Question about Elna 2007 Mechanical Sewing Machine
How do I set timing on an Elna Carina 1980 model? I'm refering to the timing between the needle and the rotary hook. The main drive wheel powered by the belt has come loose from the lower horizontal drive shaft (which runs the length of the machine).
  • Elna Master
  • 1,133 Answers
There is a service manual to download at this website http://www.arizonaexpressionz.com/elna_service/carina_500_service_manual.pdf
but it is written for a trained technician and may assume a certain level of expertise of the reader.
Hope this is of assistance to you.
If you are in the USA you could also contact White Sewing Center, www.whitesewingcenter.com - this gentleman actually trains how to repair sewing machines, and sells many Elna parts, machines and services them too.
Posted on Jun 21, 2011
  • Anonymous Oct 27, 2015
    doesn't talk about repairs
Need to drop the feed dogs on my elna carina sewing maching
The Carina came with a metal plate that you clip over the feed dogs onto the metal plate (rotary hook cover), they don't have the feed dog drop feature.
Sep 06, 2013 | Elna Sewing Machines
Elna carina 390 b power cord/foot pedal
Sewingpartsonline.com carry them
May 28, 2012 | Elna Sewing Machines
check with a elna dealer
sewingpartsonline.com
sew4less.com
sewingmachineplus.com
ebay
How to check timing on pe180d embroidery machine
In case of adjusting sewing machine timing, there are twomain parts that you should follow.To adjust the hook needle timing on the rotary hook, first,remove the bobbin, bobbin carrier, and covers so you can see the movement ofthe hook. This may involve removing the needle plate for top loadingassemblies, or removing the hook cap from the front of the machine. Itoften requires the removal of the lower covers to reach the componentparts. Adjust as needed when doing sewing machine repair.Set the machine to a straight stitch at the defaultposition. Different models have different default positions including themost common far left and center positions. If no problems are perceivedin needle bar positioning, the default position will suffice. If thereare needle bar position issues, these need to be adjusted prior to adjustingthe timing. Follow proper sewing machine repair procedures.Rotate the hand wheel toward youuntil you see the needle reach its lowest position and begin its rise. Now lookfor the point of the hook as you continue rotating the hand wheel. Thepoint of the hook should strike inside the needle scarf above the needleby about 0.5mm. Sewing machine repair is vital for smooth operations.Check to see if the hook fails topick up the thread. Double check the needle bar positioning including thehook needle spacing. If these are appropriate and the point of the needlestill fails to pick up the loop thread, proceed to adjust the timing of thehook. Maintain regular sewing machine repair. Look for the lower drivemechanism. It may be a lower shaft with gears on either end. If this isthe case, look to the right end of the shaft for a gear with adjusting setscrews. Loosen and manually adjust the position of the hook. Tightly hold thehand wheel while turning the drive shaft to set the proper position. Retighten adjusting screws. Some models have timing beltsthat control the timing of the sewing machine. Look for a belt connectedon each with to drive gears. Look for work cogs on the belt. Inmost cases, you can reset the timing belt, without replacing it. If,however, the belt requires replacement you will need to do so. Loosen the drive mechanism on the right side to free the movement of the belt.Manually adjust the position of the hook to the needle and re-tighten set screws. This knowledge is vital for effective sewing machine repair.Once the timing has been reset,conduct thorough test sewing on the sewing machine to make sure everything isworking properly.Hope this will help you. Good Luck.
Oct 16, 2011 | Brother Disney PE-180D Computerized Sewing...
I have an elna 7000 it has suddenly in the middle of sewing running but not sewing. Cleaned etc and saw that the rotary hook underneath is not taking up the top thread (including the bobbin thread
Have you changed the needle and perhaps put it in backwards? this would prevent stitches from forming as the rotary hook goes around.
However, worst case, would be that the timing is out and may need to visit the mechanic to resolve if this is the case.
Feb 06, 2011 | Elna 2005 Mechanical Sewing Machine
Embellishine machine
To my knowledge this is requires a special machine, a felting machine. Brother, Janome, Babylock sell models
Oct 13, 2008 | Elna 2007 Mechanical Sewing Machine
Elna Carine Electronic Sewing Machine
You should be able to buy a manual online but it may be a cd or image pdf file. Try www.sewingpartsonline.com or www.sewusa.com. If they don't have the Carina but have the Air Electronic SU, model 68 then this will be almost the same. Main difference is the Carina has the needle up/down button.
Here is threading up images to get you started.
Sep 21, 2008 | Elna 8007
Elna Carina Zig'Zag Stitch Issue
Over time, and especially when not used, there is a likelihood of dust and old oil forming a sort of glue, or clag....
Remove the needle for safety, then, when you have the setting on Zig zag, gently push the needle arm to the opposite side of the zig stitch.......release the needle arm, and if it springs back quickly, it is fine, if it moves slowly, or almost not at all, then the clag needs removing with application of few drops of methylated spirit to start, at the sort of piston affair that shifts needle arm L & R .....move the needle arm back & forth until it frees up, a drop of oil to finish.........if almost seized, may require leaving overnight after using a penetrating lubricant if it is really resistant....I have had them on the bench for 3 days with manual manipulation a few times each day before they finally come good.
Bargain Box
Jan 31, 2008 | Elna 2007 Mechanical Sewing Machine
Elna 2007 Mechanical Sewing Machine Logo
331 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
