Question about Sony Cyber-shot DSC-W50 Digital Camera
My sony cyber-shot 7.2 mega pixels is jammed. At first the lense was stuck closed and noow its is all the way open and will not close. When i turn the camera on it says turn the power on and off again. What can I do to fix it?
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Oct 11, 2010
Re Sony Cyber-shot DSC-T7/S Sliding lense cover wont travel down far enough to clear the lense. Message on screen says --lense cover closed Sydney Sony repair centre says discard for new. Seems a...
Hi your camera is very simply in mechanically. It may has loosen screws go around and stuck inside. If you are careful, you can try on open and look for the piece. If you are willing to, then let me know. Thanks and best regard!
May 25, 2011 | Sony Cyber-Shot DSC-T1 Digital Camera
The camera lense is stuck open and not will close
Hi! Better check it with qualified technecian. It might damage everything if you force it. The lense broke inside. It needs to be replaced or adjust the screw to lossen so that lens will go back to its original position.
Please feel free to comment.
jonags3
Jul 19, 2010 | Sony Cyber-shot DSC-W30 Digital Camera
Cybershot message "turn it on and off again"
Make sure your shutter is open mine was stuck closed and I had to push it open and then I stopped getting the message, But now it doesn't close, it doesn't seen to affect the camera pictures.
May 05, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Fell down
lens cannot be repaired . lens needs to be replaced .Alamocamera
Mar 18, 2009 | Sony Cyber-shot DSC-W110 Digital Camera
When i turn on my camera it says Turn the power off and on again
turn it on
take hold of the end of the lense, then pull and twist gantly you may hear it click but dont force it then turn off and on again this may solve your problem
Oct 11, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony cyber shot dsc w55 7.2 mega pixels
turn on when lense extends take hold of the end of the lense and gently twist and pull the lense you may hear it click do not force the lense then turn on and off again this should solve the problem.
Aug 07, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Cyber SHot DSC-W80 lens will not close.
Your lens is jammed. Odds are it's unrepairable, but as a last ditch effort try GENTLY wiggling/twisting the lens as you attempt to power down or on.
Aug 05, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Lense stuck outside
you have jammed the 3 lens studs outside of the track , you cannot fix it without dissembling the entire camera to the lens,
its best to leave it alone and sell it on ebay for the lcd is worth 35 to 60
Apr 13, 2008 | Cameras
Sony cyber shot t9 slide show music turn off
When I turn my Syber shot 6.0 mega pixels on it shows only a white or dark display. The fotos taken are the same. It seems that something is not opening the lens. What is the problem and how can I fix it?
Many thanks.
Mar 28, 2008 | Sony Cyber-shot DSC-T9 Digital Camera
The lense is not getting closed for my cyber shot
Lens Block assy. is defecive and try first to clear the foreign particles like sand etc if any. The block has to be replaced. May be we can supply this in 3 weeks time. Pl.let me know.
Nov 27, 2006 | Sony Cyber-Shot DSC-W5 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
63 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
