is not putting the refrigerator in defrost every 8 hours. You freezer should be below -5 degrees. Also the condenser beneath the refrigerator possibly needs cleaning. First slowly turn the defrost timer clockwise until freezer goes in defrost. You should hear the sound of crackling noise in freezer after about one minute into defrost. If timer does not come out of defrost or does not turn itself then replace it. Let me know what you find, Thanks Sea Breeze
Feb 07, 2009 | Frigidaire FRT15G4B Top Freezer...
Freezers cold but refrigerators warm
see if there is a big block of ice on the back plate in your frige, if there is then your thermostat is set to cold or broken. if no ice in the frige then it has a gas leak!
Dec 27, 2008 | Magic Chef MCBR440 Compact Refrigerator
Haier HSB02 1.8 Cu. Ft. Compact Refrigerator / Freezer (Black Finish) Logo
44 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
