Question about Humax Televison & Video
Humax pvr 9200T
EPG takes ages to load is this normal and can it be resolved
  • Anonymous Mar 19, 2014
    humax 9200t locks and freezing
Hello Fixya Team,
I did solve the problem with the EPG not updating quick enough when you power on.
If once you power on you switch channels to BBC1 youwill find the EPG updates quite quickly.
Hope this helps out.
Lomp.
Posted on Jun 01, 2008
Why I can't get my machine to record more than one programme, i.e. it will not record a series of programmes?
In the Recording menu of the Humax PVR-9300T (or (9200T), if the start or end times are set to anything other than "On Time", series recording is disabled.
Jan 07, 2015 | Televison & Video
Need Simple User Guide for Humax 9200T
If you Google 'Humax' you can get a manual on line, but they are all the same. What is it that you want to do? I have the 9200T, so if you email me at Paul.Brooksbank@londonmidland.com I will try to help you.
Jan 09, 2012 | Televison & Video
How to connect an LG26LE3300 TV to a Humax PVR-9200T and to an Inventive DVD video player? These worked fine with my old TV using scart cables but not with the LG.
You will see the colored jacks on tv. There should be a print by them that says out. Match the colors from the jacks on the tv to the same colored ones on the Humax. The ones on the Humax should say input or a/v or dvd, or phono. From the dvd player, match the colors from here to the tv. The tv should have another set of 3 colored rca jacks that say imput on them.
From DVD Player out to tv in From tv out to Humax in/av/dvd/ ect.
Yellow is video Red is Audio Right Channel White is Audio Left Channel
Jan 14, 2011 | LG Televison & Video
My Humax Duovisio PVR-9200T often freezes completely and has to be switched off at mains for a few seconds. Or commands from remote (eg subtitles, menu, channel change) take minutes to respond. Or...
Remove the Aerial.
Switch on or if it's frozen switch off at the mains and on again.
Press Menu
Installation and enter password - 0000
Select 'Default Setting' and OK
Select 'YES' and OK to restore all settings to factory default.
Confirm again to start loading, enter the password again and it will start scanning for channels but won't find any.
Replace the aerial and press OK to rescan and now it will find channels. On completion press SAVE then EXIT on your keypad.
You won't lose any saved programmes but you will have to re-schedule your recordings.
May 03, 2010 | Humax DRT400 DVD Recorder w/ 40 hr Tivo
Humax PVR 9200T nolonger responding to controls on machine or remote.
1. Power off at the rear
2. Disconnect Aerial
3. Switch ON
4. If the unit can then be switched on carry out a Default setting
5. When the unit restarts insert the aerial cable so there is signal when the auto search appears.
Also, believe it or not, check your batteries in the remote control (seriously).
Apr 27, 2010 | Televison & Video
Since retuning I have lost BBC 1,2,3,4 & Ceebeebees. I receive my transmission from Winter Hill, and have a Digifusion FRT 101 set top box connected to an Alba CTV3485SIL TV. I also use a Humax...
sounds like you need to rescan for channels, Should be in settings menu then maybe channels, Normally autoscan or channel update, Also make sure your airiel is good.
Nov 05, 2009 | Televison & Video
My PVR has retuned (DSO)to the wrong transmitter. I receive signals from the Winter Hill transmitter and live in SW Cumbria. My Humax 9200T has retuned ok but my older 8000T has retuned to a transmitter in...
Not a complete solution but after much fruitless fiddling through the menu I eventually found that the programmes were actually there but under different channel numbers.
I searched a long way down the LIST of channels (on remote) The BBC1 channel I want is now 800 BBC. Selecting 1 on the remote still brings up BBC Wales.
This applies to my Humax 8000T PVR - I can't comment on other makes of Freeview box.
PVR freezes and nowt will work
I'm in the US and am not completely familiar with the digital conversion in your area, but the following information may be helpful to you.
Humax released a software update earlier this year which adds the full range of ‘Group 2' Freeview Playback. For details see Trusted Reviews
Aug 14, 2009 | Electronics - Others
Cannot find codes for One For All remote
just had the same problem with the humax pvr-9200t
found VCR1794 & SAT1808 work most of the standard buttons.
the codes need to be downloaded from oneforall.
Dec 22, 2008 | One For All Televison & Video
Humax PVR 9200T freezing picture and will not turn off.
Unplug the aerial; switch the PVR On; if you have control via the remote do a reset to default settings thus:
1. press Menu on the remote
2. select Installation and enter default password of 0000 unless you have changed it
3. select Default settings and okay on YES
4. then turn if off again via the remote
5. plug the aerial back in and it will scan for channels, save them of course.
I got help on this from other forums but saw your request for help. This worked for me.
Oct 25, 2008 | Televison & Video
Televison & Video Logo
339 people viewed this question
Top Humax Televison & Video Experts
Andy Fraser
Andy Fraser
Tony
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
