Question about Harman Kardon HKTS 14 System
HK Subwoofer recently started emitting a popping sound while operating. The noise is not constant, but more intermitent
My liftmaster garage door openers as a constant alarm noise. Not beeping. Just constant. How to fix?
Premium Chamberlain garage access systems feature an internal battery backup that will operate the opener in case of a power outage. The garage door opener will emit a beeping sound when it is operating off of battery power or when the battery is no longer able to recharge. needs a battery.
Hope this helps.
Dec 31, 2017 | Building Materials
Advent subwoofer
emits a steady sound means that their is some miss connection in the in put
May 23, 2014 | Audio Players & Recorders
Powered Sub Woofer emitting lound crackling noise
i would say so sounds like woofer is dying unless u pull it apart and replace the woofer it doesnt have to be same brand just same size and watts and ohms then u can keep it
May 28, 2010 | JBL 5.1-Channel Home Theater Speaker...
I have a wharfedale svp15 passive loudspeaker. The subwoofer has started crackling and popping at low volumes and has no deep bass. At high volumes it sounds great as usual and can't tell if the crackling...
Information I find online says it an Active Subwoofer, so that introduces its own amp as a possible source of the symptom. If there is another version of this model that's passive, all the more reason to believe the amp is the problem because passive speakers don't spontaneously emit sounds.
If there was a physical reason for the crackling I would think more power would make it worse or blow it up.
A poor sub signal cable connection might explain low current anomalies if random noises are entering the signal path.
Make sure the signal, speaker and power cables are not aligned parallel and close to each other.
Feb 26, 2010 | Audio Players & Recorders
Front End Noise, Chev Cavalier
It sounds like you have a bad c v or constant velocity joint. Look under the car next to the wheel look for a rubber accordian type unit, if the rubber is torn or lose the grease has escaped and damaged the joint. You can replace it yourself, but if your not mechanically inclined would say take it to a shop.
Mar 04, 2009 | 2004 Chevrolet Cavalier
Farting Noise
Do a more detailed search there is a solution but you will have to send it out to get repaired the noise is from when it goes on stand by...jensen is of no help
Aug 27, 2007 | Jensen JPS10 Subwoofer
Audio system makes extra noises... pops
Check all the wiring. It could be a loose connection since it's intermitent. Really pay attention to the power cable, both the end for the amp and the one that's going to the battery cable.
Sep 05, 2006 | AudioBahn A8002T Car Audio Amplifier
Harman Kardon HKTS 14 System Logo
134 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
