Question about Tappan TGF363 Gas Kitchen Range
My Modern Maid oven's alarm won't stop beeping when plugged in and the entire digital display lights up. What's wrong?
4 Suggested Answers
  • 76 Answers
SOURCE: Dim Digital Display
Connie P, Unfortunately it is not possible to make the display brighter. The only solution is to replace the entire clock/timer. The price for the part is less then a hundred dollars and if you will give me the complete model number and a color, I can help you to find the best deal. Gendos...post back
Posted on Jan 07, 2007
mgprice
  • 744 Answers
SOURCE: GE oven functional code F1 appears.
Hello, I come across this problem quite often, The f1 error code does not always follow that it is a bad EOC (Electronic oven control) This could also be a problem with the touchpad. The way to figure which is bad is turn electric off, access the EOC and pull the wire harness/ribbon tape for the touch pad. Reassemble the range and switch power back on. If you are still getting the F1 it is the EOC..If the F1 clears then your problem is with the Touchpad. If you have any other questions please feel free to comment again. Good Luck!!! Mike
Posted on Aug 18, 2009
SOURCE: modern maid double built in oven. gas stove. pilot
it"s a built in range top, and started making clicking noises randomly
Posted on Oct 17, 2010
Why Does Fault Alarm Beep at End of Cycle?
Check any user friendly ports, filters, screens. It appears that the washer is trying to tell you something. See your manual for troubleshooting. BLEEP BLOOP
Mar 10, 2014 | Haier HDP18PA Stainless Steel...
I push the bake button for the lower oven and it begins to beep and displays a F9 on the digital display
Hi
F9 is a door lock error and to solve this issue you can hold the light switch for 15 seconds, this will reset the control. If it won't work then hold the light switch in and set the unit to clean and after a minute press cancel to cancel the clean cycle. If still it won't work then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 01, 2011 | Amana ACB6260A Electric Double Oven
Model KHMS155RSS microwave is not heating food after the maid service cleaned the microwave
Hello, does microwave have power? Plugged in etc, lights working on front? All microwaves have a safety backup, the door may press onto a latch which will allow the microwave to work, this is to ensure that if you open the door during cooking, it will stop immediately so you're not exposed to microwave radiation. Maid may have disrupted the mechanism for this purpose, make sure door latches are OK, and door closes smoothly, also try unplugging and then plug it in and turn it back on. Hope this may help..
May 22, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
1989 Magic Chef gas range digital display keeps beeping and says
This is a common failure in the control board. Here is an article that discusses the details.
http://www.fixyourboard.com/techzone/ovens/f1_error/f1_error.html
We repair a lot of these at www.fixyourboard.com, so you don't have to scrap out your oven.
Jun 26, 2010 | Magic Chef Kitchen Ranges
Modern maid double built in oven. gas stove. pilot light won't stay lit
Dec 13, 2009 | Tappan TGF657 Gas Kitchen Range
Modern Maid Wall Oven DGO757 ignitor gets orange,but does not fire oven.
HI, there are gas valve coils that initiate the opening and closing of the gas valves. these coils will become unstable overtime. if the coils are malfunctioning, it will cause the symptoms you are experiencing with your oven at this time. i recommend replacing the failing gas valve coils asap if possible.
It should be two or maybe three coils that are attached to the valve assembly(burner assembly). they are black and, cylindrical in design. replace these coils.
Jun 10, 2009 | Ovens
What does an err code E03 mean?
the sense is bad, unfoturally the unit need to be replaced.
Nov 24, 2008 | Kidde Nighthawk Combo Gas/co Detector
Tappan TGF363 Gas Kitchen Range Logo
173 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
