Question about Qep Tile Tools 83200 24inch Bridge Saw
The water doesn't seem to be pulling from our reserve to the hoses that lead to the tile and blade area...any thoughts?
  • 29 Answers
I like to put my pump in a water bucket under the drain plug assembly,this keeps the pump\water cleaner from ceramic sludge,you might have to get a longer peice of hose,works great
Posted on Jan 18, 2011
Looking for the blade guard arm.
Search Results
    7" Job Site Tile Saw with Laser - RIDGID Professional Tools
    https://www.ridgid.com/us/en/7-inch-wet-tile-saw-with-laser
    Ridgid7" Job Site Tile Saw with Laser. ... Heavy Duty Arm - prevents flexing while keeping the blade aligned; Guard Baffle - reduces air turbulence to help keep water ...
    [PDF]7" BRIDGE TILE SAW
    manuals.harborfreight.com/manuals/97000-97999/97360.pdf
    7" BRIDGE. TILE SAW. WITH STAND. Owner's Manual & Safety Instructions. Save This Manual .... that has an outlet that looks like the one illustrated above ... Use saw-blade guard and spreader for every .... arms and shoulders. To reduce the.
    [PDF]10" INDUSTRIAL TILE/BRICK SAW Owner's Manual ...
    manuals.harborfreight.com/manuals/69000-69999/69275.pdf
    parts. Nonslip footwear is recommended. Wear protective hair covering to contain long hair. 11. ALWAYS USE ... an outlet that looks like the one illustrated above in Figure A:... For Your Own Safety Read Instruction Manual Before Operating Saw. 1. Wear eye ..... Connect the clear water Hose from under the arm of the Motor ...
    SKIL 7" Wet Tile Saw 3540
Dec 16, 2015 | Blade Saws
Why is the pumpo not pumpin water to tile saw
Take the hose off the pump, put it in water and turn it on. If it moves water, look for a blockage in the line and nozzles leading up to the blade. If it doesn't move water there may be a small peice of tile or enough of the tile 'mud' in the impeller that it can't spin. Depending on what type of pump you have, if you can, take the cover off the impeller and remove anything that would keep it from spinning. If it does not come apart you may have to force water through it backwards in an attempt to flush out whatever may be in there. If it won't come out sometimes giving the pump a firm wack on the side will knock things loose.
Dec 31, 2011 | Saws
I have a wts2000l and i have noticed that it is burning through blades. The water is pumping through but isn't hitting the blade at all. The water is spraying in opposite directions, I can't seem...
you just have to lift the blade guard and tweek the direction of the outlet, point them so they're spraying towards the blade. Not right at the blade but just so they're getting plenty of water spraying onto the tile. Don't put a bucket and catch the water "over flowing" from the tray, just drain the pan and put the bucket under the drain hole to catch the water. A lot less messier that way.
Aug 05, 2011 | Ridgid Wts2000l 10" Wet Tile/stone Saw...
My felker tile master xl is cutting out of square
A dull blade or lack of water will cause this issue. Instead if cutting cleanly,excess friction will cause the blade to ride up the sides of the cutting channel. This action pulls on the tile causing an un-square cut.
Feb 02, 2011 | Saws
Cannot keep water on the blade of my 10" Rigid wet
if waters not getting to the blade you will see the powder of what ever your cutting coming off the back of machine,i like to put my pump in a bucket of water under the drain plug instead of puting the pump in the water tray,you can run bigger tubing up to the blade and reduce it down and it will give you better presure,good luck
Dec 31, 2010 | Ridgid 10"Wet Tile Saw with Laser and...
Applied dark brown glass tiles and those that were cut with a wet diamand blade saw are darker in colour to the others. will cut tiles become the same colour as other non cut tiles?
THIS COULD BE CAUSED BY 1 OF TWO THINGS, WHEN YOU USE WATER TO CUT ANY TILE YOU ARE INTRODUCING WATER TO THE INSIDE OF THE TILE WHICH WILL CAUSE THIS DARKENING OF THE TILE, 2ND WHEN YOU WET CUT USE A SLOW LITE PRESSURE LET THE BIT DO THE WORK TO MUCH PRESSURE AND NOT ENOUGH WATER WILL CAUSE OVER HEATING AND DARKEN THE TILE. HOPE THIS HELPS. ALSO
THIS DOESN'T ALWAYS WORK BUT AFTER CUTTING PLACE TILE IN A HEATED AREA TO DRY OUT THE WATER ,THE GLAZING IS WHAT PROTECTS THE INSIDE
Dec 01, 2009 | RTO 1/8"wet Diamond Glass, Tile, Stone,...
Ridgid Wet Tile saw water pump operates, however the water is not getting directed onto the blade. Hose partially plugged? How to clean nozzle?
You could clean the hose ... however, I think Id get to the hardware store and get a new piece.
Clean the end with a broom straw. You could trim a small piece of the hose off. Dont neglect to clean the filter on the pump. Slide the bottomoff the pump to expose the filter.
Oct 21, 2009 | D Cut CS-070 Wet Tile Saw
The saw in not pumping water
I have came across to possible solutions with other tile saws in the past. One is that your pump could have picked up a small piece of tile or sedement from the basin and got stuck in the water port where it comes out on to the blade. The first thing I would try is to disconnect the hose frome the blade shroud while saw is off. **** on the end of the hose until you get water. Sometimes the line needs to be primed and filled with water. Once you get water you can turn the pump or saw on while disconnected to see if water flows. Keep loose hoses away from blade though! If nothing then try the blocked port. Good luck
Dec 03, 2008 | Mk Diamond MK - 170 Wet Cutting Tile Saw
Qep Tile Tools 83200 24inch Bridge Saw Logo
209 people viewed this question
Top Qep Saws Experts
JOHN LAPIER
Terry Hair
Tim Marx
Tim Marx
Are you a Qep Saw Expert? Answer questions, earn points and help others
