I have an old universal remote phiips ver clo34, or,3106 and a old sony projection tv but i dont have a remote for the tv so i can change the channel to 3 for the cable to work so im asking if you havve the codes fo r this phillips remote ! thanks Juliette Romero,
tvtek
  • 1284 Answers
SOURCE: TV not working with remote from Cox cable/Scientific Atlanta
The cable company should be able to tell you how to scan for the remote code that will work for the TV. The other possibility is to try a Funai or Symphonic codes since they are the same with Sylvania now.
Posted on Apr 18, 2007
SOURCE: ILO TV Universal Remote control code
try changhong code #10765
Posted on Feb 07, 2008
PABLOCSA
  • 1124 Answers
SOURCE: Remote Codes for new Sony Bravia
Sony has unique code for all equipments, those are 0000, and 0111, if doesn't work with your tv the problem it is on the remote control.
Posted on Nov 17, 2008
  • 4 Answers
SOURCE: Universal Remote for Hisense TA42P40M
The Logitiech Harmony will work on any Hisense TV. For instance. Logitech Harmony 550 Universal Remote. http://www.amazon.com/Logitech-Harmony-550-Universal-Remote/dp/B000EUGX70/ref=pd_cp_e_3?pf_rd_p=413863501&pf_rd_s=center-41&pf_rd_t=201&pf_rd_i=B00093IIRA&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=0ACHP3B2Z1XPGGZHPA28
Posted on Jan 04, 2009
SkyGuy08
  • 27 Answers
SOURCE: sky remote code fo LCD LE40A456 TV
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Posted on Apr 08, 2009
No remote sony wega
You can simpley fix this problem!
Just buy a universal remote!
BTW: Don't buy a new kind but on older kind of universal remote!
It's just 10 bucks in a electric store!
Sep 08, 2012 | Sony Grand WEGA KDF-55WF655 36" Rear...
Same problem as above.Disney p1310ATV lost the remote. No Phone # in orginial manual.Television system NTSC (American TV Standard) I have tried other universal remotes also I have a Sony RM-V210 universal...
there may be a problem with the tvs remote sensor. most universal remotes you dont even have to enter any codes you just have to follow the same steps to enter the code but instead of entering a code all you have to do is press the channel up button after following all other steps, just keep pressing up until it turns the channel on the tv then press enter or similar button after it changes the channel and this should lock in the code without entering a specific code.And if all other remotes only half the buttons work on if it happens with every universal remotes then it probably a problem with the remote sensor or the tv . Good luck too ya!!!
Jan 02, 2011 | Disney 13" TV
Can not change the channels on my Sony Bravia KDL-46V3000. The remote will turn the TV on and off but will not change the channel.
Is this the original remote or a universal remote? Can you change the channel with the buttons on the right side of the TV?
Can you type in a channel number and go to that channel? (this applies if the channel will not change with the buttons on the TV.) Try to rescan the channels (it could be that the TV has the other channels hidden (or lost the list).
If it is a universal remote, you may not have the correct code (just a close one). Try additional codes for Sony TVs. Also when was the remote built? If it was programmed more than 6 months before the TV was released, then it will not have the correct codes. You would need a newer remote. A substitute remote can be obtained from https://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?sessionId=4q4-Cd8shqFs_c5rcVcD_Lw or http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=KDL-V32XBR1&uuid=12842263276080 .
I hope this helps.
Sep 11, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Rca hdtv channel changed by mistake
RCA channel setup and selection is not easy to understand. You may try to add channel 3 on the add/remove channel section. If that doesn't work try pressing the input button. Good Luck.
Feb 28, 2010 | RCA HD52W56 52" Rear Projection HDTV
Programming channels
universal remote will work,
sony does sell a replacement remot or get a logitech harmony one
it replaces all your remotes
Apr 02, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Code for Sony tv
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 10, 2008 | Philips Universal PH301S Remote Control
RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
Feb 08, 2008 | RCA RCR311B Remote Control
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Sony Trinitron KV-20VM40
You can't. Best solution = buy a universal programmable SONY
remote for about 12.00.................................T.
Nov 18, 2007 | Sony KP-44PX3 44" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
