Question about HP Officejet 6310 All-In-One InkJet Printer
Strip wire unplugged in hp officejet 6310 - need diagram to locate where they plug in - thanks
  • jg99928 Oct 12, 2010
    I need a WIRING DIAGRAM, not the basic consumer manual, which I have. Please, do not send "canned" non-solutions ! I need to know where the 2 narrow flat wires CONNECT to the top portion of the printer - thanks !
  • jg99928 Oct 14, 2010
    Need witring diagram or instruction where 2 flat wires connect to top section of the 6310 printer, NOT USELESS non-solutions like: the owners manual, which I have !
    Thanks !
  • 1,472 Answers
Jg99928
To clarify with you has your power cord ben damage or do just need to know where to connect it on the printer?
Note look at the picture below you should have an AC Power Brick with your power cord. With your most of your modern electronic devices the power cord plugs intto the AC Power Brick and this is what connects to the device. This is done so that the same printer can be made for different parts of the world and all they have to change it the cable that plugs into the AC Power Brick.
Hope this helps. Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on Oct 15, 2010
  • 3,083 Answers
I once worked at Best Buy and while there as a tech, found out HP doesn't really provide service manuals, and they only supply parts and schematics to Authorized HP Dealers and repair facilities. This requires most people to send their units in for repair. What this translates into is that one has to disassemble and fix the printer on their own, and kind of using the take apart and figure it out as you go routine. Never fun, or easy, but it's the way it is.
I'm assuming you're talking about the ribbon connector, and that will go from the print head movable assembly to either a sub board or the main board in side the machine.
Some printers use torq security screws to discourage disassembly and repair, not sure if these do.
Depending on how mechanical you are, you might be able to reconnect it. You will recognize the plug for the ribbon connector when you see it, and it will go on two ways, but the physical structure is usually obvious.
If you run the printer in to a computer repair shop, they may be able to give you some ideas to assist in the disassembly.
Good luck, and hope this helps.
Posted on Oct 13, 2010
I have hp officejet 6310 all in one, but the
Please visit- http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&product=1119598 and download the full feature drivers and save it on your computer.
2. Uninstall the existing driver from program and features under control panel.
* To search for progam and features, Click on start or the windows vista logo on left bottom, click on control panel, clck on program and features and then unistall the printer driver.
3. Power off the printer and unplug it from computer.
4. Install the printer from the saved drivers and plug it when asked.
Restart computer once the installation is compete and hope the scan would work after this.
Mar 24, 2010 | HP OfficeJet 6310 All-in-One Printer...
I can't get my HP officejet 6310 All-in-One to turn off
This model takes an extremely long time to shut down.
I have had mine on for 2 years. because it takes way too long to start up and shut down. Still works fine.
If you really really want to power this unit down.
Purchase a strip plug with power buttons for Monitor, CPU, Printer and Device 1 and 2. Shut down the PC normally then hit the Printer button on the strip plug. Viola printer off no worries.
Oct 03, 2009 | HP Officejet 6310 All-In-One InkJet...
Cant install the software disc is bad
Hi!
You can free download the drivers for your HP Officejet Printer 6310 from the following link---
HP Officejet Printer 6310 Drivers
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 14, 2009 | HP Officejet 6310 All-In-One InkJet...
I need to install my HP Officejet 6310 All in one printer and do
helllo
in order to resolve the issue
unplug the printer
go to this link
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&product=1119598&lang=en
then click on
HP Photosmart Full Feature Software and Drivers
which is 298 mb
first save it and then run it
when it prompt to plug the printer then only plug your printer
it will resolve your issue
Apr 08, 2009 | HP Officejet 6310 All-In-One InkJet...
Ink level monitoring on officejet 6310
Yes. Never refill or buy refilled ink carts.
Jan 31, 2009 | HP Officejet 6310 All-In-One InkJet...
Unable to print on my computer
Hello sir,
you go on HP Officejet 6310 All-in-One printer, double click on it, a small window will appear, delete all recent commands
if problem not solve then turn off your pc and printer both and unplug the U.S.B cable, now turn on the pc and delete HP Officejet 6310 All-in-One driver and restart pc then install the driver manually again and print your documents again.
thanks
Jan 14, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Officejet 6310 won't turn on.
Ok try unplugging the printer for about 15 minutes and plug it back in that will reset the printer and it should work fine.
Let me know how it works out
Dec 24, 2008 | HP Officejet 6310 All-In-One InkJet...
Master Reset
I don't have a 6310 but I do have 4 printers one of which is a 5610. I never bothered w/ a reset switch because I would just turn the printer off, then unplug everying for 2min. Then I would reconnect everything back. If it doesn't work, I suggest you uninstall the software and reinstall it again. Let me know if this helps.
Nov 10, 2008 | HP Officejet 6310 All-In-One InkJet...
Need postscript printer driver for vista
Here is the full software, just install it as postscript printer during setup.
HP Officejet and Photosmart Full Feature Software and Drivers
Unplug the printer USB befoare starting setup.
Here is also general download page for 6310:
» HP Officejet 6310 All-in-One Printer » HP Officejet 6310xi All-in-One Printer
Oct 26, 2008 | HP Officejet 6310 All-In-One InkJet...
HP Officejet 6310 All-In-One InkJet Printer Logo
181 people viewed this question
Seeker5211
Seeker5211
