Question about Microsoft Xbox 360 Console
Xbox i have 3 red lights but there not fully red. and there is one green light 2 .it is from overheating or whAT??i tryed to unplued and it worked once ???plz help thx
When it does that turn it off imediatley and it should stop
Posted on Jun 02, 2008
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
I have the red ring of death
okay dont panic YET!
Try this try overheating ur xbox360 by stopping the fans ge 2 sticks small enogh to stop both fans i used two darts most people use q-tips well any way wen uv stopped ur fan s the red light s on ur xbox will still have 3 lights wait untill the lights have only 2 lit on the left hand side of the ring this is wen ur xbox will have overheated let it cook for 1min if that the unplug leave for 15-25mins to cool to room tempand boot it back up GREEN LIGHTS
Nov 27, 2010 | Microsoft Xbox 360 Console
A red ring is around my xbox start up button
How may lights are showing up?
3 red light is GPU and the CPU overheating,
2 red lights is general overheating
1 red light is E74 and 4 red lights is the av cable.
For the 1, 2, 3, red lights you will need to get it fixed you can either send it in to do this or repair it yourself
Oct 26, 2009 | Microsoft Xbox 360 Console
My xbox360 will not stop flashing red
Sorry, only answer is to phone xbox and arrange to have repaired. Good news is its all free and should be back with you in 2 weeks.
Sep 20, 2009 | Microsoft Xbox 360 Console
Red lights on x box 360
this is a common problem
all you have to do is check the av lead in the back of the console
make sure its firmly in place not wobbly
should fix the problem
2 left red lights = overheated
3 red lights = broken
4 red lights = av lead disconected
pls rate "
Jan 08, 2009 | Microsoft Xbox 360 Console
Xbox 360 3 lights, tried the fix still have 2 lights
2 Red lights displayed on the front of an Xbox 360 indicates it is overheating here are some solutions provided by Microsoft
http://support.microsoft.com/kb/907533?sd=xbox
If it continues - Under the circumstance that you have not voided your warranty or allowed it to expire you can send your 360 away to get a replacement.
Hope this helped ;)
Blazamane
Jan 07, 2009 | Microsoft Xbox 360 Console
3 red lights and one green one in the middle HELP
how can i fix this ring of death it will not let me play the game
Jul 31, 2008 | Microsoft Xbox 360 Console
3 red lights on my xbox 360 please help
Hey cozierterry,
While this may be an indicator that something is wrong with your Xbox 360, there are a couple of things that you may want to consider before seeking additional assistance.
According to information provided by the manufacturer, the light on your Xbox 360's power supply should still light up green even when the console has encountered a three red light problem. If the light on the power supply isn't green, you will want to take different actions based on what color is displayed. If this light is red, the AC adaptor may either be defective or has recently overheated. If the light is orange, you may need to double-check all cable connections are secure. If the light on the AC adaptor isn't lit, the AC adaptor may need to be replaced.
Alternatively, you may want to try turning the Xbox 360 off, then pressing the power button again roughly 10-15 seconds later. If the unit powers on normally and the three red lights disappear, the system may simply have needed to be reset.
Should the problem persist however, you may need to speak directly with Microsoft for further assistance, as three red lights often indicate a hardware failure that requires repairs. You can reach Microsoft's toll-free Xbox support hotline at 800-4MY-XBOX (800-469-9269), or you can always request service through the Xbox website:
http://www.xbox.com/en-US/
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 28, 2008 | Microsoft Xbox 360 Console
RED lights flashing
This is going to sound like a very strange solution, but it worked for me, twice. My xbox 360 gave me the red ring of death once, and in my despair I asked a few friends about anything they can think of, and one suggested letting it run for 10 minutes while wrapped in a towel, or blanket. By that point I was desperate enough to try it (I had bought a refurbished one, so it wasn't under warranty anymore), and lo and behold, my xbox 360 is as good as new. Basically what you're doing is shocking the system into working via overheating... I know that doesn't make much sense, but, like I said before, it worked twice for me. Hope this helps!
Jul 27, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
15 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
