Question about Seiko Coutura Chronograph Watch
I just replaced the battery on my seiko. Watch is working fine EXCEPT the alarm will not ring. Help!
    Genius:
  • 1,970 Answers
Mcdevito75 here, By pressing the MODE button until you get to the alarm function and turn it to on or, set an alarm time for the alarm to go off.
Posted on Oct 11, 2010
  • 4 more comments
  • pete776 Oct 11, 2010
    There is no MODE button on this watch. It is a Seiko 7T62 chronograph watch.
  • Michael C. De Vito
    Michael C. De Vito Oct 11, 2010
    Mcdevito75 here, It may not be called MODE, as each watch is different, simply go thru your settings until you reach alarm or set a time on the alarm.
    I set it, it doesnt ring.
    I did. It wont ring when it hits the setting. Doesnt make any noise at all.
    mcdevito75 here, If it was working before the battery change, you"ll have to double check your battery installation, also check that all button contacts are being made from the button itself to the movement, use a Qtip to clean all contacts as oil from your fingers could make a bad contact. also, if there is a seperate battery for the alarm as some watches have you may also have to replace that battery. Last but not least, your NEW battery could be weak right out of the package, who knows how long it was in the store or warehouse. Sorry for your troubles but welcome to the world of watches. One more thing, the alarm sounds from a speaker like device just under the back cover, double check everything for proper placement and go slow, don"t loose patience, take a break and return to your watch. Hope all works out.
How to set on the alarm on a seiko D 409 5030 silver wave
Here are instructions for the watch as a .jpg file...if you press both the "C" and "D" buttons ( refer the attached pic) at the same time you should hear the alarm ring. If it does not it will possibly need checking by a Seiko repair centre ( possibly no parts available though due to age)
Cheers
Mike
Dec 10, 2017 | Seiko Watches
All functions on my seiko work fine it just will not start.
mcdevito75 here, Your watch should start by pressing the MODE button maybe once or twice or by pulling out the stem as if to set the time and pushing it back in.
Jul 04, 2010 | Seiko 0512037FA Wrist Watch
How to set Seiko alarm chronograph alarm?
Without the watch model it is hard to help you set the watch. Some Seiko watches use the watch stem which has two positions. Sometimes it is hard to identify the indentations so you may want to pull the stem all the way out then carefully push the stem to the first indentation. This will activate the alarm until it is pushed all the way in. When it is in the alarm on position, you can use the buttons to set the alarm time. However, I have 10 Seiko watches, and they are all unique to their functions, so it is best that you go to the link below and put the caliber code from the case back and look at the instructions.
http://www.seikowatches.com/support/ib/index.html
Feb 24, 2010 | Bulova Watch
How do you use the alarm in the Seiko coutoura chronograph?
You can obtain instructions from the Seiko web site "seiko.com".
Go to their web site, click on "support". The on "instruction booklets",
You can either enter the number off your watch or choose the instructions from the list.
Jan 25, 2010 | Seiko Coutura Chronograph Watch
I have a Seiko Titanium Chronograph certified water resistant to 20 BAR. The movement # is 7T62-0BZ0. I recently had a jeweller put a new battery in the watch and it has not been working properly since. I...
DO AMASTER RESET TO YOUR WATCH!PULL FULL OUT THE STEM(CROWN)THEN TURN THE HANDS TO THE RIGHT TIME THEN RESET THE CHRONOGRAPH AND THE ALARM WITH THE TWO BUTTONS(SEE YOUR MANUAL.IF YOU HAVENT TRY TO DOWNLOAD IT FROM ANY SITE OF SEIKO SUPPORT).THEN PUT THE CROWN IN.IF THE PROBLEM REMAINS THE ONLY SOLUTION IS THE SIKO SERVICE!THEY ARE NOT EXPENSIVE AND MAKE GOOD WORK!DONT GIVE THE WATCES EVEN FOR THE BATTERY TO THE MONKEYMAGICIANSGURU JEWELERS THEY ARE WATCH RUINERS!
Dec 06, 2009 | Seiko Alarm Chronograph Titanium CASE AND...
Seiko Chronograph Sport 150 - Problem: After Battery replacement and pressure test (15-Bar), watch hands are not in the correct place. Can this be fixed so the chronograph timing features, and month &...
Please folow this link:
http://www.seiko.co.uk/support/instructionbooklets
Enter your calibre code (its on the back of your watch, it will explain which numbers to you on the website), you'll then be able to download an instruction manual for your watch, this will detail how to adjust hands to their corect starting position :)
Nov 20, 2009 | Seiko SNA553 Alarm Chronograph
Resetting a SEIKO watch
You may can find instructions here:
http://www.seikousa.com/#FAQ
Go through the watches till you find the match.
Rate me, please.
Mar 14, 2009 | Seiko 0512037FA Wrist Watch
How to set the alarm on a seiko presage chonograph?
Try Googling (Seiko)(SUY055)(manual) without parens for instructions.
Dec 15, 2017 | Seiko Presage SUY055 Wrist Watch
How to adjust alarms
moz-screenshot.jpgSetting the alarm:
1. Pull the crown to the 2nd "click" (the possition you adjust the time) (Carefull: The seconds hand has to be on "12")
2. Press repeatedly button "B" to set ALARM hands to the time indicated by the main time hands (The ALARM hands move quickly if button B is kept pressed)
3. Push the crown to normal possition
4. Pull the crown to the 1st "click".
5. Press repeatedly button "B" to set the desired alarm time. (The ALARM hands move quickly if button B is kept pressed)
6. Push back the crown in to normal position.
At the designated time the alarm rings for 20 seconds, and it is automatically disengaged as it stops. To stop it manually, press button A or B.
Oct 15, 2008 | Seiko Le Grand Sport SDWF73 Wrist Watch
Seiko Coutura Chronograph Watch Logo
437 people viewed this question
Top Seiko Watches Experts
Jerry Greenberg
Jerry Greenberg
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
