Question about John Deere Garden
John deere fuel tank. how to remove - John Deere Garden
  • 8 Answers
SOURCE: ust changed the fuel pump on John Deere 6300 and will not start
Can you hear the pump run when you turn the switch on? If so, you have installed the pump correctly.
There could be an air lock...... there should be a handle somewhere for a manual pump you can loosen a fuel line connection and pump until the bubbles stop and all fuel comes out.
Posted on Feb 21, 2009
SOURCE: Hello. My John Deere mower has started surging at
I have a john deere 420 rider. It would surge at a higher speed. It is a hydrostatic and there were 2 bolts on the transmission that were loose. now it runs beautifully smooth,
Posted on May 04, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
nova2nv
  • 197 Answers
SOURCE: I have a John Deere 116 not getting gas to the filter or carb
Fuel line is pinched between fuel tank and frame.You should see the line coming down the rear side of tank,grab it and see if its free to move.
Posted on Nov 14, 2009
SOURCE: John Deere 5420 has no fuel from tank to filter
John Deere and it's lack of engineers, located the fuel tank below the engine/filter assembly, so it won't gravity feed. The little pump in the top of the fuel filter is worthless. The easy fix is to install an inline diesel fuel pump with a overpressure line off a blank fitting from the fuel filter, which will allow excess pressured fuel to flow back to the tank. What I did was install a fitting with a fuel hose about 2 feet long that has a lawn mower fuel cut off, with a section of hose after it, that can be plugged, when not used. Anytime fuel prime is lost to the filter, then it's a major effort to get it back. This is the cheap way. If you disconnect your fuel line the fuel flows all the way back to the tank, however I believe there is a check valve located underneath the tractor, before the tank, which keeps it from going all the way back. Anyway, I use a large cc syringe to pull fuel up to the filter. After each pull, I close the lawn mower shut off to keep the progress. Empty the syringe and then open the valve and pull some more. Once you have plenty of fuel to the filter, then I close the red fuel shutoff on the back of the fuel filter (closes the line to the tank). Then I push some fuel with the syringe toward the injector pump, while cranking the engine. At this point you don't want it to start, because you will pull all the fuel from the filter, because the red shut off is closed on the back of the filter. After only one or two "pushes" , then close off the lawn mower shut off, open the red shut off on the back of the filter, and crank. Mine usually starts about 5-15 seconds from starting to crank. DON'T CRANK TOO LONG, THE BOOK WARNS ABOUT OVERHEATING THE STARTER. What stupid engineers designed this? Hope this helps. As a side note the fuel hose off the tank is one size, and then it goes through the check valve and changes to a smaller diameter, to go to the filter.
Posted on Sep 25, 2010
John deer L100 is not getting fuel an fuel does not stay in fuel filter it drains back to tank
Sounds like the vent on the fuel tank isn't opening. Check the tank cap to see if there is a clogged vent.
Mar 22, 2012 | John Deere Garden
I put the wrong fuel in the gas tank on a John Deere lt160.. Need to drain
Disconnect the pipe from the bottom of the tank or the inlet to the fuel pump and let it drain out, or use a tube to syphon the fuel out.
Jul 10, 2011 | John Deere Garden
Just changed the fuel filter on a John deere 1020, is there a way to prime the injector pump?
If the fuel filter is full when replaced it shouldn't be necessary. But if you have access to compressed air, put air to the fuel tank and that will do it. Hope that helps ya.
Dec 21, 2010 | John Deere Fuel Pump Fits 1020 Thru 4230
How to repair a gas line on a sst18 john deere lawn mower
make sure the tank is empty and then remove the clamps holding the line on the tank and the carb take the whole thing with you to service center and ask for a direct replacement for your fuel line (may also include a fuel filter)...good luck
Apr 07, 2010 | John Deere Air Cleaner Bowl For Tractors
John Deere 6420 shutting off
Take apart fuel line around tank and blow out. Might also be something in tank that is getting sucked over the outlet. Clean out fuel tank
Feb 23, 2010 | John Deere 6300,6300l,6400,6400l Tractor...
John deere 445 with 22 hp kawasoki engine wont run take 1 plug out it runs dont mater what side stick finger in plug hole engine shuts off ,but wont start with both plugs in
Remove fuel cap to see if there is alot of fuel spraying back into tank.I have replaced ALOT of fuel pump hoses that have split between pump and sender clamp inside of tank.Lack of fuel pressure creates a very lean condition with the injected models.
Sep 03, 2009 | John Deere Garden
I have a John Deere/Scotts/Home Depot 20 hp B&S 48"deck. Stalled out - no gas. Changed filter and drained tank - blew out line into tank - stalled again. Checked fuel pump - line was cracked - cut and...
The easiest way is to not remove the tank. Buy a can of chem tool the liquid,not spray.Drain gas out of tank,pour can in tank,let sit for 15minutes,then drain,should clean it out good.
Aug 09, 2009 | John Deere Garden
Garden Logo
434 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
