Question about Acer AL1711 17" LCD Monitor
Acer al1711 shows only a white screen
I searched for this problem on FixYa and I only found troubles with the backlight or the inverter causing a dark screen showing a faint display. My problem is completely different.
I have a al1711 which shows a totally white screen. The monitor reacts on the energy saver and turns off when Windows tells it to do so.
When I press on the "auto" button on the front of the screen, no display is showing "Auto confi please wait". Pressing the menu also doesn't give any result.
I hope you can give me a solution to save this monitor.
  • Anonymous Jun 20, 2008
    321
    613
    21
    32
  • salesars Aug 13, 2008
    I'm having the exact same problem with the exact same screen. Brand new. Have completely pulled it apart but can't find anything out of the ordinary. I was looking for dry solder spots but found none. Not sure where to go from here.
  • Acer Master
  • 5,568 Answers
These are pretty old now but I'll respond anyhow-
When there is absolutely no screen content and white, it means that ALL pixels are turned off; black, means all are turned on. If you have a white screen, it means that a component in the video stream has failed; a black screen (preferable failure!) often means that the backlight lamp or its inverter have failed. The latter is a potential DIY fix, a dead IC in the video path normally not since most of the signal chips (ICs) are placed and soldered by robots and the pin spacing on those is pretty much beyond the capabilites of an untrained hand.
The only exception I can think of is if the ICs no longer have voltage supplied to them from the main power supply but you would need at least a cheap multimeter to locate that.
Posted on Sep 17, 2008
Why my tv have dark screen
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
May 05, 2015 | Sharp LC-32SB24U 32 in. LCD TV
Acer AL1711 17" LCD Monitor showing white screen
A white screen indicates the power supply board is not putting out the correct voltages to properly power the monitor, just the back light. This type of issue is caused by a failure of the filter capacitors on the power board. You can rebuild your power supply board and bring the monitor back to life by just replacing the the bad capacitors. The problem is that model the Acer AL1711 could come with 1 of 4 different power supply boards install depending and the date manufacturer and supply on hand. If you want to repair the monitor if you could open the unit and get either the model number of the power supply board or send a picture of the board to me I will be glad to help you repair the unit and get it back up and running. You can contact me to send the information at tech@ccl-la.com
Nov 30, 2012 | Acer AL1711 17" LCD Monitor
Acer AL1711 monitor it almost too dark to read. have tried to adjust brightness etc. nothing seems to work. any help would be great. thanks
You probably have a back light problem. This is caused by a faulty inverter board or a faulty CCFL lamp.
LCD screens and Inverters are available from these WEB sites. www.lcdparts.net http://www.yallstore.com
Jun 29, 2011 | Acer AL1711 17" LCD Monitor
My Acer AL1711 goes black but the light indicator on..i've read some of comment similiar to my problem and tried to repair it..but still..it didn't work..i even replaced the 1000uf capacitor..but...
When you repalce the caps, they should be repalced in a set since bad caps can look normal but can have high ESR.
http://s807.photobucket.com/albums/yy352/budm/ACER/Acer%20AL1711bm/
And yes, you can have bad lamp assembly:
http://s807.photobucket.com/albums/yy352/budm/Bad%20backlight%20lamp/
You need spare lamp the test the inverter board.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
May 20, 2011 | Acer AL1711 17" Flat Panel LCD Monitor
Acer al1711
We have repaired a couple of these. R1 on board normally burnt also C6 and C22 bad on inverter board. Replace these and it will probably work. R1 is 10 ohm. Capacitors are 220uf 25v.
Nov 07, 2008 | Acer AL1711 17" Flat Panel LCD Monitor
Al1711 Problem....
White screen is normally a problem with the LCD panel,generally difficult to repair
Samir.
Oct 25, 2008 | Acer AL1711 17" LCD Monitor
My acer laptop screen is dark
If your laptop screen is dark, it could be the backlight,inverter, or bad lcd. You can test the backlight by starting the laptop and give it a few seconds to load and take the laptop in a dark room and shine a flashlight on the lcd and see if you can see any pictures or icons. If you can, you may just need an inverter to correct the issue, If not, you may need to replace the inverter and lcd both.
If you find that you need parts to correct the issue. I would suggest that you begin with replacing the inverter first, as they are usually less expensive.
If you can supply me with the model number of the specific laptop you are having trouble with and I can try to locate more information on replacing the parts.
Thanks
Jul 23, 2008 | Computers & Internet
ACER ASPIRE LCD TROUBLE!!
If the screen appears dark with only a faint image or picture and the brightness can't be adjusted then it is likely that the screen backlight is not on - the backlight is like a very thin flourescent tube that runs along the bottom of the screen and provides the illumination. The backlight tube may be faulty or the small electronic inverter unit that powers the backlight tube may have failed. Occasionally the backlight is off because the little switch that is used to detect the screen lid being closed is broken or stuck in. If your backlight is faulty, some engineers will replace it - but it is more common that the entire screen is changed. If it is the inverter they can usually be replaced from ebay.
Mar 15, 2008 | Acer Aspire 1304LC PC Notebook
Acer 3690 Notebook/laptop computer
Carefully open the screen lid and look at the back of the screen there is a type number [like LTN15ox3] you can then obtain a replacement screen from ebay searching for this type number.
However if the screen only shows a faint dark image the fault could be the screen inverter that powers up the backlight tube in the screen.
Mar 14, 2008 | Acer Aspire 3690-2196 Notebook
Acer AL1711 17" LCD Monitor Logo
324 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
