Question about Philips 50PFP5332D 50 in. Plasma Television
Philips has a split screen - Philips 50PFP5332D 50 in. Plasma Television
Split screen
either you have the PIP engaged (two different pictures) or if same picture twice a digital issue in the set.
Look for PIP and turn it off or if a swap button see if it swaps the pictures--will tell you if PIP is issue or not.
Jun 07, 2012 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Split vision screen
This is a rear projection set (model indicated) but need a better description of the issue--colors skewed? screen wrong color?
Jun 06, 2012 | Philips 60PP9363 60" Rear Projection...
Picture comes on for split second
Hi.
Are you sure this is not on somthing like hide screen mode?
I am not responsible for any damage.
-K.R.
"I know what I know because I know what to do!"
Feb 07, 2010 | Philips 42 in. Plasma TV
When I plug in my DVD player, my Philips flat screen shows a split screen with 2 pic and pscan yellow warning in the middle of the screen and wont go away
There is a progressive scan on and off switch on the back of your dvd player. Turn this to the off position.
Jun 22, 2008 | Televison & Video
Tv split screen
This can be the screen itself, or the drive board, or a bad ribbon cable assembly for the screen operation.
The set will have to be serviced by the authorized service rep.
Jerry G.
May 27, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
Screen split into 2 colours - vertical split
I think it is degaussing problem if any thing is lying which has magnet please remove it. &then put of monitor for 15 minutes & then put on again.do not move when it is on. please let me if it gets ok good luck
Sep 09, 2007 | Philips 170B4MG 17" LCD Monitor
Philips 50PFP5332D 50 in. Plasma Television Logo
60 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
