Question about Koiiler XM-8787C Car Audio Amplifier
Hi... When I adjust my radios balance to full right or full left, it gives far stronger bass then it would if the balance were dead center.... When it is centered, there is very little bass......and music sounds crappy... I have the koiiler xm-8787 1000w 2ch amp... Music sounds nice and clear with strong bass when i switch the balance to full either side.
Mine is doing the same thing one hits harder than the other any known causes send an e-mail dirtydog98006@aol.com
Posted on Jan 22, 2011
  • 20 Answers
Speakers are "out of phase", meaning that one side is wired correctly and the other side is not. the easiest way to fix this is to just switch the wires on one side, by "switching" the wires i mean the positive and negative wires on the speakers/box? hope this helps, dave
Posted on Oct 11, 2010
How to adjust balance control on Marantz sr66 receiver?
As you rotate the control, you should feel a "notch" at dead center where left and right speakers are balanced. If channels are not balanced, you will have to rotate the control either left or right of center.
Apr 29, 2017 | Marantz Audio Players & Recorders
I have a Phillips RC604 stero in my hyundia 99 model and the balace has shifted to the rear while cleaning the car iand i cant figure out how to get to balance setting
press the mode button it puts you in touch with the operations loke balance front rear , left right, bass, treble etc and readjust the balance setting
Apr 22, 2017 | Cars & Trucks
Hi there I have an RAB030F clarion stereo in the car i just bought and no one can figure out how to change the time...any suggestions?
Setting the Clock
:$To turn the Power off, Press the POWER button ,) press and hold the BAND button a,wh ile
again. pressing the Function button 1 a to enter
2) Use the Up and Down buttons to adjust the clock display mode.
the volume. 2) Press and hold the BAND button m, while
A : Increases the volume. pressing the Function button 1 for 2 sec-
V: Decreases the volume. onds or more. This enables clock editing.
,#A Ci'4UTlOM
Audio Mode Adjustments
1) Press the AUDIOMODE button to select
the adjustment mode. The mode switches as
follows each time the AUDIO MODE button is
When this unit is turned on, starting and stop- pressinq the Function button 1 at the same
pressed:
BASSrrREB + BAUFAD -B Previous mode
2) Use the Left and Right and the Up and Down
buttons a, to adjust the bass and treble.
-=Adjusting the bass>
bb : Bass gets stronger.
4: Bass gets weaker.
-=Adjusting the treble:,
A: Treble gets stronger.
V : Treble gets weaker.
3) Use the Left and Right and the Up and Down
buttons a, to adjust the balance and
fader.
<Adjusting the balance>
W: Sound from right speakers gets stronger.
44: Sound from left speakers gets stronger.
<Adjusting the fader>
A: Sound from front speakers gets stronger.
8 : Sound from rear speakers gets stronger.
*The editable fields will be indicated by flash.
3) To move between the hour and minute fields,
use the Left (hour) and Right (minute) buttons
a.
4) To.store the clock setting, press the BAND
button a.
Aug 16, 2010 | Clarion RAB030F
How to adjust the dead key in a uniden pc78ltw
You change the dead key with the addition of 2 components to the board. There is no dial or pot inside to turn to adjust the dead key.
What you want to do to the radio is called a swing mod. If you are trying to adjust your dead key, it sounds like you are trying to run a linear amplifier. If that is the case, you should probably set your dead key to around 2 watts. Most amplifiers are good with 2 watts. If this is so, then do this:
Go to radio shack and get a 1/2 watt 100 ohm resistor, and a 100uf 35 volt electrolytic capacitor.
Open the radio and look for JV117. It is a jumper. It is located in the back left of the radio in front of the final resistor in front of the heat sink.
Use a de-soldering wick to remove the solder from the trace side of the board. Remove the jumper.
In the jumpers place put the capacitor. Make sure the black tab is facing the back of the radio, towards the final. This is very important because there is a positive and negative to the capacitor. If you do it backwards you can blow your radio.
Solder in the capacitor, then take the resistor and on the side you soldered, solder the resistor bridging the 2 pins of the cap on the trace side of the board.
How this works:
The resistor determines the amount of dead key. the bigger the resistor, the smaller the dead key, the smaller the resistor, the higher the dead key. (dead key will only go as high as it was before you put in the mod.) A 100 ohm resistor gives you about a 2 watt dead key.
ALSO! you are going to want to find VR4. Its a little pot towards the back right center of the board. Then turn it all the way to the left. This turns up your modulation, and will make the radio swing to full PEP wattage, around 20 watts.
If you have a watt meter that reads avg wattage then you can gain more wattage by adjusting L14. It is just right of VJ117. it is a white or brown plastic tank with a copper coil around it with a slug in the center covered by a little way.
*do this only if you have a meter, also, do not transmit on your radio without an antenna connected or a dummy load or you will blow the final.*
Remove the wax and then while saying a steady ahhhhh sound, slowly back out the slug until you have peak wattage,(when the needle no longer increases.) You do not want to back the slug out any more then is needed for full wattage, other wise you over bias the final and lessen the life of it. So once the needle stops going up while giving a steady ahhhh into the mic, back it in a hair just to make sure its not over biased.
And as always, if you are not comfortable doing this your self, take it to a radio tech at a radio shop. They are usually found at truck stops.
Oct 15, 2009 | Uniden Radio Communications
Sony radio cdxgt210
Use the main control knob. The one that turns your volume up and down. If you press it in it should go through bass, treble, fade, balance, and sub. Then use that same knob to adjust it by turning it left or right.
Jan 20, 2009 | Car Audio & Video
How the heck do I adjust the radio sounds (Bass/Treble)??
in newer sound systems they usually have an button that says audio with push of the button it should give you options of adjusting balance fade bass treble etc.
Aug 27, 2008 | 1999 Porsche Boxster
How to adjust treble and bass
At the lower left of the unit, just right of the power button is a button marked LD, with A-M below that. Push this button and the display will say BATT, then, in a couple seconds it will display 2 numbers. The left number is the bass and can be adjusted with the select arrows (left & right arrows). The right number is the treble and can be adjusted with the volume arrows (up & down arrows). If you push the LD button once more, it will display BAL, then 2 numbers. The left is the left-right balance & the right is the front-back balance. They can be adjusted in the same way with the arrow keys. Hope this helps someone.
Jun 11, 2008 | Clarion RDB325D
RX-V2090 Bass Output Problem
A couple things to check on the no bass problem:
1) Make sure your center speaker is set for normal, not large.
2) Make sure your speakers wires are in phase (+ conn. to + and - conn. to -).
Jun 23, 2007 | Yamaha RX-V2090 Receiver
Koiiler XM-8787C Car Audio Amplifier Logo
91 people viewed this question
Top Koiiler Car Audio & Video Experts
xxxxxx xxx
Are you a Koiiler Car Audio and Video Expert? Answer questions, earn points and help others
