Question about Peg Perego Cub Cadet Tractor
Have a 5234d cub cadet with a broken hydro pump shaft. will i need to remove pump or can i remove and replace shaft without removal?
2 Suggested Answers
adamfjeld
  • 1508 Answers
SOURCE: hand brake Cub Cadet
wrong forum
Posted on May 22, 2012
I have a2011 cub cadet zero turn mower but when I push the left side handle it doesn't barely move . Like theres hardly any power to move the left side. What is a matter with it? Is going to cost alot
May be low on hydraulic Oil.
Theres also a nut that releases the hydro pressure make sure it is not loose. Make sure there are no leaks. And make sure on the back of the mover that the hydro release is not pulled. If there are no issues then there is a issue with the hydro pump and yes the repair is costly. A replacement pump is roughly $250-300 dollars.
May 21, 2015 | Cub Cadet Garden
How can I get an Owners, Operation Manual for a cub cadet, series 5000, Model 5234D Diesel Tractor
You can download it here:
http://www.manualslib.com/manual/33979/Cub-Cadet-5234d.html#manual
Feb 05, 2015 | Cub Cadet Street Sign- tractor lawn riding...
Troubleshooting
It sounds like maybe you have a broken shear pin where the drive shaft connects the hydro pump. Remove the tunnel cover and you will see the drive shaft. De careful on this step: start the tractor and what that connection and see if it holds. If that is not it then you have deeper problems.
Jul 31, 2014 | Cub Cadet Garden
I have a LT1042 hdrostatic drive and it won't go forward or reverse what is wrong
can only guess
Low on cub cadet hydro fluid?
other hydro filter other and cub cadet?
linkage came unhooked from drive mechanism
your engage disengage lever at the back of the mower is set so it can be pushed,engage lever to allow hydro pump not to be bypassed
Jul 28, 2014 | Cub Cadet Garden
Cub cadet slt 1554 will not move when running
hydro pump has gone out replace it or hydro lever not engaged
Jun 14, 2014 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet 129- The drive shaft from the engine to the hydrostatic drive does not line up at the hydro end. What should I do? The roll pin in the shaft at the engine hub it connects to kept shearing, and...
This mis alignment of 1/4" is about normal that is how and why cub put the rubber flex coupling on the hydro... however if there is play in the hyro input shaft then we need to determine what the cause of this is. Good luck
Sep 07, 2009 | Cub Cadet Garden
Forward rev shaft seal leaking on 1650 cub cadet
I would say no. your best off to take that in to shop services riding tractors.
Mar 08, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Hydrostat pump leak,cub cadet garden tractor
One... these are pressure relif valves. There are O rings that probably need replacing is all, the valve can go bad but since both are leaking it will probably be just O rings from heat that went bad.
Remove the valves and replace O rings. Use a 'good' pipe thread dope on threads when re-installing.
Two... never use teflon tape on hydralic systems.
Three... boscia is no guro for sure.... lmao
Nov 05, 2008 | Garden
Peg Perego Cub Cadet Tractor Logo
83 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
