Question about Magic Chef CYG3004AWW Gas Dryer
Doesn't get hot - Magic Chef CYG3004AWW Gas Dryer
  • Magic Chef Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 17, 2010
Engine temperature gauge low
I would suspect the thermostat first.
Aug 17, 2017 | 2002 Dodge Grand Caravan
Dryer doesn't shut off and doesn't get hot
Look at this video to help you fix the no heat issue.
Nov 14, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
What should i do when the hot air doesn't work
does the air not blow when it is turned to hot or does it blow but just not hot? If it blows but not hot you need to replace your thermostat and heater core which looks like a little radiator under your dash.
Jan 21, 2012 | 1998 Oldsmobile Silhouette
I have a 2001 Ford Focus DOHC. Heater doesn't blow hot. Hot cold indicator switch clicks as i9t should when I turn indicator but it doesn't seem to change anything
Feel your heater hoses and see if they are getting hot..If so when your click from the switch ,,make sure the door is switching from hot to cold
Sep 16, 2011 | 2000 Ford Focus
Temperature needle stays on the hot , have changed temperature sensor but it still stays on the hot and the engine is not overheating or leaking anything..what is making it stay on the hot
replace the thermostat,, and make sure that the fan engages , just because the fluids don't boil over doesn't mean the temp isn't to high, if your saying that the temp gauge is stuck on the hot setting, and doesn't move even when the car is cold,, thats a different problem,, if thats the case whats the make , model , and year
Sep 11, 2011 | Ford Thunderbird Cars & Trucks
Sometimes there isn't enough hot water for a shower when the hot water mode is set.I have set the hot water temperature to 65 degrees
Are you waiting long enough for the water to be totally heated, before showering? Unfortunately, all the water doesn't reach 60 degrees celsius (140 degrees fahrenheit) in a matter of minutes. Try switching to the hot water mode sooner and allow enough time for the system to heat up entirely. If that doesn't solve the problem, the burner may need cleaning,
Hope this helped you. Please let me know. Thanks.
May 05, 2011 | Heating & Cooling
Dryer doesn t get hot
it is going to be either the igniter for the gas or the heating element
you probably have an electric igniter. it is not igniting the gas to make the dryer heat i would definantly start with that
Jan 07, 2009 | Kenmore Dryers
Magic Chef CYG3004AWW Gas Dryer Logo
83 people viewed this question
Top Magic Chef Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
