Question about General Electric WSSH300G Front Load Washer
THe door hinge on my GE front load clothes washing machine model # wssh300G1WW has rusted and bent and the screws are rusted. I would like to replace the hinges and screws but I don't think the replacement parts should cost that much especially if they are going to rust again in less than 3 years.
  • Anonymous Mar 22, 2014
    2008 model
I have the same washer & its 3 years old today. Rusted hinges & door & screws too.
Door is really hard to shut so I called GE to complain & they are overnighting me a new door, hinges, & screws. You should call!!
Posted on Sep 30, 2011
  • stacey Sep 30, 2011
    free of charge!!
GE WSSH300G Front Load Washer drains, but won't spin. Repairman wanted $340 to replace a door latch. ???
Door latch for that model I chrge labor and materials minmum charge is 180 ... its easy to replace ..2 minutes done...
May 25, 2011 | General Electric WSSH300G Front Load...
GE front load model wssh300g1ww, jumps across the floor during spin cycle, takes 2 people to hold it in place.
ha ha ha! they do dance well dont they???,,,
its the brum suport spring/s broken nothing very hard to fix, and the springs are about £10 each change them both it helps to have two people as the springs are hard to pull into place,wip the top off and you will see the two springs,,if there still there? normaly they just fall off down the back and you need to fish them out from underneath the washer,,,,,,,its a cheap fix realy
Mar 10, 2010 | GE WSXH208A Front Load Washer
I have a maytag front load mah4000aww. i replaced the wax motor and motor board put it back together. when i tried to wash a load water started to come out of the door. any suggestions would be gratefully...
The door is most probably out of alignment with the front shroud. Slightly loosen the door hinge screws and close the door firmly making sure it is fully and evenly seated into the shroud. Retighten the lower hinge screw but not fully tight. Retighten the upper hinge screw but not fully tight. Fully retighten the lower hinge screw then the upper hinge screw.
Feb 12, 2010 | Washing Machines
The door is bent a bit and now won't shut right unless slammed just right. I doesn't look bent but must be. I know I have trouble opening it after a wash where it seems stuck and I am sure the previous...
That model has 2 hinges on the door, and one or both of the hinges are probably bent, not the door. The good news is that they are pretty cheap to buy the hinges, and it only involves 8 screws, its an easy fix. After you do that, if you still have problems with the door lock, then it probably got damaged from the door closing when it was bent, and you would need to replace either the door lock or the door strike if the strike on the door is broke. I have replaced many of these hinges for this problem, and havnt come across the door lock getting damaged in the process, but have had to replace a few broken door strikes. hope this helps, good luck.
Oct 23, 2009 | Frigidaire FTF2140FS Front Load Washer /...
Model gltr1167oaso\ door hinge seems bent
Are you sure someone has not used their knee to push the machine back into positon and have distorted the front panel.
Worth putting a straight edge across the front of the machine where the lower bit of the door gasket stops to see if there is a dip there
Jun 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Where to get shipping bolts for wssh300g1ww
Hi Judy
Your best bet would be calling GE and see if there is a part number for those bolts and where you can get those.. Installer usually throw those away after installation..
Here is their tel #1 800 626 2000
Jun 29, 2017 | GE Washing Machines
General Electric WSSH300G Front Load Washer Logo
362 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Paul Bade
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
