Question about Saeco Vienna Espresso Machine
I have a Saeco Vienna, about 5-years old. When we took the brew group out to clean, it fell and split into a few pieces. We were able to piece it back together, but it must still be broken because there are red lights flashing, and the machine jams immediately upon pressing the brew button. Should I replace the entire brew group, or do I need to get a new machine? thanks.
    Champion:
  • 248 Answers
Replacing the brew group should solve your problem if it was working properly before the part was broken
Posted on Oct 12, 2010
How to remove Door?
Lift out the drainer by lifting upwards then pulling towards you. Pull the door from the left side and it will swing out. Pull out the brew group, if you want. Start cleaning.
Nov 28, 2011 | Saeco Vienna SuperAutomatica Coffee...
Hello my saeco vienna coffe machine leaks on the side when I make my coffee
Try changing the water inlet seal under the water tank (part # NM05.006)
May 14, 2010 | Saeco Vienna SuperAutomatica Coffee...
I cant take out the brew group of my saeco vienna espresso machine
have to make sure the group is in part. turn machine off and on should hear the motor go. if the group is stuck take the small screw out of group and will release piece thats on the injector. MUst hold the lever on the front of the group to relase the lock then gently pry it out .
Dec 12, 2009 | Saeco Vienna De Luxe Espresso Machine
I have a broken piece on my brew group, do i have to replace the entire brew group? i have looked at the brew group diagram to see if i can identify the piece, however, the brew group picture shows the...
There are only a few parts on the brew unit that are replaceable, you might have to get a new one check with servicesunlimited, they might have either the diagram or the part needed.
Dec 06, 2009 | Saeco Vienna SuperAutomatica Coffee...
Only half of a cup of coffee dispensed from Saeco Vienna
the trouble is the pipe that goes to the water tank follow it its hook to a white plastic sensor go in that piece and come out that the level sensor that broken that the first thing and most likely broken if not the circuit board
Apr 04, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Vienna De Luxe not transferring grounds to brew group?
Make sure there not comming any damp into the grinder and the grinder is dry. If there was some damp in the grinder then you have to clean the grinder.
Aug 07, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna delux
The brew group is out of place.
--> --> The brew group cannot be taken out.
--> --> Turn on the machine and close the service door. The brew group will automatically go back into place.
The brew group is out of place -Turn on the machine and close the service door. The brew group will automatically go back into place.
May 07, 2008 | Saeco Vienna Deluxe
Saeco Vienna wont turn on
dont worry if it was working good before the clean up the brew group is not install all the way in remove it push it in untill you here a click the brew group is not all the way in and doesnt push the on switch when you push it in wiggle it
THANKS FOR USING FIXYA
PIERRE
Feb 17, 2008 | Saeco Vienna Espresso Machine
Problem getting a Full Cup of Coffee
besides descaling you need to lube the brew group, especially the bit that accepts the group nozzle. You might have a leaking boiler too, 6 years is pretty good for a vienna.
Remove the brew group and look for the two red o-rings on teh brass bit, smear some lube on it, they might need replacing by now, but luckily they aren't too expensive and readily available albeit a bit tricky to install, a good light and some patience is very important.
Dec 14, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna Espresso Machine Logo
155 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
