Question about Ricoh Aficio 450 Copier
I have a white streak down one side of the page, what causes this and how do i fix it.
    Problem Solver:
  • 5 Answers
This proplem means clean filter of laser that called laser shield
Posted on Oct 13, 2010
Canon NP6221 makes copies black and white with black streak down middle. How can it be fixed--works well otherwise.
They are manny cause of black copy.
1.over tone.
2.arching on main charger or dirt on main charger.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Brother Printer Support
Feb 16, 2014 | Canon NP6221 Fuser Thermofuse
White streak down center of page
Remove the toner cartridge and while keeping it level, shake from side to side. Re-install and test. If light streak goes away then you are back in business. Keep in mind that this MAY mean your toner cartridge is getting low on toner.
Good Luck and Thnak You for using Fixya.
WheatlandServices
Oct 25, 2010 | HP LaserJet 1100 Printer
I've replaced the drum but it leaves a white streak down the page
Pull the drum out and wipe the narrow window inside that is over where the drum goes. It gets toner dust on it and causes that hind of problem, make sure the blue tab on the drum is moved over to the side with the little triangle on it.
Feb 02, 2010 | Brother HL-2040 Laser Printer
Large white streak through the page
there might be something wrong with the cartrige
Sep 30, 2009 | Brother MFC 9700 All-In-One Laser Printer
HP Laserjet 2820 Streaks on Page
There are 3 parts to the imaging process that could cause your issue. You have the toner (x4), the imaging drum unit (Q3964A) and the fuser unit. If you are getting streaks from all colors, one or more these parts are the issue.
Let's start with the easy stuff:
Open the cover as if you were replacing toner where you can "visually" inspect the toner and imaging drum. Pull the drum out and pull back the "plastic shutter" on the top, this will expose a green drum CAUTION! Too much exposure to light and touching it can cause damage. Just take a quick look trying to see if any of the lines on your page match any marks on the drum. Check the bottom half of the unit as well there should be a white section across the bottom, expect that as well.
Next look at the toner, if you can look at any other color but black it will help you look for the streak marks a lot easeier. If you couldn't see any streaks on the drum on toner cartridges, it's time to look at the fuser unit. Power the machine down and turn it around, unplug it then fold down the blue clips and CAUTION! the fuser heats the toner to the page so if it's been used recently it may be hot. once the clips are down, just pull straight back and look for the streak marks.
Sorry for the book, but I hope it helps.
Jul 30, 2009 | HP LaserJet 2820 Printer
Balck and white streaks on left side of paper
Usually if there are streaks you need to change the pcu that is the same color as the lines. If the streaks are gray it also could be the fuser, but i would think it is the pcu.
May 18, 2009 | Ricoh Aficio CL3500N Laser Printer
I have a white or faded streak down the left side of my prints
I had this problem once as well. Open the side door and remove the waste toner bottle. Behind it you'll find a little blue tab. Pull it out and you'll have a long strip with a window in the middle. I solved my problem by cleaning that window. I hope it works for you, too.
Jan 29, 2009 | Konica Minolta magicolor 2300DL Laser...
Pages printing blank
Resolving white, light lines or streaks (eliminate light stripes)
From the printer, print the Troubleshooting Print Quality Pages.
With Troubleshooting highlighted, press the OK button.
Scroll to Print Quality Problems by pressing the Up or Down Arrow button. Press OK.
Scroll to Troubleshooting Print Quality Page. Press OK.
Evaluate the Light Stripes Test page for missing printhead jets (missing cyan, magenta, yellow or black color bars).
Clean the maintenance unit's wiper blade and empty the waste tray. A dirty maintenance drawer wiper blade can cause white lines and weak or missing printhead jets. Using a clean lint-free cloth or a paper coffee filter, gently clean the blade with a wiping motion across the entire length of the wiper blade.
Dec 20, 2008 | Xerox Phaser 8400 Laser Printer
White Streaks down left side of page.
Shake the toner hard and try again. It should work.
Dec 11, 2007 | Samsung ML 2010 Laser Printer
Ricoh Aficio 450 Copier Logo
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
