Question about Cyberhome CH-DVD 300 DVD Player
I hit something now I can't see the video out of the player...How do I reset the factory defaults without being able to see the screen?
  • 30 Answers
It's impossible. because the problem is mother board in dvd player is damage.contact technician and solve your problem. thank you.
Posted on Oct 11, 2010
Why is it a error code on my screen saying something went wrong the error code is E2030000080C87AF000D
Use the Offline System Update Diagnostic Tool on your Xbox One to troubleshoot your error. You'll need to use a flash drive that's converted to NTFS.
How to use the Offline System Update Diagnostic Tool on Xbox One
If going through this process doesn't work, you'll need to reset your Xbox to its default factory settings. Do this by hitting the "Restore Factory Defaults" in Step 2 of the Offline Diagnostic Tool.
If that doesn't work, you'll need to send in your console to be repaired.
May 17, 2016 | Microsoft Xbox One
Factory reset
Use Default Settings If you want to return the initial language setting such as Language, Video, Audio and etc. to the factory default, do the following: 1) Press SETUP button. 2) Press / button to select Misc. 3) Press button to select Use Default Settings, then press ENTER button. 4) Press / button to select "Yes", then press ENTER button. The original setting will be restored. Screen saver : On Do you want to use default setting? Note When you reset the DVD player to the factory default, the DVD player will take 3-5 seconds to reset.
Oct 15, 2014 | Toshiba SDK990 Player
Can the sylvania video/mp3 player-smpk8854b be reset?
if you can navigate the screens you can, tap settings,default set, yes.
try reset on top of player if its acting up.
firmware is not available for these players.
Nov 24, 2009 | Sylvania Audio Players & Recorders
My creative Zen screen will only display firmaware problem momentarily when the reset button has been hit and it is then turned on. HELP!
Try plugging it into your computer and updating it's firmware if possible. Or, if you know how, reset it to factory defaults and then re-update it.
( Resetting to factory defaults WILL erase all the music and media you have on it, but at least it may work again )
I hope this helps.
Oct 17, 2009 | Creative Technology Zen MX Black (8 GB)...
Reset Toshiba SD-5000 Dvd player to factory defaults
With most Toshibas, you could un-plug them and leave it for either 10minutes or 30minutes and it would reset. strange, I know. give it a try.
I also found this when working on a similar problem with your player, it may be relevant -you could try pressing the power button and another button..
sorry, I don't have one in front of me to test..
[[power off the player
hit the power button and immediately hold the HDMI select button
the 3 HD indicator lights will cycle and then pushing the HDMI select button will move through the resolutions.]]
Aug 31, 2009 | Toshiba SD-5000
Router password
Unfortunately in most routers, you cannot actually find the existing password. If you have access to the router configuration, you can set a new Wifi password.
Using a wired connection to the router, you will need to find the "default gateway" of your computer. To do that, go to Start>Run, type "cmd" (without quotes) and hit OK. Type "ipconfig" without quotes and hit enter. It will give you the IP address and default gateway of your computer. Now, go to Internet Explorer or your favorite browser and type the default gateway address into the address bar (no WWW in front of it). Hit Enter on that. If it pops up with a username and password on that, you'll need to get that from whoever set up your wireless router. If it was you and you don't know the password, you'll have to reset the router back to factory defaults by holding the reset button on the physical router itself, while you plug the power in (that may not be the procedure - consult your router documentation for resetting to factory defaults).
If you did know that web password, you can get in and click on something like "Wireless Settings" and look for "Encryption" or something similar, and there will be a place to enter a new password.
Apr 16, 2009 | D-Link DI 514 Wireless Router (DI-514)
I just got a rockchip 2.8" 4gb touch screen mp4 player. The calibration on the screen is messed up. *what i touch isnt what comes up*. I need to find out how to manually reset the whole system back to...
all yo have to do is take a niddle or something skinny and push it in the side hold the hold is hard to see but it will master reset
Jan 04, 2009 | GPS
No picture
you have prbly changed the output of your device change the ports in the back(you might need to use a diff type of cable), or on the remote press the display button
May 28, 2008 | Cyberhome CH-DVD 300 DVD Player
Reset to factory defau;ts
Small print in the manual says to hold down the 100/P.Scan button on the remote to toggle between progressive and interlaced. This was after I blindly tried to follow the setup screens in the manual and found that the manual doesn't match the exact screens (must be a firmware difference?) in the manual.
Also found that the factory default instructions in the manual do not include a yes/no confirmation screen.
May 26, 2008 | GoVideo DV2150 DVD VCR
Blank Screen
There is an error in the manual. In order to reset to factory defaults, turn on (with no disc inside), DO NOT OPEN THE DISC TRAY, just press the stop button on the player for 5 seconds (some solutions say 20 seconds).
Aug 16, 2007 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
27 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
