Question about Bosch HBN 7052 GB Stainless Steel Electric Double Oven
I can hear the fan but there is no heat! - Bosch HBN 7052 GB Stainless Steel Electric Double Oven
  • Bosch Master
  • 3,463 Answers
If the fan is working o/k, the n you need to fit a new o ven element, located at the rear of the oven compartment behind a removeable cover.
Posted on Oct 11, 2010
Oven Wont Heat up
have an electrician check the oven element as it may be burnt out
Mar 07, 2016 | Ovens
My oven doesn't heat up
It could be the switch or heating element
Mar 17, 2013 | Thermador SM272 Electric Double Oven
The oven will not heat up, it will say start, I enter the temperature I would like it to heat up, it will say that on the display, I can hear some noise (sounds like a fan) but there is no heat. And the...
Good morning, the fan noise is probably the cooling fan in the control compartment. With an electric oven, it could be a resettable thermostat that tripped and needs to be reset. Or it could be a bad heating element. Display will display lot if it can't bring the oven temp up. Hope that helps.
Feb 09, 2018 | KitchenAid Architect Series KEBC208KSS...
Hello, I am having trouble with my built in Zanussi ZBF 360. When I turn the oven on to the fan symbol the 'on' light comes on and when I turn to the required temperature the heating light also appears. ...
If you cannot hear the fan going, then it is possible the fan is faulty, and the element has probably failed as well.
Both these components can be accessed by removing the panel at the rear of the oven compartment
Feb 02, 2011 | Zanussi ZBF360 Electric Single Oven
FAN ASSISTED PART OF OVEN DOES NOT WORK - ALL OTHER PARTS OF OVEN WORK
3ce67db2-692b-4b64-9a3b-5ffc185dfc29.pngIf its convection , take the back panel off inside the oven an change the element . Ta daaaaaaaa !
Dec 26, 2009 | Bosch Ovens
HELLO MY FAN OVEN STOPPED WORKING ALTHOUGH THE ALL OVER FUNTIONS ARE OK. WHEN I TURN THE FAN OVEN ON I CAN HEAR THE SOUND OF THE FAN BUT THERE IS NO HEAT EVEN AFTER A LONG PERIOD OF TIME.
If it is an eletrically heated fan oven, thei it sounds like the oven element has failed.
This is usually located at rrear of oven behind a removeable cover.
Hope this helps you.
Dec 06, 2009 | Ovens
Im getting this message u60 cooling fan can some one tell me the meaning? Thanks
There is a small fan you should be able to hear blowing when the oven has been hot for a while. The fan keep the electronic controls cooler so they won't be damaged by the heat.
Aug 21, 2009 | Dacor MCS130 Millennia Electric Single...
Rubbing sound-like noise when switching bottom oven on
most likly the fault is the fan blades touching the side of the circular hole,to test.1.switch of all power.2.when power is switched of try switching your oven to on position.if oven will not work then proceed3.if you can turn the fan blades by useing a thin piece of wood or simler.4 if when you turn the blades you hear a rubbing noise you might take a closer look if you have torch point it in if you see the blades touching or one of the blades touching it might be possable to to push the offending blade back very slightley useing the same piece of wood you yoused at 3.if this fails to solve your problem the fan moter might be ready to give up. I hope this can solve your problem.yours adrian.
Feb 14, 2009 | Fisher and Paykel OS302SS, Stainless Steel...
Bosch HBN 7052 GB Stainless Steel Electric Double Oven Logo
223 people viewed this question
Top Bosch Ovens Experts
Oloyede Monsuru
michael_t919
Are you a Bosch Oven Expert? Answer questions, earn points and help others
