Air Conditioners
Problem for Air Conditioners
Generic problem for all Air Conditioners
Blower fan keeps shutting on/off,
By greschak88 on May 31, 2008
I have a central air unit (goodman, 4years old) the blower fan keeps shutting off and on, however the condensor unit outside stays on? Could it be the thermostat, if so why is the outside unit still running? Or bad blower fan? or something sending the signal to shut on and off? The house is cooling, the outside pipe is cold too? Please any help???!!!
Thank you
Same Problem
Aug 16, 2008
-   Blower fan keeps going on then off then on intermittently-   mjnappe
Aug 04, 2008
-   My air conditioning unit runs, however, the fan in the furnace is not blowing the air through the ducts. It doesn't seem to be running when I test it by turning the heat on either. Advice?
I have never conducted any preventative maintenance on my air conditioner. Oops. -   jentschida
Jul 24, 2008
-   having the same problem, but when I put the fan in the on switch, it is still turning on & off. -   Guest
Jun 02, 2008
-   have the same problem with my air conditioner.-   m40milw
Solution #1
posted on Jun 01, 2008
Somewhat Helpful)
fixr1st
Rank: Wiz
Rating: 84%, 67 votes
Try putting your fan in the on not auto position and see if your outdoor condensing unit cycles on and off. If it does you might have a defective time delay relay to blower. If not your contactor might be stuck or your thermostat could be defective.
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
22yooper
Rank: Guru
Rating: 87%, 759 votes
Your blower fan turning on and off shows your thermostat is working. I am willing to bet you have the fan in the automatic condition. Check for a sticking contactor at the outside unit.
Was this helpful?
Yes
No
Solution #3
posted on Aug 02, 2009
Not Rated)
alexofarden2
Rank: Apprentice
Rating: 0%, 0 votes
could B a bad ground or a bad wire connection, make sure theres no lose wire connections, clean contacts a conections.
Was this helpful?
Yes
No
Popular Solutions for Air Conditioners
Questions and Unsolved Problems for Air Conditioners
Answer
Looking to replace a 20 yr old Weil-McLain with a dependable, efficient oil-fired boiler for a... (More)
Answer
Our Quality: We believe that our customers should receive the highest quality Hp dv1000 battery at... (More)
Answer
system reading p8 code on thermostat . Will run fine cools room but goes of on code p8. thank you
Answer
Air conditioner mini split Frigidare FSE12CM6A very noisy. It is inside the cabinet that goes inside... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioner Experts
Top Air Conditioner Repairmen
in , IL
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
