Question about Dell Inspiron Mini 10 Notebook
Have a dell inspiron mini has the blue screen and unable to go into safe mode
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 132 Answers
The fatal blue screen occurs due to0 the OS issues.. So reinstall the OS... The mini computers dont have CD drive so use the following option
Dell has a default partition on the computer and you can install with the same..
If you have windows 7 on the computer then tap F8 when the computer turns on and then you will be able to see the advanced boot options.. Select repair my computer.. In the repair my computer screen select the dell factory image restore...
Your computer will go through the installation and it will be up and running...
If you have windows Xp then you have to turn on the computer and when the dell logo appears you have to simultaneously press control and the F11key.. You will be able to reinstall the OS in this way..
If the restore option is not available then call up the tech support of dell(18006249896) they will replace the HDD to fix the issue
Posted on Oct 15, 2010
I can't get into safe mode keep going to blue screen0x000000ed help
its called the screen of death, can be caused by software or hardware fault.
things i would test is the hard drive, memory and software problem.
afraid theres no quick fix on this one.
Jun 17, 2012 | Dell Inspiron Mini 10 Notebook
Dell inspiron 910 no cdrom has blue screen
This is not good, this indicated hard drive failure, or windows files has been corrupted so you can not access the partition. If you have the owners manual see if they offer a way to do a full recovery, if that is not available, have the hardware assessed for possible replacement.
Mar 31, 2012 | Dell Inspiron Mini 10 Notebook
Ok, my dell inspiron mini will turn on, but after it does the dell thing in the begining, the screen just goes blue.
This happens because you might have installed some new software and hardware on your system.
Reboot your system and start typing F8 key
Check by selecting last known good configuration
If this does not work then boot the system in safe mode and try system restore and restore your system to backdate when it was working good.
You can also try removing some recently installed software or remove recent windows update.
Sep 16, 2011 | Dell Inspiron Mini 10 Notebook
I have a Dell Inspiron Mini 10 no cd rom drive, when i put the netbook on ,,it shows a blue screen., i need help to fixs it............ Its on safe mode!!! I have the cd to reboot it, I just don't know...
The Recovery CD was meant to be used with an external CD drive. They just assume you'll buy one. If it's in safe mode,you should'nt have a blue screen in safe mode. In safe mode, you should be able to use the computer in pretty much the normal way.If so, then what you need to do is a "System Restore". Click the "Start" button,then "Control Panel", then "System". Near the top -left corner of the "system" box, you will see a tab labeled "System Restore". Clickit, and follow the instructions.
Apr 04, 2011 | Dell Inspiron Mini 10 Notebook
Goes blue screen on start up. UNMOUNTABLE_BOOT_VOLUME Recommends starting in safe mode...will not start in safe mode either.
1.) Possible bad hard drive unit
2.) Possible bad cable/connector(s)
3.) Corrupt boot sector
You can try checking the cabling yourself. If that does nothing, then please consider hiring a local computer guy for assistance. (IMO: Avoid hiring technicians from big box stores.)
Dec 18, 2010 | Dell Inspiron Mini 10 Notebook
My Dell Inspiron Mini 10v comes on. It asks if I want to start in safe mode or last known configuration and after I click on either, the screen goes blue and gives me an error message with the following...
Yup go to safe mode, and choose system restore... follow instructions and select a time prior to when you had a problem. finish off and your PC should be all working again. Startup PC, press F8 at instant of turn on... choose Safe Mode. when you are asked if you want safe desktop or system restore choose restore, when you get to the restore menu, choose a date BEFORE you had problems there may only be one or two to choose from. just follow the instructions and you should be back to working with all that behind you.
Mar 05, 2010 | Dell Inspiron Mini 10v Netbook
Dell Inspiron mini10
check if keyboard works during dell logo - try to press F2 or F12 - if no response need to replace keyboard
Feb 19, 2010 | Dell Inspiron Mini 10 Notebook
Blue Screen of death.
You might try removing the Hard Drive from the machin and slaving it on your other machine. Then running a chkdsk in the command prompt or norton disk utilities. If either fails, backup your data on other machin and reinstall.
Jan 26, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron Mini 10 Notebook Logo
549 people viewed this question
Alun Cox
