Question about Olympus FE-100 Digital Camera
I dropped my camera and the lens wont come all the way out and the screen comes on but it is fuzzy i need help on how i can fix it by myself
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Oct 11, 2010
  • Brian
    Brian Jul 28, 2014
    #4 worked but it was stuck again! Is there a way to "clean" the lens tracks so it will work again? I've already tried blowing compressed air around thenlens area. Thanks.
Camera screen is fuzzy
Try cleaning the lens with a camera cleaning kit, other than that it will need to be serviced by a professional.
Mar 10, 2012 | Panasonic Lumix DMC-FH2 / DMC-FS16 Digital...
Pictures fuzzy when you look through the viewer.
The viewfinder and the picture lens are totally separate. If it looks fuzzy, and then comes out fuzzy, the capture screen inside needs cleaned. The main lens and viewfinder lenses should be cleaned too.
Get estimates before you say yes to the work. It might be cheaper to buy another camera, unless you can do the work yourself.
Aug 06, 2009 | Sony Cyber-Shot DSC-P52 Digital Camera
Kodak easyshare c533 lens is stuck
after 4 seconds view screen pic melts and goes blurry
Oct 19, 2008 | Kodak EasyShare C533 Digital Camera
Exilim ex-s770
First, check if you haven't set the camera for MACRO shoots, if so, only objects very near the lenses are focused. If is not the case you may have drop it and the lens got out of alignment.
Sep 05, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Lens Stuck
YOU CANNOT REPAIR THIS SOPHISTICATED CAMERA YOURSELF!!
I guess pushing the lens inside may have made the problem worse.
I follow a rule- if you drop an electronic equipment and a problem occurs- it usually takes a professional repair!
For all you kamow there is a minor problem in the camera, like something stuck inside or something like that. and most certainly you will aggravate the problem by trying to do it yourself..
do post when you get it repaired, for all of us to know what goes wrong when lens gets stuck..
take care
Jun 17, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Camera lens might be broken
My friend droped my camera and the lens is sideways. i can look at my pictures, but when i want to take a picture it is black and says lens error. what should i do?
May 21, 2008 | Casio EXILIM EX-Z70 Digital Camera
T737
Ihave the same problem. Its annoying. When you turn it on does it make a buzzing noise? Cause that's what mine does. Except I never dropped my camera. It just goes to the Polaroid screen and then turns off. I'm wishing I wouldve bought a different camera :( Sorry I can't help..
Mar 28, 2008 | Polaroid T737 Digital Camera
Broken zoom
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 16, 2008 | Canon PowerShot A520 Digital Camera
Olympus FE-100 Digital Camera Logo
62 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
