Canon AC Adapter K30286 - Office Equipment & Supplies
REPER AC ADAPTER K30263
K30263 Adapter..... is REPER "REPAIR"
CANON K30263 AC ADAPTER 32VDC 0.9A 24V Used POWER SUPPLY PIXMA M
$59.99
Condition : Used
Content : One Adapter only Manufacturer: CANON
Model Number: K30263
Part Number: QK1-2228-000-DB01-01
> Input Voltage: 120-240V~ 0.9A 50/60Hz
Output:
32V === 0.9A
24V === 0.5A
24V === 0.03A
Output Connector Type : 2 rectangle White Flat
1 x 2Pin, 1 x 7Pin [ • • ] [ • • • • • • • ]
Dimension: 17 x 10.5 x 7 cm approx.
Weight: 310 grams approx.
Compatible with: Canon Pixma MP830 Printer K1027 K10270 QC1-9029-DB01-01
http://azsurplus.com/index.php?main_page=product_info&cPath=1_24&products_id=1211&language=en
Feb 26, 2015 | Office Equipment & Supplies
Need to find source to buy canon ip4300 ac power adapter
press canon smarthead button .reports , then print user config page
Feb 19, 2013 | Canon PIXMA Office Equipment & Supplies
I want to find the part # for canon 3000f AC adapter.
http://cgi.ebay.com/AC-Power-Adapter-Canon-CanoScan-3200F-Scanner-12V-/300416673485?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item45f23aa6cd
this is for the 3200F ..but in the same range cause I know for sure that on your model is a 12 V adapter ...take a look and if the plug is the same ...you can take it without care cause it will work ...
Apr 26, 2010 | Canon CanoScan 3000F Flatbed Scanner
Camera will not power on with battery or ac
Theres a 1.6 amp fuse on the circuit board that needs replacement, and also two transistors kz 3 b1 and jp 3 b2, but I can't find the transistors online anywhere. If you find them tell me. Thanks.
Dec 28, 2009 | Canon PowerShot S50 Digital Camera
Canon powershot sd750
The AC adapter for the battery charger shoud work from 110V-240V with auto detection for voltage. Look at the marking on the AC adapter and the input voltage should show 110V-240V. Once you verify this, the charger will work on 220V and you will only need the outlet adapter.
Jan 18, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Does Anyone know how to test Canon i860 AC Adapter??
Yes I know. put the adapter into the plug and switch on, and put the another side in a glass which contains water, then you can observe water avaporate or not. If water avaporate it is working otherwise it is not working. Just try and send me reply pnbab@hotmail.com
Nov 04, 2006 | Canon i860 InkJet Photo Printer
Power Adapter
The operating voltage of the AC Adapter Kit/Compact Power Adapter/Battery Charger is 100V - 240V and conforms with international standards. Voltage may be unstable in some countries/regions. Please take care when using the device. The shape of the plug varies depending on the country/region. Make sure the conversion plug adapter is the right shape for your location.
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
537 people viewed this question
jasbo
jasbo
