Question about Music
Korg c25 has power to it. Power light comes on but keys produce no sound. Any ideas?
4 Suggested Answers
  • 1138 Answers
SOURCE: when I play the sound come out distorted, like it
The manual is at:http://www.korguksupport.co.uk/upload/X50_OpGuide_E1.pdf if you don't have one. Try saving everything you want to save first if you know how to do that. Then initialize the keyboard. Follow the instructions on page 111 carefully. It sounds like you created an undesirable effect and accidently assigned the Pitch Bend Lock function to the effect. This parameter is explained on page 41 under Pitch Wheel Mod Wheel. Hope this helps.
Posted on Aug 20, 2009
  • 5603 Answers
SOURCE: Korg Wavestation EX LCD Screen Info disappears!
This is characteristic of a poor contact someplace within the unit NEAR the connections for the display. It may also be a bad plated-thru-hole in the circuit board. This problem could also be on the display circuit board itself. They often have a complete microprocessor right on the display itself.
The vibration from the keys causes the connection to break, and the re-cycling of the power sends enough of a pulse to break down the oxide at the poor connection.
These can sometimes be found with freeze spray circuit cooler and often by applying gentle pressure at suspect points on the boards and looking for changes.
It for certain is a get out and get under repair involving taking out a lot of case screws and VERY careful handling of the cables within the unit.
Posted on Feb 26, 2010
  • 5603 Answers
SOURCE: KORG SP-250. Keyboard powers
There is probably a cable loose that connects the keyboard itself to the processor... OR the key contacts have been contaminated by spilled liquid. The keys are scanned as a matrix. The contacts will be a conductive rubber pressed against circuit board traces. Clean contact "pills" and the circuit traces with ONLY 99% isoprophyl alcohol.
This is NOT for the unskilled to attempt a DIY other than carefully opening and looking for a cable that has come loose.
Posted on Mar 22, 2011
I have a vox vt40 and the light for the power comes on bit there is no sound. I talked to someone with the same amp and they said there is a clip that switches on the tube that tends to go out with this...
If your amp isn't producing signal, your best bet is to take it into a local Vox autorized repair shop. There are leathel voltages involved and if you're not an experienced tech, you can get hurt, not to mention screwing to amp up worse. Here's a link to the Vox contact page http://www.voxamps.com/contactus
And one to find the list of Vox repair shops.
Korg USA Musical Instruments
Feb 11, 2015 | VOX Music
How do I restore a dead key on a Korg X5?
What do you mean by applied graphite...graphite powder? That is not the solution I wouldn't think, you need to use a keyboard contact repair kit, which has a solution you paint on? Something like the link provided might be in order. Make sure there are no improper conductive bridges formed between the contacts in the PCB board surfaces. Replacement rubber pads (the part that presses down) are available from any decent service provider (try Syntaur if can't find http://syntaur.com/korg_x.html ) (beneath key) Korg Key Contact Repair Kit Replacement Keys and Parts for Korg Series Keyboards
Jan 14, 2015 | Korg Music
I have a korg pa 80 it have not sound
Initialization: N/A
Preload: Disk Load (6 Disk set available from korgpa.com)
ROM Check: Given on power up.
http://www.sweetwater.com/sweetcare/articles/initialize-reset-preload-korg-pa80-60
Apr 10, 2014 | Korg 37 MINI-KEY 8-VOICE...
I have korg pa 50 fd my screen say korg pa 50 i get only one thing my paino work only
i have korg pa 50 fd when i turn on the power on screen says korg pa 50 only thing work just piano that is it my menu all freez to download the floppy disk is any body has any idea thanks
plz help me out
Aug 14, 2013 | Music
Korg pa50 freezes at start up and only says "KORG PA50"
I think it is time for you to buy one new one....That you can but on side for parts.
Apr 04, 2012 | Korg Pa50 Professional Arranger Keyboard...
Hello my Korg X5D on switching on shows 00:Initcombi0 on top display and "battery low" blinks on lower display, Keys from 33-40 are malfunctioning ( giving odd sound) other keys are working...
There's a watch type battery (flat disc) on one of the boards inside the X5D. This maintains the settings while the keyboard is switched off and could be the whole problem.
The keys are on two different circuit boards connected with a multi-pin cable. If the cable were dislodged I would expect it to simply cut off half the keys but it's probably worth checking.
Oct 30, 2011 | Korg X5d
How to perform a factory reset?
1. Power-off the PS60.
2. While holding down the four PERFORMANCE buttons and the OCTAVE DOWN button, power- on the PS60. The PS60 will be initialized, and the factory-set data will be written into internal memory. The display will indicate "Initializing..." while data is being written. Never turn off the power while this indication is shown.
Manual available here:
http://www.korg.co.uk/downloads/ps60/docs/PS60_OM_E1.pdf
Jun 24, 2011 | Korg PS60 61 Portable Performance...
KORG SP-250. Keyboard powers up, you can change all selections, five or six random notes sound, but the other keys produce no sound at all.
Mar 22, 2011 | Korg SP-250
I have a1980 Korg CX3. Last night at the gig It started to make noice that sounded like all the keys were being pushed down at once. It did npot matter if I was in a preset or using the drawbars. Any...
This is likely a power supply problem. It is important that all interconnected equipment be powered by the same receptacle OR source or isolation such as DI's be used for system safety.
Jan 30, 2011 | Korg Cx3 61Key Modeled Combo Organ
Hello i have a korg pa 800 just a while ago something happened it was fine i was using it and all of a sudden it just got really pitchy and the sounds seem to mix and its sounding really off key even...
If this is not a low power supply problem, you might try circuit cooler to isolate the bad part.
Beyond the power supply I would recommend taking this to a shop for repair ONCE you have tried a factory reset.
Use this site for downloads:
http://www.korgpa.com/pa_root/en/products/pa800_soft.html
Jun 03, 2010 | Korg Pa800 Synthesizer
Music Logo
153 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
