Question about Gaggia Syncrony Compact Digital Espresso Machine
Something is up with the watre tank/spring. Even when filled the "no water" light shows and machine won't work.
    Champion:
  • 248 Answers
The water level mechanism is probably stuck.you can try wiggling or tapping on it if you can locate it
Posted on Oct 12, 2010
Trying to fill fresh water tank. Overflows in a minute
there is probably a stoppage in the relief opening. should be next to the potable water fill. are you trying to fill from the pressure inlet or potable fill inlet? if from the pressure inlet, there is a bypass valve by the fresh water tank to divert watr into it.
Jun 19, 2014 | Thor Motor Coach RVs
Water in tank but water light on
First, I'm not a Saeco technician. Though I've worked on similar Saeco models.
*** The following is for information only. You should always call your vendor for service, as opening this machine will void warranty.***
- Water not getting to machine or not sensing that the water tank is already filled.
* There usually some type of float near to middle of the water tank. It's usually white or colored plastic. This 'float' needs to move freely up-down to 'sense' the filled tank. clean the tank and shake it -note the movement of this float. It will need further cleaning if it's stuck (or you will have to replace tank if it's crudded up).
* Re-install tank and fill with filtered water. Turn machine off, count to 15 then turn on again. This usually turns on pump to add water to inner tank. If this does not happen then there is a CPU problem. If it does hums for 5-10 seconds then goes off but no heating then the pump may have an air bubble in line. Try the turn off and on method several times (up to 5) to get the water flowing. If it's still not working then there is a clog in the pump and will need service and/or replacement.
* Did you change water source? Since this is a table top machine in which you fill the water tank. Try to use filtered (bottled ok) water. Do Not use Distilled or 100% pure water as this type of water will eat out the metals from your machine! Some places use a water softener as it tends to be better for the machine long term (years).
* Still got problems? Check with vendor or MFR for service or replacement. Most machines of this type do not have serviceable parts or adjustments.
Aloha, ukeboy57
Feb 03, 2018 | Saeco Incanto Classic Espresso Machine
Washer adds water whilst extracting
The washer will add water in the rinse/pin cycle even while it is pumping out. This is to give the clothes a wash while spinning to remove excess soap suds. Could this be your problem
May 27, 2013 | Washing Machines
Onga water pump not pumping water thru to house
either water lock or motor burnt out ,
Mar 17, 2012 | Plumbing
Water light is on ,Water tank is full but the light stays on
If the water tank stays full it indicates that the pump cannot function properly.
Before first use, the Sirena pump needs to be 'primed'. This is indicated by the blinking blue 'water' LED. On a new machine (or a refurbished one as in my case), empty the water container first, then
  • remove the plastic water container
  • activate the small spring valve mechanism built into the bottom of the water tank.
    This plastic valve mechanism could initially be hard to depress, because the small metal spring is too strong, or the entire mechanism may be stuck altogether. Exercise this spring and the small valve a few times (ok: 10 times).
  • once the spring-loaded valve moves freely (it becomes easy to depress with your finger), the pump will have no problem activating the spring mechanism and starts sucking water out of the tank:
  • refill with filtered water almost to the top and observe the floating magnet (fill indicator) now in its UP position. You will have to refill the water after a few shots and using steam.
  • Press the ON/OFF button and open the steam knob clockwise all the way until you can hear the pump working and a steady stream of water escapes... onto the floor, or if you're smart, into a small container.
  • Once primed, the pump can operate and in turn, the machine starts heating up.
  • Now you can make your espresso, and even try the steam wand after it shoots out a short stream of water. Once you have steam coming out of the wand, you can start getting serious about making your brew...
I believe that a lot of problems, like failure to heat up, machine doesn't work, etc. are caused by this small spring mechanism being a little hard to operate initially. The Sirena is programmed to operate ONLY if it can extract water out of the tank.
Try it and enjoy the superb cappucino, espresso, etc. -the beautiful Sirena was born in Italy and is a little temperamental, but will be your best friend with a little help in the mechnical department (Think FIAT). By the way: I am a German engineer -no kidding.
Sep 08, 2011 | Saeco Starbucks Sirena Espresso Machine
Water wont fill washer. The water currently in
The pump is probably clogged with a coin. Pull off the hoses and check the pump. Make sure you put a pan under the hoses to catch the water
Jun 27, 2009 | Frigidaire Washing Machines
Fault
Found this online and the solution worked for me. Just fill the water container!
What if F 10 shows?
– No water can be pumped from
the water tank.
– F 10 also shows, if the water tank
was not filled correctly during
descaling.
– Fill the system with water. See "Before
using the coffee system for the first
time".
– Remove and reinsert the water tank.
– Refill to the mark and restart descaling.
– If the message still shows, contact
Technical Service
e.
Jul 10, 2008 | Miele CVA2650 Stainless Steel Espresso...
Kenmore top load washer leaks as it fills and drain hose is not an issue. There is a small hole in the plastic hosing where the two hoses meet, but why is water even getting to that point when it should be...
As the washer fills the water will go up the drain hose to the same height as the watr fills in the tub. That is why the drain needs to be higher then the tub or the water can just run down the drain.
Apr 25, 2008 | Washing Machines
Fill water tank warning stays on even when tank is full.
I've had this problem. Looks like its the float in the back corner of the water tank, which contains something magnetic that must trigger a sensor. I put a piece of plastic in the float chamber to push the float closer to the side of the tank. Be careful, if you jam the float (in the up position) then you may run out of water without any warning. Very annoying when you can't get your morning coffee.
Apr 09, 2008 | Saeco V-spresso Espresso Machine
Fill Watertank Message
The black thing floating in the water tank is a plastic shell with a magnet inside. If you clean it...make sure you reinstall it with the tapered (smaller) side down. There is a slight size difference BUT it will make ALL the difference in the world.
I had no idea there was a magnet in that black/greyish case. The direction of the casing is important.
I had the same problem and that solved it!
Jul 29, 2007 | Miele CVA615 Espresso Machine
Gaggia Syncrony Compact Digital Espresso Machine Logo
174 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
