Question about Dewalt DC011 AM/FM Radio
LOSES MEMORY WHEN TURNED OFF - Dewalt DC011 AM/FM Radio
  • 4 Answers
Replace the 2 AA batteries in the main battery case.
Posted on Oct 28, 2010
I have a pioneer DEH 150 radio it's loses its memory when the isolator switch is turned off in the tractor?
The radio has been wired incorrectly so no 12v battery power is applied to retain memory when the isolator switch is turned off.
Jan 02, 2017 | Pioneer Car Audio & Video
When turned off, why does it lose all channels stored in memory?
Not a power supply problem. Trouble with the main board
Sep 29, 2015 | Bush Televison & Video
Turn off subtitles
hi no mention of make or model if u cant turn of subtitle on the remote unplug the power cord for 5 or 10 minutes it should lose its memory but if its got a ( rom ) read only memory chip it wont lose its memory :::good luck.
Jul 26, 2015 | Televison & Video
Loses channels when power turned off
Main system control memory IC fault. Replace it. contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
After the IC replacement, a memory initilization might be done.
Nov 22, 2014 | Televison & Video
Voltage Drop
Radio should have 2 power leads, one should be switched, (hooked to key switch) and one should be hooked direct to battery so you don't lose memory when you shut the car off. Someone hooked them both to the key switch.
Mar 18, 2014 | 2002 Ford Escape
My Technika TV model X22/14C-GW-TCD-UK loses all of its channels when I turn it off. I have to retune everytime I turn the TV back on, Any Ideas welcome, many thanks
All sets use a eprom in some form or another that stores the memory of what up/down channels are programmed into the memory of the set-I will presume no box is used in line with this set for signal---very rare for this problem to even happen---next try when turn on to direct enter a known channel and see if set goes there--then manually add it in the menu---if set does not lose that memory at worst you can manually add every channel one at a time.
Oct 30, 2012 | Televison & Video
Memory card corrupted
Try reformatting it by inserting into a card reader connected to PC. If it is indeed only a bad sector in the card then you will lose data but still salvage your card. Otherwise you will lose both card and data. Also, if you are using a linux OS then there are data retrieval methods available from corrupt cards as well. Kindly clarify OS.
Jan 27, 2011 | Computers & Internet
My TI89 wont turn on. My back up batery is no good and not in is this a problem?
The calculator must have a backup battery in. It will supply energy to the memory module when calculator is turned off. You may lose the content of the memory.
I do not want to sound dramatic, but you may lose the OS and you would have to reinstall it. Put fresh batteries and see if your calculator is still operable.
Hope it helps.
Dec 08, 2009 | Texas Instruments TI-89 Calculator
Tv loses stored channels
mains board need replacement, the memory chips are faulty
Mar 20, 2009 | Televison & Video
This is for the c713 kodak easy share, couldn't find it on the index.
YOU DIDN'T SAY, BUT I WOULD GUESS THAT WHEN YOU TURNED THE CAMERA BACK ON THE BATTERY WAS DEAD? THIS IS ONE POSSIBLE REASON TO LOSE MEMORY, EVEN THOUGH THE MEMORY CARD SHOULD HOLD YOUR DATA. YOU MIGHT POSSIBLY HAVE A FAULTY MEMORY CARD ALSO. ALSO REMOVING THE MEMORY CARD AND REINSERTING IT CAN SOMETIME CAUSE IT TO LOSE MEMORY. ALL POSSIBLES, BUT TRY USING JUST THE INTERNAL MEMORY OF THE CAMERA, WHICH IS SMALL, BUT SEE IF THE SAME THING HAPPENS DOING THIS. IF NOT, I WOULD SUSPECT THE MEMORY CARD IF IT HAPPENS MORE THAT ONCE. THEY DO FAIL ONCE IN AWHILE. THE KODAK HAS A SETTING THAT LETS YOU SELECT INTERNAL MEMORY OR SD CARD. TRY THAT AND SEE WHAT HAPPENS. IT'S BEST TO JUST GET IN THE HABIT OF DOWNLOADING PHOTO'S WHEN YOU GET BACK TO YOUR COMPUTER AND NOT TAKING A CHANCE AT LOSING SHOTS. I CARRY MY LAPTOP WHEN I'M AWAY FROM THE HOUSE FOR ANY TIME JUST FOR THAT PURPOSE.
Sep 16, 2008 | Kodak EasyShare C613 Digital Camera
Dewalt DC011 AM/FM Radio Logo
133 people viewed this question
Top Dewalt Audio Players & Recorders Experts
Gyula Lacz
Rob Beech
Are you a Dewalt Audio Player and Recorder Expert? Answer questions, earn points and help others
