Question about Frigidaire Refrigerators
What are the cut in and cut out temperatures for the wdf 25k-921-328 eg thermostat, which is fitted to the fre 2422a fridge freezer
Warm on 5 +/-1 warm off -10 +/-2 cold on 5 +/-1 colf off -25
Posted on Jun 09, 2011
I have a hotpoint FF72P fridge freezer. it comes down to temperature (-22/+4) without any problem, but after this the compressor won't cut in.
takes time for the temperature inside the fridge -freezer to normalize after doors are being left open
turning off a fridge freezer on and off wont help it
it takes time to for the thermostat to kick start the compressor
and more time to reach the freezing temp lost
if you are certain the thermostat is damaged
call in a service man
have the thermostat replaced and have them check
the gas in the system is running the correct pressure
Jul 31, 2016 | Hotpoint Refrigerators
Temperature sensors
I have an E402 fridge (403 litre model with freezer on bottom) . I just dismantled the freezer back wall due to a bad defroster element and noticed that on the back wall of the freezer is a small raised "cavity" or "slot" that the black thermostat fits into nicely. In my fridge, it is above the Collins coil and a bit to the right of centre(closer to the wire entry hole). Hope this helps
Feb 15, 2014 | Fisher and Paykel Active Smart E522B...
HOW TO ADJUST CONSTANT CUT-IN THERMOSTAT MODEL WDF 10A-111-122
Part number WDF10A-111-122, 01.D6249A.Z, 5(4) A 250V. Foshan Tongbao Co. is a Temperature (cool) sensor with switch; When it turn CW it drops temperature to cool, while turning CCW it rises water tank temperature.
Apr 17, 2012 | Cars & Trucks
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
Food freezing in Refrigerator Freezer ok. Westinghouse model wse6100wa. Have misplaced manual and need to know what temperature is correct and how to fix this problem.
There is a normal setting of the thermostat for the fridge and freezer and you can select the fridge setting to be lower than normal than what is set presently.
If there is no change then the thermostat is not cutting off the cooling and so there is no control of temperature within the fridge. Allow the lowest setting of the thermostat in the fridge section to confirm this fault.
Aug 18, 2011 | Refrigerators
Fridge compressor keeps working all the time
Check the thermostat bulb in the freezer section. If it is encased in ice defrost for 24hrs. If this does not correct it fit new thermostat, but take care not to damage bulb or tubing it is gas filled.
Apr 16, 2010 | GE Profile Arctica Stainless Steel Top...
My beko frost free fridge freezer is not switching on and off. it is running constantly and the fridge is now very cold on number 1 setting?
you would have to find out what temperature your freezer is. if it is reaching -20 then it should be cutting out and chances are the thermostat is stuffed
Apr 30, 2009 | Freezers
Freezer and fridge to cold setting does not seem to work
the thermostat faulty or sensing piece not against the evaporator.check that the thermostat supplied is for the right fridge.eg:that is not a freezer stat that is installed in the fridge compartment.
Nov 05, 2007 | Fisher and Paykel Active Smart E522B...
Refrigerators Logo
235 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
