Question about Sony DVP-CX777ES Multi-disc DVD Player
Player will not read discs. the player is old but has only been used rarely. It is virtually new.
I had the dvd player/radio /cd player replaced in my 2007 Yukon, the cd player would not read discs, the dealership ordered a new radio & now the dvd player reads disc region error & will not play...
If your using copies then some dvds wont read them even if the old one did, sometimes its a gamble if it reads or not, if your using a master then i would have them check it out, it may be bad or need programing, it funny because sometimes it will play a copy and sometimes not, thats what i've run into. hope this helps.
Aug 31, 2010 | GMC Yukon Cars & Trucks
Player does not recognise DVD has been inserted
Try using a CD-Lens cleaner since the player wasn't used dust might have got into the lens.
Jul 11, 2008 | Wharfedale DVD-M3 DVD Player
Wii console won't read discs
Check to see if there are any scratches on the disc. Scratches or marks on discs will render game discs unplayable or will freeze the game and will often show a message stating “Disc Read Error” or something to that effect. Best remedy for starters, is to clean the discs and make sure there are no scratches or marks left on the play-side of the discs.
Most Game Discs, DVD’s and CD’s can be fixed quite easily. Some home remedies may help with very light scratches on some of these discs but a professional disc repair service is usually required to repair any discs with more than very light marks or scratches. Discs can normally be repaired back to a virtually new condition.
For further help on disc repairs, visit:
www.discREPAIR.ie Get Scratched Discs Repaired Back to "As Good As New Condition".
Check the “More Info” & “FAQ” Sections for further details on disc repairs and related matters.
If you tried some home remedies and they have not worked, try sending the disc off for repair. Contact the site above for advice on repair and shipping.
Hope this Helps!!!
Apr 25, 2010 | Nintendo Wii Console
Hi -- my toshiba SD3990 model DVD player won't
Your DVD player is fu.k.d up.  These things are made so cheap now a days that it is more trouble to try to fix the thing, than going out and buying a new one.  You can try running a disc head cleaning kit through it first to see if that helps.
Nov 23, 2009 | Televison & Video
CD player will cycle through all 5 discs and then show "No Disc"
HI. the main board is ok. this is the actions of a malfunctioning optical lens assembly. the lens is unable to read, due to the damage to its structure or, the laser has burned out.
The main board is programed to issue the (no disk) alert if the lens doesn't relay audio data. simply replacing the failed optical lens assembly will fix this issue.
Jun 17, 2009 | JVC XL-F254BK 5-Disc CD Changer
Previously recorded disks and new disks all-dirty disk rejection
you may need to go thru the cleaning process a couple of times since it has never been cleaned ,but I'm glad there is a for sure improvement
that was my thinking about the laser lens cleaning disc , I have helped alot of people with thier player as well because they to did not know of the disc either. they do not advertise it enough for people to always hear about it or include the cleaning process and recommendations(maybe because they want you to buy a new one is about right!)
sometimes they get so dirty the laser lens has to be cleaned manually ( with a q - tip and the disc solution )
if you have anymore questions don't hesitate to ask
electech1
Mar 26, 2009 | Televison & Video
Bose 5 disc cd multi changer wont load any discs from the magazin
That is usually because of dirty or defetive lens, as teh player cannot read the initial track of the CDs.
Try first using a len cleaner , like the ones here.
If this does not work it will be necessary to take apart the unit and accees the lens to clean it, or replace the lens pickup. The repair must be done by a technician.
In this case call the number listed on the owner manual to get assistance
Dec 15, 2008 | Audio Players & Recorders
CD Player does not recognize CD
If using computer generated dics , disc usally bad burn progam , bad disk, burn speed to fast. Check out NERO burn. OR dirty eye, clean, laser eye with disc clean disc
Oct 05, 2008 | Teac DC-D2831 CD Shelf System
JWIN DVD PLAYER JD-VD502
its the new disc setup for dvd's there using a new dvd conversion set up disc old dvd players just dont read the new dvd's just the other night did what you did but i went out and bought a new dvd player gotta keep up with technology
if you have warranty return for update or buy new technology it sucks i know but just put old dvd in another room have fun with the old one when you buy the new one
May 07, 2008 | Jwin JD-VD502 DVD Player
Sony DVP-CX777ES Multi-disc DVD Player Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
