Question about Toyotomi TIN/TIG-329D Air Conditioner
Hello i have a toyotomi air condition TIN 288 (R-22).At heat mode when the pump start working it stops after 1 minute and the operation led (green)and heat mode led(orange)flashing.Could you help me because i have lost the manual?Thank you
3 Suggested Answers
  • 86 Answers
SOURCE: toyotomi ccti/ccto 445
red light means power on
Posted on Mar 16, 2008
micromatikal
  • 2777 Answers
SOURCE: I have the toyotomi TAD-T38J
That means you have some fairly major hardware failure inside the machine. The control board is my suspicion for sure, it definitely sounds like that is having electrical failure.. Have you called back the Toyotomi service person / people after you confirmed that their suggestion made no difference? This unit is definitely going to need in person service.
Thanks
Tim
Posted on Oct 08, 2010
My 12000btu spliter air condition start and stop in 5 seconds
24
EN
TROUBLESHOOTING
CAUTION
If any of the following conditions occur, stop the air conditioner immediately, turn off the main power switch and contact the
dealer.
• The indicators flash at short intervals (5 Hz). Reset the circuit breaker 2 to 3 minutes after the power main switch is turned
off.
Despite the resetting operation, the indicators still continue turning on and off.
• The main power fuse often blows, or the circuit breaker is often activated.
• Foreign matter or water has fallen inside the air conditioner.
• Any other unusual conditions are observed.
Before asking for servicing or repairs, check the following points.
Recheck
Inoperative
• The power main switch is turned off.
• The circuit breaker is activated to cut off the power supply.
• The main power fuse has blown.
• The electric current has stopped.
• The batteries in the remote controller used up.
• The ON timer is set.
• As a protective mechanism for the air conditioner, it does not operate for 3 minutes
immediately after restarting operation or turning on the main power.
Poor cooling or heating performance
• The air inlet or outlet of the outdoor unit is blocked.
• Doors or windows are opened.
• The air filter is clogged with dust.
• The louver is not at the correct position.
• The fan speed is set to low.
• The air conditioner is set
to the DRY or SLEEP MODE.
• The temperature setting is too high (during cooling operation).
• The temperature setting is too low (during heating operation). (heat pump models)
Feb 01, 2015 | Samsung AS18A6RB Air Conditioner
How do I drain water from a toyotomi portable ac unit
1. put it on higher position near water drainage, window...etc
2. make hole in water tank
3. put tube in hole and lead tube in drainage or outside (hole in frame of window recommended for long term use). Fix tube with glue
4. take care that water tank is higher than end of the tube
5. done
Jul 06, 2014 | Toyotomi TAD-T40LW 14000 BTU Portable Air...
I have a summer house and would like to heat the house in winter while I'm away to keep the humidity out. The problem is there is often breackdown of electricity. What must I do@
Hello,If unoccupied during the winter so what,Assuming the house water is off & drained.#1 get a generator for the house with auto demand start.#2 install a millivolt steam heat system (makes it's own electricty to operate)#3 the burgular alarm system can have tempature alert added so you get a phone call if the house gets too cold.Just an idea.
Oct 15, 2010 | Toyotomi TIN/TIG-329D Air Conditioner
Heatcool toyo ta-09chs
hi friend,
go to website
www.retrevo.com/samples/Toyotomi-manuals.html
i think this may solve ur problem
thank u for using fixya
regards,
sivaranjini
Aug 05, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
English Instruction Manual for a Toyo TA-09CHS Split Air Con Unit
I bought two TOYO split air conditioner in 2009. They are awesome, the best quality split air conditioner in Japan. I have two manual in English and I can mail you one. Please let me know how to mail it to you.
Jul 20, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
TOYO TA-09CHS aircon problem
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem.
Jun 09, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Toyo Aircon. Starts perfectly. Runs for approx 5 min and then the yellow "timer" light starts flashing and machine stops working. Green power light on...yellow timer light flashing. When you switch unit...
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck!
Dec 28, 2008 | Toyotomi TIN/TIG-329D Air Conditioner
AIR CONDITIONER LG S18AN
The operating LED will be blinking 5 times, means that there is a
comunication error (serial comunication) between the outdoor and the indoor unit.
Dec 28, 2008 | LG LS-K1830CL Cool Mini Split Air...
Toyotomi TIN/TIG-329D Air Conditioner Logo
515 people viewed this question
Top Toyotomi Heating & Cooling Experts
hmca
Level 1 Expert
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Toyotomi Heating and Cooling Expert? Answer questions, earn points and help others
